Native Instruments Komplete Kontrol 2.7.0 WIN
KOMPLETE KONTROL ÊÇÒ»¸öÒ×ÓÚʹÓõŤ¾ß£¬¿ÉÒÔÇåÀíÄúµÄ¹¤×÷Á÷³Ì¡£Ëü¿ÉÒÔ×éÖ¯ÄúµÄËùÓÐÀÖÆ÷¡¢Ð§¹û¡¢Ô¤É衢ѻ·ºÍÑù±¾£¬ÖÇÄܵؽ«ËùÓÐÄÚÈÝÓ³Éäµ½ÄúµÄÓ²¼þ£¬ÒÔ±ãÄú¿ÉÒÔÔÚÒ»¸öµØ·½²éÕÒ¡¢²¥·ÅºÍµ÷ÕûËùÓÐÉùÒô¡£Õâ¸öÃâ·ÑµÄ²å¼þ¿ÉÒÔÔÚÈκΠDAW ÖÐÔËÐУ¬²¢ÇÒ¿ÉÒÔÓëÈκΠMIDI ¿ØÖÆÆ÷»òÄú¿ÉÐÅÀµµÄÊó±êºÍ¼üÅÌÎÞ·ìÐ×÷¡£
Ö±¹ÛµÄ¼¯³ÉÖÐÐÄ
¨C ʹÓÃÒ»¸öÇ¿´óµÄÃâ·Ñ²å¼þ½«ÄúµÄËùÓÐÀÖÆ÷¡¢Ð§¹û¡¢Ñ»·ºÍÑù±¾½áºÏÆðÀ´
¨C ä¯ÀÀ¡¢µ÷ÕûºÍÔ¤ÀÀÄúµÄËùÓÐÉùÒô
¨C ʹÓà Smart Play ÇáËÉÑÝ×àÊý°ÙÖÖÒô½×¡¢ºÍÏÒ¡¢ÅÃÒôµÈ
¨C ½«ËùÓÐÄÚÈÝÍêÃÀµØÓ³Éäµ½ KOMPLETE KONTROL ¼üÅÌ¡ª¡ªÆäËû¿ØÖÆÆ÷¿ÉÒÔÔÚ¼¸ÃëÖÓÄÚÍê³ÉÉèÖÃ
ƽ̨£ºWiN64 ¨C EXE/VST/AAX£¨Ð޸ģ©
ʲôÊÇеÄ
Ìí¼ÓÁË VST3 ²å¼þÄ¿±ê
ÔÚ Ableton Live ÖвüôµÄ FIXED VST ²å¼þ UI
¹Ì¶¨¼üÅÌ¿ì½Ý¼ü Enter£¨½ÓÊÜ/È·ÈÏ£©ºÍ Esc£¨È¡Ïû£©ÔÚ Windows Éϲ»Æð×÷ÓÃ
ÒÑÒÆ³ýÔÚä¯ÀÀÆ÷ÖÐ×Ô¶¯ÏÂÔØ Sounds.com ÄÚÈÝ
KOMPLETE KONTROL is a easy-to-use tool that cleans up your workflow. It organizes all your instruments, effects, presets, loops, and samples, smartly mapping everything to your hardware so you can find, play, and tweak all your sounds in one place. This free plug-in runs in any DAW and works seamlessly with any MIDI controller ¨C or your trusty mouse and keyboard.
INTUITIVE INTEGRATION HUB
¨C Unite all your instruments, effects, loops, and samples with one powerful, free plug-in
¨C Browse, tweak, and preview all your sounds
¨C Easily play hundreds of scales, chords, arpeggios, and more with Smart Play
¨C Maps everything perfectly to KOMPLETE KONTROL keyboards ¨C and other controllers can be set up in seconds
Platform: WiN64 ¨C EXE/VST/AAX(MODiFiED)
Whats New
ADDED VST3 plug-in target
FIXED VST plug-in UI cropped in Ableton Live
FIXED Keyboard shortcuts Enter (accept / confirm) and Esc (cancel) not working on Windows
REMOVED Automatic download of Sounds.com content in Browser
Homepage
https://www.native-instruments.com/en/products/komplete/bundles/komplete-kontrol/
