Native Instruments Massive X v1.4.0 CE-V.R WIN
ÖØÐÂ˼¿¼¡¢ÖØÐ²¼ÏߺÍÖØÉú¡ª¡ªMASSIVE X ÊÇÒ»¸ö±êÖ¾ÐÔºÏ³ÉÆ÷µÄ¼Ì³ÐÕߣ¬Ëü°ïÖú²úÉúÁËÕû¸öÁ÷ÅÉ¡£»ñµÃ´´½¨ÈκοÉÒÔÏëÏóµÄÉùÒôËùÐèµÄÒ»ÇС£¿ìËÙÐÞ²¹¸´ÔӵķÓÉÒÔ½«ÄúµÄÏë·¨±äΪÏÖʵ¡ª¡ªÎÞÂÛËüÃÇ¿´ÆðÀ´¶àôңԶ¡ª¡ª²¢Í¨¹ý¸»ÓбíÏÖÁ¦¡¢¿ÉÑÝ×àµÄµ÷ÖÆ½«ÊÂÇé×öµÃ±ÈÄúÏëÏóµÄ¸üÔ¶¡£ÏëÒ»Ï룬²¦Í¨Ëü£¬È»ºó¶¨ÒåδÀ´µÄÉùÒô¡£
MASSIVE X ½«Í¨¹ý¶¨ÆÚÃâ·Ñ¸üÐÂÀ´·¢Õ¹¡¢ÊÊÓ¦ºÍ·¢Õ¹¡ª¡ª¼ÈÊܵ½ËüËù°ïÖú´´ÔìµÄÎÄ»¯µÄÆô·¢£¬Ò²¼¤·¢ÁËËüµÄÁé¸Ð¡£
1.4.0 ¨C 2022-05-05
•Ìí¼ÓÁËеÄä¯ÀÀÆ÷£¬°üÀ¨±êÇ©¹ýÂË¡¢Îı¾ËÑË÷¡¢ÊղؼкÍÐí¶àÆäËû¸Ä½ø
•Ìí¼ÓÁËеĵÍÒôÔöÇ¿Æ÷²åÈëЧ¹û
•ÔÚSVF¹ýÂËÆ÷ÖÐÌí¼ÓÁËеÄLP4¹ýÂËÆ÷ģʽ
•Ìí¼ÓÁË¿ØÖÆÁéÃô¶È²Ëµ¥
•Ìí¼ÓÁËÀ©Õ¹¹âÊø¡¢ÅöײºÍ³äµçËùÐèµÄ 1.4.0 °æ
•¸Ä½ø ¸ü¿ìµÄÔ¤Éè¼ÓÔØ
•KNOWN ISSUE VST3 ÔÚɨÃèÆÚ¼äÔÚ macOS É쵀 Reaper ÖбÀÀ££¨µ«ÈÔͨ¹ýÑéÖ¤£©
•ÒÑÖªÎÊÌâ Ö÷»ú×Ô¶¯»¯²ÎÊýÃû³ÆÔÚ Apple Silicon ¼ÆËã»úÉ쵀 Logic ºÍ GarageBand Öй̶¨Îª¡°Macro¡±
Rethought, rewired, and reincarnated ¨C MASSIVE X is the successor to an iconic synthesizer that helped spawn entire genres. Get everything you need to create any sound imaginable. Quickly patch complex routings to bring your ideas to life ¨C no matter how far-out they might seem ¨C and take things further than you thought you could with expressive, playable modulation. Think it up, dial it in, and define what the future sounds like.
MASSIVE X will grow, adapt, and evolve with regular free updates ¨C both inspired by, and to inspire, the cultures it helps to create.
1.4.0 ¨C 2022-05-05
•ADDED New browser which includes filtering by tags, text search, favorites and many other improvements
•ADDED New Bass enhancer insert effect
•ADDED New LP4 filter mode in SVF filter
•ADDED Control Sensitivity menu
•ADDED Version 1.4.0 required for Expansions Beam, Bump and Charge
•IMPROVED Faster preset loading
•KNOWN ISSUE VST3 crashes in Reaper on macOS during scan (but still passes validation)
•KNOWN ISSUE Host automation parameter names are fixed to ¡°Macro¡± in Logic and GarageBand on Apple Silicon computers
home page
https://www.native-instruments.com/en/products/komplete/synths/massive-x/ |
