Permute 3.9 Multilingual MacOS¸ñʽת»»¹¤¾ß
PermuteÊÇÒ»¿îMacÉÏÒ×ÓõÄýÌå¸ñʽת»»¹¤¾ß£¬Ö§³ÖÊÓÆµ¡¢ÒôÀÖºÍͼÏñµÄ¸ñʽת»»¡£Permute¿Éͨ¹ýÍÏ×§Ö§³ÖÅúÁ¿¸ñʽת»»£¬Ö§³Ö³£¼ûµÄÊÓÆµ¡¢ÒôÀÖºÍͼÏñ¸ñʽ£¬ÈçͼƬ֧³ÖPNG¡¢JPEG¡¢TIFF£¬ÒôÀÖÖ§³ÖAAC¡¢MP3¡¢WAV¡¢M4AµÈ£¬×ª»»ËÙ¶ÈÒ²ºÜ¿ì£¬¼òµ¥ºÃÓá£
Permute is the easiest to use media converter with it¡¯s easy to use, no configuration, drag and drop interface, it will meet the needs to convert all your media files. We have completely rewritten Permute 2 from the ground up. It now detects if the original file only needs to be transcoded and if not, the track is copied, saving you a lot of time. It now also supports converting images and has improved presets across all media types.
Key features:
¨C Easy to Use ¨C Built from the ground up, Permute is a perfect example of what a Mac app should be. With a gorgeous interface and drag & drop simplicity no need for complicated options.
¨C Insanely Fast ¨C Permute was engineered to be incredibly fast. Let us take care of the hard stuff. Just select the video format you want and it¡¯ll be done faster than you can say ¡°Antidisestablishmentarianism¡±.
¨C Everything Included ¨C It doesn¡¯t matter if you¡¯re converting home movies or processing images. Permute can do it all. We support nearly every format and have plenty of device presets to choose from.
Easy to Use
Insanely Fast
Everything Included
Requirements: OS X 10.11 or later, 64-bit processor. |
