Ô³§£ºToshiba
' ^( h' b2 @4 \! uÐͺţºTC358775XBG / K @$ S/ V }% {8 G* ~
¹¦ÄÜ£ºTC358775XBGÊÇÒ»¿Å½«MIPI DSIÐźÅת»»³Ésingle/ dual -link LVDSµÄоƬ£¬×î¸ß·Ö±æÂÊÖ§³Öµ½1920x1200£¬ÆäÓ¦ÓÃͼÈçÏ£º
: q3 X: U9 Q4 r) h# ^* j3 U2 N
9 R4 y/ R+ ~' K% I5 g( F
( J& A! e9 `, E, _- B, @& s" G²úÆ·ÌØÕ÷£º
1 L& ]/ N. X, o7 U4 K7 O) y6 W) PMIPI½Ó¿Ú£º
2 e' \, g3 ~: G- n/ ^0 d( V/ j% _£¨1£©¡¢Ö§³Ö1/2/3/4 lane(s) data£¬Maximum bit rate of 1 Gbps/lane
& Z4 Q# H9 Z1 D9 f! G* \£¨2£©¡¢Ö§³Övideo mode£¨Non-Burst Mode with Sync Pulses¡¢Non-Burst Mode with Sync Events£©ºÍcommandmodeÁ½ÖÖ¸ñʽ + t$ G& Q9 a" q( ~+ i: l* v
£¨3£©¡¢Supports video data formats £º 6 q4 U% `' {& I- J; N, p) z
RGB565 16bits per pixel
5 m! D: g9 C: n; W RGB666 18 bits per pixel
1 X) z& d- {% p; c$ M RGB666 loosely packed 24 bits per pixel
3 e3 R' y3 a8 ~$ Y RGB888 24 bits per pixel
/ K( R8 [, U0 s9 x6 f1 R2 qLVDS½Ó¿Ú $ I" E# n9 s8 y9 O9 u6 z
£¨1£©¡¢Ö§³Ö single-link or dual-link ! n9 j$ L6 \9 i) ~" {7 ?
£¨2£©¡¢×î¸ßÏñËØÊ±ÖÓ£º135MHz
5 [% G, W) v% }4 A9 E( V) O+ M# r6 [7 E; [2 {* s
£¨3£©¡¢µ¥Â·LVDS×î¸ß·Ö±æÂÊ1600x1200£¨Êµ¼ÊÓ¦ÓõÄʱºòÒ»°ãµ½720p£© ˫·LVDS×î¸ß·Ö±æÂÊ1920x1200
" a. g+ O: m1 X3 p£¨4£©¡¢Ö§³ÖLVDS¸ñʽ£º RGB666 18 bits per pixel & v+ J) g& V( z# o2 h# ~/ \
RGB888 24 bits per pixel.
0 s- b8 a" }4 M& M' K£¨5£©LVDSʱÖÓ¿ÉÒÔͨ¹ýÍⲿ¾§Õñ»òÕß´ÓMIPI CLK»ñµÃ£¬µ«ÊÇÒ»°ãʹÓÃMIPI CLK£¬½¨ÒéÔ¤ÁôÍⲿ¾§Õñ£¬·½±ãµ÷ÊÔ¡£
3 d% v: t9 s4 W! e³õʼ»¯·½Ê½:IIC»òÕßMIPI COMMAND£¨Ò»°ãʹÓÃIIC£© 9 o1 G0 t2 B/ o: U9 p2 {
Powersupply * \. u9 a$ c2 i
MIPI DSI D-PHY: 1.2V
+ C! u! @$ J# i; ^LVDS PHY: 1.8 V 3 O! q* [( G) f2 K5 c
I/O: 1.8 V - 3.3V(all IO supply pins must be same level)
