MP3 Cutter Joiner 6.7¼òµ¥Ò×ÓõÄÒôƵ±à¼¹¤¾ß
Ò»¿î¹¦ÄÜÇ¿´ó¡¢¼òµ¥Ò×ÓõÄÒôƵ±à¼¹¤¾ß£¬¿ÉÒÔ½«ÒôƵÎļþ½øÐзָҲ¿ÉÒÔ½«¶à¸öÒôƵÎļþºÏ²¢ÎªÒ»¸öÎļþ£¬Ö§³ÖMP3¡¢WAV¡¢WMAÒÔ¼°OGG¸ñʽ£¬Ö§³ÖÅúÁ¿´¦Àí£¬Í¨¹ýÄÚÖõÄÒôƵ²¥·ÅÆ÷£¬Óû§¿ÉÒÔÔ¤ÏÈÌýÈ¡ÒôƵÎļþÈ»ºóÉèÖ÷ָô/ºÏ²¢Ê±µÄ¿ªÊ¼/½áÊøÊ±¼ä
MP3 Cutter Joiner consists of a MP3 Cutter and a MP3 Joiner. It is much easier for you to get highlights from MP3 files with MP3 Cutter function, howerver, with MP3 Joiner function, you can perfectly join many audio files into one.
Top-notch production: All MP3 files that we created with MP3 Cutter Joiner had the same quality as the original file. Producing new files was very fast, with most MP3s only taking less than 30 seconds to create.
Pleasant design: You will enjoy the plain, comfortable design of this program. There are only a handful of objects in the program window, which we found to be a streamlining aspect of MP3 Cutter Joiner
Compatibility
OS X 10.10 or later, 64-bit processor
