Nomad Factory Analog Studio Rack Ä£¿é»¯»ú¼Ü
Analog Studio Rack ÊÇÒ»¸ö¡°Ä£¿é»¯»ú¼Ü¡±£¬ÌṩÈȲå°Î 500 ϵÁзç¸ñµÄ¾ùºâÆ÷¡¢Ñ¹ËõÆ÷¡¢ÃÅÏÞ¡¢¼¤ÀøÆ÷ºÍµç×Ó¹ÜÇý¶¯Ç°Ö÷ŴóÆ÷£»ÍêÃÀµÄ¶àºÏһͨµÀÌõ£¡
Áé¸ÐÀ´×Ô¾µäÖøÃûµÄÓ¢¹úµ÷Òǫ̂µÄÃÅÏÞ/À©Õ¹Æ÷¡¢Ñ¹Ëõ/ÏÞÖÆÆ÷¡¢×ÜÏßѹËõÆ÷ºÍ¾ùºâÆ÷¡¢¸Ä½øµÄ¼¤ÀøÆ÷¡¢µç×Ó¹ÜÇý¶¯Ç°Ö÷ŴóÆ÷ºÍÁíÒ»¸ö 1950 Äê´úÖÐÆÚÖøÃûµÄ¾ùºâÆ÷£¬AS-Rack »ã¼¯ÁËÒ»Ì× 7Ä£¿é¾¹ýרҵµ÷Õû£¬ÌýÆðÀ´ºÜÔöú¡£ÕæÕýµÄÄ£ÄâÔÚºÐ×ÓÀ
6¸öÖ÷Ҫģ¿éÖеÄÿһ¸ö¶¼¿ÉÒÔͨ¹ý¼òµ¥µÄÍÏ·ÅÒÔÈÎÒâ˳Ðò·ÅÖã¬ÈÃÄúÔÚ»ú¼Ü¿Õ¼äÉè¼ÆÖÐ×ÔÓɳ¢ÊÔ²»Í¬µÄ×éºÏ£»¾ùºâÆ÷֮ǰ»òÖ®ºóµÄѹËõÆ÷£¬Ñ¹ËéѹËõÆ÷Ö®ºóµÄÃÅ¿ØÐ§¹û¡¡ËùÓÐÕâЩÏÖÔÚ¶¼¿ÉÒÔ×Ô¶¨ÒåÄúµÄÒôµ÷ºÍÔ´ËØ²Ä£¬Ã¿¸öÄ£¿é¶¼Óи÷ÖÖÊÓͼ£¬ÓÃÓÚÔöÒæ½µµÍ¡¢ÆµÆ×ºÍ 1/3 °Ë¶ÈÒô³Ì¡£
¸Ã²å¼þ´øÓÐһϵÁÐרΪ¸÷ÖÖÀÖÆ÷Éè¼ÆµÄÔ¤Éè×÷ΪÄúµÄÆðµã¡£ÔÚÄúµÄ»ìÒôÖÐʹÓÃËüÃÇ£¬µ÷Õû£¬´´½¨Äú×Ô¼ºµÄ×÷Ϊµ¥¸öÄ£¿éÔ¤Éè»òÈ«¾Ö¡£
Analog Studio Rack is a ¡°Modular Rack¡± that provides hot-swappable 500 series style EQ¡¯s, Compressors, Gate, Exciter and a Tube Driven Pre-Amp; the perfect all-in-one channel strip!
Inspired by a classic and famous British console for its Gate/Expander, Comp/Limiter, Bus Compressor and EQ, a modified Exciter, a Tube Driven Pre-Amp and another famous mid 1950¡¯s EQ, the AS-Rack brings together a suite of 7 modules expertly tuned to sound musical. True analog in the box!
Each of the 6 main modules can be placed in any order with simple drag and drop, allowing you the freedom within a rack space design to try different combinations; Compressor before or after EQ, Gate after a crushed Compressor for effect¡ All of this is now possible to customize your tone and source material, with various views available per module for gain reduction, spectrum and 1/3 octave.
The plug-in comes with an array of presets specifically designed for various instruments as your starting point. Utilize them in your mixes, tweak, create your own as single module presets or global.
´úÂ룺
https://hot4share.com/0ni0qzkd8rj6/hzbz0.Nomad.Factory.Analog.Studio.Rack.v1.0.4.1.rar.html
Rapidgator
https://rapidgator.net/file/3fdc470b693b72d7f8763e5e517d1e47/hzbz0.Nomad.Factory.Analog.Studio.Rack.v1.0.4.1.rar.html
Uploadgig
https://uploadgig.com/file/download/bb4dda3248d6BeC4/hzbz0.Nomad.Factory.Analog.Studio.Rack.v1.0.4.1.rar
NitroFlare
https://nitro.download/view/1DD3C4576E419BD/hzbz0.Nomad.Factory.Analog.Studio.Rack.v1.0.4.1.rar |
