3delite DS WASAPI ASIO Router Mixer 1.0.88.194 WINÒôƵÊä³ö·ÓÉÆ÷
DS WASAPI ASIO ·ÓÉÆ÷»ìÒôÆ÷ÊÇÒôƵÊäÈëµ½ÒôƵÊä³ö·ÓÉÆ÷/»ìÒôÆ÷£¬Ö§³Ö Direct Sound¡¢WASAPI ºÍ ASIO ģʽ¡£ÈκÎÀàÐͺÍÊýÁ¿µÄÒôƵÊäÈë¶¼¿ÉÒÔͨ¹ý¾ØÕó»ìºÏ¡¢VST DSP ²å¼þÖ§³Ö¡¢11 ¶Î¾ùºâÆ÷ºÍ¼ÒôÑ¡Ïî·Óɵ½ÈκÎÀàÐ͵ÄÒôƵÊä³ö¡£ ASIO Êä³ö»ìÒôÆ÷¿ÉÑ¡¶àỊ̈߳¬ÒÔͨ¹ý DSP ʵÏָ߷ֱæÂÊ 96/192KHz Êä³öµÄ×îµÍÑÓ³Ù¡£¾ùºâÆ÷¡¢¾ØÕó»ìÒôºÍ VST DSP ÓÐÒ»¸öÔ¤ÉèϵͳÀ´´æ´¢ºÍµ÷ÓÃÉèÖᣠDS WASAPI ASIO Router Mixer ¿ÉÒÔʹÓÃÉÏ´ÎʹÓõÄÉèÖÃ×Ô¶¯Æô¶¯ Windows¡£
ʹÓà DS WASAPI ASIO ·ÓÉÆ÷»ìÒôÆ÷µÄ»ù±¾²½Öè
ÔÚ´°¿ÚµÄÖÐÉϲ¿Ñ¡ÔñÒ»¸öÊä³öÉ豸¡£ÔÚÓÒ²àÉèÖÃËùÐèµÄ¸ñʽ£¬È»ºóµ¥»÷¡°ÆôÓ᱿ª¹Ø¡£Èç¹û¸ùÒѾ³õʼ»¯£¬Ôò ASIO ͨµÀ¶Ô¼Ì³Ð¸ùÉ豸µÄ²ÎÊý£¬Èç¹ûûÓУ¬Ôò½«Ê¹ÓøöԵÄÉèÖÃÀ´³õʼ»¯¸ùÉ豸£¬Òò´ËÈç¹ûÐèÒª£¬ÇëÏÈΪ¸Ã¶ÔÉèÖøù²ÎÊý¡£
ÔÚ´°¿ÚµÄ×ó²àÑ¡ÔñÒ»¸öÊäÈëÉ豸¡£ÔÚÓҲࣨÕû¸ö´°¿ÚµÄÖÐÐÄ£©Ñ¡ÔñÊäÈëËùÐèµÄ¸ñʽ£¬È»ºóµ¥»÷¡°ÆôÓ᱿ª¹Ø¡£Ñ¡¶¨µÄÊäÈëÉ豸½«¿ªÊ¼ÔÚÏÈǰѡ¶¨µÄÊä³öÉ豸Éϲ¥·Å¡£ÊäÈëÉ豸ʼÖÕͨ¹ý×îºóÑ¡ÔñµÄÊä³öÉ豸ÆôÓ᣿ÉÒÔΪ 1 ¸öÊä³öÉ豸ÆôÓöà¸öÊäÈëÉ豸£¬µ«Ò»¸öÊäÈëÉ豸½öÖ§³Ö 1 ¸öÊä³ö£¬µ«ÔÚÊäÈëÉ豸ѡÏîÃæ°åÖУ¬¿ÉÒÔ£¨Ôڵײ¿£©Ö¸¶¨ÁíÒ»¸ö¡°¼àÊÓÆ÷¡±Êä³öÉ豸£¬ÕâÐèҪ֮ǰÆôÓã¬ÕâÒ²½«²¥·ÅÑ¡¶¨µÄÊäÈëÉ豸¡£
Òª·ÃÎʵײ¿µÄ 3 ¸ö FX£¬Çë´ÓÁбíÖÐÑ¡ÔñÒ»¸öÊäÈë»òÊä³öÉ豸¡£×îºóÑ¡ÔñµÄÊäÈë»òÊä³öÉ豸½«Êܵ½Ó°Ï졣ϲ¿Ãæ°åµÄ×é¿ò±êÌâÏÔʾµ±Ç°Ñ¡¶¨É豸µÄÃû³Æ£¨ÊäÈë»òÊä³ö£©¡£
ÀýÈ磬Ҫ½«¾ùºâÆ÷Ó¦ÓÃÓÚÉ豸£¬ÇëÉèÖà EQ ¹ì¼£Ìõ²¢µ¥»÷¡°ÆôÓᱡ£µ±È»£¬²ÎÊýÒ²¿ÉÒÔËæÊ±¸ü¸Ä¡£
ASIO ͨµÀ¶Ô´Ó¸ùÉ豸½ÓÊÕÒôƵÊý¾Ý£¬Òò´ËÔÚ¸ùÉ豸ÉÏÉèÖÃÈκÎЧ¹û£¬ÈçÒôÁ¿»ò EQ¡¢VST DSP ¶¼»áÓ°ÏìËùÓÐͨµÀ¶Ô¡£Çë×¢Ò⣬´ó¶àÊý VST DSP ²å¼þ½öÖ§³ÖÁ¢ÌåÉù£¬Òò´Ë 1/2 ÒÔÍâµÄͨµÀ¿ÉÄܲ»ÊÜÓ°Ïì»ò¾²Òô£¬ÔÚÕâÖÖÇé¿öÏ£¬ÇëÔÚͨµÀ¶ÔÉÏÉèÖà VST DSP¡£
DS WASAPI ASIO Router Mixer is an audio input to audio output router/mixer with support of Direct Sound, WASAPI and ASIO modes. Any type and number of audio inputs can be routed to any type of audio output with matrix mixing, VST DSP plugin support, 11 band equalizer and recording option. ASIO output mixer is optionally multi-threaded to achieve lowest possible latency for high resolution 96/192KHz output with DSPs as well. Equalizer, matrix mixing and VST DSPs have a preset system to store and recall settings. DS WASAPI ASIO Router Mixer can start automaticaly with Windows with last used settings.
