¹Ø¼ü×Ö£ºÁªÐ¾¿Æ¼¼£¬LC1860£¬LC186x£¬Chipone Technology£¬icn6211£¬mipi bridge£¬mipi to RGB£¬mipiת»»Ð¾Æ¬£¬RGB666£¬st7789£¬st7789V2
ÁªÐ¾ 1860ƽ̨ icn6211 mipi to RGB ת»»Ð¾Æ¬ µ÷ÊÔ ºÍ st7789 LCDµ÷ÊÔspi 9bit ģʽ
ƽ̨£ºÁªÐ¾¿Æ¼¼ LC1860£¬Android4.1
±¾ÏîÄ¿LCDÆÁÄ»½éÉÜ£º±¾´Îµ÷ÊÔµÄLCD²ÉÓÃst7789v2Çý¶¯Ð¾Æ¬¡£¸ÃоƬ¼ò½é£º
The ST7789V2 is a single-chip controller/driver for 262K-color, graphic type TFT-LCD. It consists of 720 source line and 320 gate line driving circuits. This chip can directly connect to an external microprocessor, and accepts, 8-bits/9-bits/16-bits/18-bits parallel interface. Display data can be stored in the on-chip display data RAM of 240x320x18 bits. It can perform display data RAM read/write operation with no external operation clock to minimize power consumption. In addition, because of the integrated power supply circuit necessary to drive liquid crystal; it is possible to make a display system with the fewest components.
±¾ÏîÄ¿ÖвÉÓõÄMIPI to RGB bridge½éÉÜ£º±¾´Îµ÷ÊÔµÄת»»Ð¾Æ¬ÊÇicn6211,ÕâÊÇÒ»¿î½«mipiÐźÅת»»ÎªRGBÐźŵÄת»»Ð¾Æ¬¡£
¸ÃоƬ¼ò½é£º
ICN6211 is a bridge chip which receives MIPI® DSI inputs and sends RGB outputs. MIPI® DSI supports up to 4 lanes and each lane operates at 1Gbps maximum; the totally maximum input bandwidth is 4Gbps; and the MIPI defined ULPS(ultra-low-power state) is also supported. ICN6211 decodes MIPI® DSI 16bpp RGB565 and 18bpp