+ S) ~ X! h$ |4 l* x% P* rDigital Core: 1.2 V
/ I- z n# \' m; H1 o# d5 c¹¦ºÄ£º
& m' e% K% A0 o; d
% X- J* n; V5 T2 `4 o; i; M·â×°£ºBGA64 (0.65mm ball pitch) 6.0mm x 6.0mm x 1.2mm
; o& a: S% P% T2 m; [' L' J+ sÓ¦ÓòúÆ·£ºÏÔʾÆ÷¡¢¹ã¸æ»ú¡¢Ò½ÁÆÆ÷еµÈ
7 O1 A$ ~# K) k/ F4 ?- G8 cÓ¦ÓÃÆ½Ì¨£ºÈ«Ö¾¡¢RK¡¢MTK¡¢¸ßͨµÈ
7 y: @. k w" t& Z3 p
( V, I! b# l1 |( ~: B0 b9 ^. \$ k+ w; [. O2 M: r- l1 w) ~
È·ÈÏÊÂÏî: & ~. S; ?& w8 A# `9 L$ [3 C
A¡¢È·ÈÏǰ¶ËÊäÈë±ØÐëÊÇMIPI DSI£¬ºó¶Ë½ÓµÄÉ豸Êǵ¥Â·»òÕß˫·LVDS . J2 b2 }( t+ c( }$ j) ~* r7 h a
B¡¢È·ÈϺó¶ËÉ豸µÄ·Ö±æÂÊ£¬×î¸ßÒ»°ãµ½1920x1200@60Hz
7 c5 I* r1 \4 X1 xC¡¢´ËоƬһ°ãÍÆ¹ã˫·LVDSÊä³öµÄʱºò 1 L* F8 K# `& B$ x$ q! z( Q* |
D¡¢´ËоƬ²»ÊÇ´¿Ó²¼þµÄоƬ£¬ÐèҪͨ¹ýIIC»òÕßMIPI COMMANDÀ´¸øÐ¾Æ¬Ð´¼Ä´æÆ÷ÅäÖ㬵«ÊÇÒ»°ãʹÓÃIIC£¬Èç¹û¿Í»§ÏëʹÓÃmipi command½øÐгõʼ»¯µÄ»°½¨ÒéÔ¤ÁôIIC×ÜÏß¡£
1 h% a& [- j4 iE¡¢´ËоƬÓÐÒ»¸öÍâ¹ÒµÄ¾§Õñ£¬ÔÚʵ¼ÊÓ¦ÓõÄʱºòÒ»°ãÓò»×Å£¬µ«ÊÇÔÚÉè¼ÆµÄʱºò½¨ÒéÔ¤Áô£¬ÒÔ·ÀºóÃæµ÷ÊÔµÄʱºò»áÓõ½¡£ ' e+ b B' I$ l' G2 `9 O+ _4 T
Éè¼Æ×¢ÒâÊÂÏ 8 W+ n* u! Y7 g) W
A¡¢TC358775XBGÉè¼ÆµÄʱºòÒªÌØ±ð×¢ÒâMIPI DSIºÍLVDSµÄ×ßÏßÎÊÌ⣬Ҫ×öºÃÆÁ±ÎÒÔÃâÐźÅÊܵ½¸ÉÈÅ¡£
% \$ O/ ?3 `; x% R2 v6 x5 OB¡¢×¢ÒâµçÔ´Â˲¨
6 w s4 W8 O3 @. W! B/ a5 WC¡¢´ËоƬ²»ÊÇ´¿Ó²¼þµÄоƬ£¬ÐèҪͨ¹ýIIC»òÕßMIPI COMMANDÀ´¸øÐ¾Æ¬Ð´¼Ä´æÆ÷ÅäÖ㬵«ÊÇÒ»°ãʹÓÃIIC£¬Èç¹û¿Í»§ÏëʹÓÃmipi command½øÐгõʼ»¯µÄ»°½¨ÒéÔ¤ÁôIIC×ÜÏß¡£
3 C \) I3 D9 m% D0 ID¡¢775Ò»°ãÊÇ×öÔÚϵͳ°åÉÏÃæµÄ£¬²¢ÇÒÔÚ³õʼ»¯Ö®Ç°Ò»°ã¶¼ÒªÇóÏȸ´Î»£¬Òò´Ë½¨Òé¿Í»§ÓÃÖ÷¿ØIO¿ØÖƸ´Î»½Å£¬ÒÔ·½±ã¿ØÖÆÊ±Ðò¡£
& t( V& g6 e( l; p, F1 CÔÚϵͳ°åÉÏÃæµÄ£¬²¢ÇÒÔÚ³õʼ»¯Ö®Ç°Ò»°ã¶¼ÒªÇóÏȸ´Î»£¬Òò´Ë½¨Òé¿Í»§ÓÃÖ÷¿ØIO¿ØÖƸ´Î»½Å£¬ÒÔ·½±ã¿ØÖÆÊ±Ðò¡£ ÓÐÐèÏéϸ×ÊÁÏ»ò¹ºÂòÇëÁôÑÔ£¬¹²Í¬Ñ§Ï°£¬¹²Í¬ ½ø²½ ¡¢
% d! p. W* V7 M+ m& M* j3 Y + C. j( r# a% D- m Y
5 }7 h# B& @9 {; A3 q. A! ?