Basic steps for using DS WASAPI ASIO Router Mixer
In the upper-center part of the window select an output device. To the right set the desired format and click the ¡®Enable¡¯ switch. ASIO channel pairs inherit the root device¡¯s parameters if the root is already initialized, if it is not, the pair¡¯s settings will be used to initilize the root device, so set the root parameters first if needed for the pairs.
In the left part of the window select an input device. To the right (center of the entire window) select the input¡¯s desired format and click the ¡®Enable¡¯ switch. The selected input device will start playing on the previously selected output device. The input device is always enabled through the last selected output device. It¡¯s possible to enable multiple input devices for 1 output device, but only 1 output is supported for an input device, but in the input device options panel it¡¯s possible (at the bottom) to specify another ¡®monitor¡¯ output device, that needs to be enabled previously, that will play the selected input device too.
To access the 3 FXes at the bottom select an input or output device from the list. The last selected input or output device will be affected. The lower panel¡¯s groupbox caption displays the currently selected device¡¯s name (input ot output).
For example to apply an equalizer to the device, set the EQ track bars and click on ¡®Enable¡¯. Of course the parameters can be changed on the fly too.
ASIO channel pairs receive audio data from the root device, so setting any effect, like volume or EQ, VST DSP, on the root device will affect all the channel pairs. Note that most VST DSP plugins support only stereo, so other then 1/2 channel might be unaffected or muted, in this case set the VST DSPs on the channel pairs.