RGB666 and 24bpp RGB888 packets. The RGB output 18 or 24 bits pixel with pixel clock range of 5MHz to 154MHz. ICN6211 support video resolution up to FHD (1920x1080) and WUXGA(1920x1200). ICN6211 adopts QFN48 pins package. ÏîÄ¿±³¾°£º
±¾´Î²ÉÓõÄÊÇÒ»¿î240*320µÄС³ß´çLCD£¬ÕâÖÖС³ß´çLCD¶à²ÉÓÃRGB½Ó¿Ú¶ø·ÇMIPI½Ó¿Ú¡£¶øÄ¿Ç°µÄÖ÷Á÷ARM´¦ÀíÆ÷ÔÚÏÔʾ½Ó¿Ú·½Ãæ¶¼²ÉÓÃDSI£¨MIPI£©½Ó¿Ú£¬±£ÁôRGB½Ó¿ÚµÄ·½°¸Ô½À´Ô½ÉÙÁË£¬µ±Ö÷¿ØÐ¾Æ¬²»ÄÜÌṩRGB½Ó¿Úʱ£¬¾ÍÐèÒªÔÚÖ÷¿ØÐ¾Æ¬ºÍLCDÖ®¼äͨ¹ýÒ»¸öÇŽÓоƬ½øÐÐmipiµ½RGBµÄÐźÅת»»¡£±¾ÏîÄ¿¼ÈÊÇ¡£
µ÷ÊÔ£º
Ê×ÏÈ£¬±ØÐëÒªÃ÷È·ÕâÀïÓÐÁ½¸öºÚ¿Ó¡£ÈκÎÒ»¸ö¶¼»áµ¼ÖÂÎÞ·¨ÏÔʾ¡£
1. icn6211²»Í¨»áµ¼ÖÂÎÞ·¨ÏÔʾ¡£
2. LCD²»Í¨»áµ¼ÖÂÎÞ·¨ÏÔʾ¡£
ËùÒÔ£¬µ÷ÊÔ±ØÐëÒ»¸öÒ»¸öÀ´£¬¶øÇÒºÜÏÔÈ»£¬Èç¹ûÄãÏȰÑLCDÈ·Èϵ÷ͨ£¬Äã»áÉÙ×ßÍ䷵ġ£
ÐÒÔ˵ÄÊÇ£¬icn6211ºÍ»ùÓÚst7789µÄLCD¶¼ÄÜÖ§³Ö×Ô²âÊÔģʽ¡£ËùÒÔµ÷ÊԵĵÚÒ»²½¾ÍÊÇÈÃÕâ¸öLCDÏÈÄÜͨ¹ý×Ô²âÊÔģʽÏÔʾ³öÄÚÈÝ£¬ÒÔ´ËÖ¤Ã÷LCDµ÷ͨ£¬µ½ÕâÒ»²½ÄãÒѾÍê³É50%µÄ¹¤×÷£¡È»ºóÔÙµ÷ÊÔicn6211£¬µ±icn6211µÄ×Ô²âÊÔÄÜÔÚLCDÉÏÏÔʾ³öcolor barʱ£¬Ä㼸ºõ¾Í³É¹¦ÁË¡£
ÏÖÔÚ¿ªÊ¼µ÷ÊÔLCD°É£¡Éϵ磬resetÍê³Éºó£¬¾ÍÊÇÒª·¢Ò»Ð©³õʼ»¯ÃüÁîºÍ²ÎÊýÁË¡£Õâ¸öLCDÖ§³Ö8080·½Ê½ºÍSPI·½Ê½·¢ËÍÅäÖÃÃüÁ±¾´ÎÏîÄ¿²ÉÓÃSPI ½Ó¿Ú·½Ê½¡£ËäÈ»spiÓÐ4ÏßģʽºÍ3Ïßģʽ£¬µ«ÊÇ4Ïßģʽ¶ÔÈí¼þµ÷ÊÔÀ´Ëµ»á¼òµ¥Ðí¶à£¬ÒòΪÄDZϾ¹ÊDZê×¼µÄ8bitÊý¾Ý·½Ê½£¬Çý¶¯Éè¼Æ»á¼òµ¥¡£
È»¶ø£¡£¡£¡Ó²¼þÉè¼Æ´ÓÀ´¶¼²»¿¼ÂÇÈí¼þµÄ¹¤×÷Á¿£¬MLGB£¡±¾ÏîÄ¿µÄÕâ¸öLCD±»Éè¼ÆÎª3Ïßģʽ¡£´ÓÁ¬½ÓÉÏ¿´£¬Ö»ÊÇÉÙÓÃÁËÒ»¸ögpio£¬µ«ÊÇÈ´¸øÈí¼þ´øÀ´¾Þ´óµÄ¹¤×÷Á¿£¡ºÍ¸ü¶àµÄµ÷ÊÔÄѶȡ£ÔÙ´ÎMLGB£¡
˳±ã¿ÆÆÕÒ»ÏÂÉÏÃæËµµÄ4ÏߺÍ3ÏßģʽµÄ²î±ð¡£
