GiliSoft Audio Recorder Pro ¼ÒôÈí¼þ
Èí¼þ
GiliSoft Audio Recorder FreeÊÇÒ»¿îÇ¿´óµÄ¼ÒôÈí¼þ¡£ÓÐÁËËü£¬Äã¿ÉÒԼǼÉùÒô´ÓÂó¿Ë·ç£¬Ïß·ÊäÈ룬WINAMP£¬WindowsýÌå²¥·ÅÆ÷£¬Real²¥·ÅÆ÷£¬DVD²¥·ÅÆ÷£¬ÉÁ´æ£¬ÓÎÏ·²¥·ÅµÄÒôÀÖÁ÷ʽÒôƵ£¬MP3µÈ¸ñʽ¿ÉÒÔ±£´æ²¢Â¼ÖÆÉùÒô¡£
GiliSoft Audio Recorder Pro is a perfect audio recorder to record computer sounds and microphone to AAC, AC3, AIFF, AMR, AU, FLAC, M4A, M4B, M4R, MKA, MP2, MP3, OGG, RA, VOC, WAV or WMA files on Windows 7/8. Recording the sound that goes through your audio card isn¡¯t at all a difficult task, but GiliSoft Audio Recorder Pro promises to make everything a lot easier, even for those with no advanced computer knowledge.
1) Allows you to pre-define recording qualities to help quickly set and manage recording parameters.
2) Allows you to start and stop recoding automatically with built-in timer.
3) Support silence detection during audio recording.
4) Built-in advanced sound engine to produce high quality recording.
5) Allows you to preset your recording device before start record.
Audio Recorder Pro is a perfect audio recorder to record your own voice, music or any other sound by working directly with your sound card. It supports the record input/source from a microphone, streaming audio from the Internet, external input devices (e.g. CDs, LP, music cassettes, phone line etc.) as well as other applications like Winamp, Media Player, etc.
With built-in advanced audio record engine, the recorder produces high quality recordings. With Auto Record feature, you are able to schedule the time to start/stop a recording.