4ÏߣºCLK£¬MISO£¬MOSI£¬D/C£¬CS¡£
È·ÇеÄ˵ÕâÆäʵÊÇ5ÌõÏß¡£ÔÚ±ê×¼µÄspi½Ó¿ÚÉ϶àÁËÒ»¸öÓÃÀ´Çø·ÖÃüÁîºÍÊý¾ÝµÄD/CÐźÅÏß¡£±ÈÈçµ±D/CΪµÍʱ±íʾMOSIÉÏÕýÔÚ´«ÊäµÄÊÇCommand£¬µ±D/CΪ¸ßʱ±íʾMOSIÉÏÕýÔÚ´«ÊäµÄÊÇData¡£
3ÏߣºCLK£¬MISO£¬MOSI£¬CS¡£
È·ÇеÄ˵ÕâÓõ½ÁË4¸ùÏߣ¡ºÍÉÏÃæµÄģʽÏà±È£¬½ö½öÊÇÉÙÁËD/CÐźš£ÄÇÔõÃ´Çø±ðÃüÁîºÍÊý¾ÝÄØ£¿ºÜ¼òµ¥£¬ÓÃspiÐÒéµÄ9bitģʽ¡£ÔÚ¸ÃģʽÏ£¬Ã¿Ò»Ö¡Êý¾Ý¾Í²»ÊÇ8bitÁË£¡¶øÊÇÐèÒª±»ÅäÖÃΪ9bit¡£È»ºóÓÃÕâ¸ö9bitµÄ×î¸ßλ±êʶÃüÁîºÍÊý¾Ý¡£½ö´Ë¶øÒÑ¡£
µÚÒ»²½£ºµ÷ÊÔst7789v2 LCD¡£ÅäÖÃspiÇý¶¯Îª9bitģʽ¡£Í¨¹ý·¢ËÍ0x04ÃüÁî»ñÈ¡st7789v2µÄchip id¡£ÈçÄܶÁµ½idÔò˵Ã÷ͨѶOK£¬Èç¹û¶Á²»µ½id£¬ËµÃ÷spiͨѶ²»Õý³££¬ÏÈÈ·ÈÏÓ²¼þµçѹºÍ²¨ÐΡ£
¼ì²éµã£º
1. ¹©µç
2. reset¶¯×÷ÊÇ·ñÕýÈ·
3. spi²¨ÐÎÊÇ·ñÕýÈ·£¬ÊÇ·ñÅäÖÃΪ9bitÁË£¬spi ͨѶģʽÊÇ·ñÕýÈ·£¨spiͨѶÓÐËÄÖÖʱÐòģʽ£©¡£
ÕýÈ·µÄ·¢ËÍ0x04ÃüÁîµÄ²¨ÐÎÊÇÕâÑùµÄ£º
Èç¹ûÄܶÁµ½id£¬Ôò¿ÉÒÔ·¢ËÍ0x11ºÍ0x29ÃüÁÆô¶¯ÏÔʾ£¬È»ºó·¢ËÍÒ»¸ö0x2cÃüÁÓÃÒÔдRAM£©£¬½Ó×Å·¢ËÍ240*320¸öÏñËØÊý¾ÝÀ´²âÊÔÏÔʾÊÇ·ñÕýÈ·¡£
×¢Òâÿ¸öÏñËØÊý¾Ý°üÀ¨3¸ö×Ö½Ú£¨R¡¢G¡¢B¸÷Ò»¸ö×Ö½Ú£© £¬Ò»°ãÇé¿öÏ£¬ÕâÒ»²½¶¼ÊÇOKµÄ¡£
µ±ÎÒÃÇÈ·ÈÏLCDÒѾ¿ÉÒÔÕý³£ÏÔʾºó£¬¾Í¿ÉÒÔµ÷ÊÔicn6211ÁË¡£Õâ¸ö±È½Ï¼òµ¥£¬¿ÉÒÔ¸´ÖÆÒ»·ÝÅäÖÃÎļþ£¬È»ºóÐÞ¸ÄϲÎÊý¼´¿É¡£ÐèҪעÒâµÄÊÇÒòΪLCD·Ö±æÂÊ̫С£¬ÎªÁË´ïµ½ÒªÇóµÄpclkƵÂÊ£¬Ó¦¸Ã½«mipiÅäÖÃΪ1 lane·½Ê½£¡ÎªÁËÈ·ÈÏicn6211¹¤×÷ÊÇÕý³£µÄ£¬×îºÃÓÃicn6211µÄI2Cͨ·ȷÈÏÏÂÊÇ·ñÄܶÁµ½¸ÃоƬµÄreg data¡£ÒòΪ¸Õ¿ªÊ¼µ÷ÊÔʱÄã¸ù±¾²»ÖªµÀͨ¹ýmipi·½Ê½È¥ÅäÖøÃоƬÊÇ·ñ³É¹¦¡£Õâʱºòi2c²Ù×÷¾Í±È½Ï·½±ãÁË£¬ÓÖÄܶÁÓÖÄÜд£¡Ë³±ã˵Ï£¬icn6211½öÖ§³Ö0x23¸ñʽ½øÐÐÅäÖᣠÈçÐèÏêϸ×ÊÁÏ»ò¹ºÂòÇëÁªÏµÕ¼Éú13530609500 Q674896689 Ô×°ÕýÆ· ¡£ÏÖ»õÓÅÊÆ
