iZotope Music Production Suite Pro 2021.12 CE-V.R Rev2 WIN Ч¹ûÆ÷
ÒôÀÖÖÆ×÷Ì×¼þרҵ°æ
Äúϲ°®µÄËùÓй¤¾ß£¬Ê¼ÖÕ±£³Ö×îÐÂ״̬
Ò»Ì×רҵµÄÒôÆµÖÆ×÷¹¤¾ß£¬¿É°ïÖúÄúΪ¿Í»§Ìṩ×î¸ßÖÊÁ¿µÄÉùÒô¡£
ÊÕÌýÒôƵµÄ²å¼þ¡­
ºÍ±Ë´Ë
Music Production Suite Pro ÊÇΨһһ¿îʹÓà AI Çý¶¯´¦ÀíµÄÒôƵ²å¼þ¶©ÔÄ£¬Îª»ìÒôµÄÿ¸ö²½ÖèÌṩ×Ô¶¨ÒåÆðµã£¬´Ó·ÖÅä»ìÏìµ½Ìí¼Ó×îÖÕµÄĸ´øÈóÉ«¡£Í¨¹ý²å¼þ¼äͨÐÅ£¬ÄúµÄ iZotope ²å¼þ¿ÉÒÔÏ໥ñöÌýÒÔ¼ì²âÒô¹ìºÍÈËÉùÖ®¼äµÄÑڱΣ¬°ïÖú½¨ÒéµçƽƽºâÉèÖã¬ÉõÖÁÈÃÄúÔÚÊÓ¾õ¿Õ¼äÖлìºÏÒô¹ì¡£
ÀïÃæÓÐʲô
Êʺϸ÷ÖÖ³¡ºÏµÄ EQ
Neutron µÄÊÖÊõʽ¾ùºâÆ÷¿É°ïÖúÄúµñ¿ÌÒô¹ì²¢È¥³ýÑڱΡ£ Nectar µÄ EQ »á¸ú×ÙÄúÈËÉùµÄг²¨£¬ÈÃÄú´´Ôì¶ÀÌØµÄÒôµ÷¡£ Ozone µÄ EQ ¿ÉÒÔÔÚ Mid/Side Öй¤×÷£¬ÒÔ»ñµÃ¸ü´óµÄÊÖÊõÁé»îÐÔ¡£
ÏÖ´úºÍ¸´¹ÅµÄ¶¯Ì¬
ʹÓà Nectar µÄ Compressor ÖеÄËÄÖÖ¿ÉѡģʽºÍ Ozone µÄ Dynamics ²å¼þѹËõ¶à¸öƵ¶ÎÖеÄÀÖÆ÷¡£Ê¹Óà Nectar Compressor µÄËÄÖÖ¿ÉѡģʽΪÈËÉùÌí¼Ó¾­µäµÄ³å»÷Á¦ºÍÄÜÁ¿¡£
רҵµÄĸ´ø¹¤¾ß
ʹÓà Ozone µÄ Maximizer ºÍ Vintage Limiter ÈÃÄúµÄ»ìÒô±£³Ö¾ºÕùÁ¦£¬ÈÃÄúÔÚ²»ÎþÉü¶¯Ì¬µÄÇé¿öÏ¿ìËÙÔö¼ÓÏì¶È¡£
´´ÐºÍÏÖ´úµÄ DSP
ʹÓà Spectral Shaper ºÍ Low-End Focus µÈרҵ¹¤¾ß½â¾ö²»¿ÉÄܵĻìÒôÎÊÌ⡣ʹÓûùÓÚÄ¿±êµÄ´¦Àí£¬Í¨¹ý Neutron Sculptor ÇáËɵØÎªÄúµÄÀÖÆ÷Ôö¼Ó³å»÷Á¦ºÍÇåÎú¶È¡£
ÐÞ¸´ÍêÃÀÅÄÉã
ʹÓà 10 ¶à¸öÓÃÓÚÒôƵÐÞ¸´µÄ RX ²å¼þ£¬´Ó³£¼ûµÄÒôƵÎÊÌ⣨ÈçÔëÒô¡¢ßÇàªÉùºÍÆäËûαӰ£©Öб£´æÄúµÄƬ¶Î¡£
°üÀ¨£º
ÖÐ×Óרҵ°æ v3.8.0
³ôÑõרҵ°æ v9.11.0
RX Pro for Music v9.2.0
»¨ÃÛרҵ°æ v3.6.1
ÐýÂÉ v5.1.1
ÖÐ¼Ì v1.2.1
ÊÓ¾õ»ìÒôÆ÷ v3.7.0
Neoverb רҵ°æ v1.1.0
Òôµ÷ƽºâ¿ØÖÆ Pro v2.4.0
VocalSynth Pro v2.4.1
¶´²ìרҵ°æ v2.2.0
rev.2 ¨C RX ¸üе½ v9.2.0
All the tools you love, always up to date
A suite of professional audio production tools to help you deliver the highest quality sound to your clients.
Plug-ins that listen to your audio¡­
and to each other
Music Production Suite Pro is the only audio plug-in subscription that uses AI-powered processing to give you a customized starting point for every step of the mix, from assigning reverb to adding the final mastering polish. With inter-plugin communication, your iZotope plug-ins listen to each other to detect masking between your tracks and vocals, help suggest level balance settings, and even let you mix your tracks in a visual space.
What¡¯s Inside
EQ for every occasion
Neutron¡¯s surgical EQ helps you sculpt your tracks and remove masking. Nectar¡¯s EQ tracks the harmonics of your vocal to let you create unique tones. Ozone¡¯s EQ can work in Mid/Side for even more surgical flexibility.
Modern and vintage dynamics
Compress instruments in multiple bands with the four selectable modes in Nectar¡¯s Compressor and in mid/side with Ozone¡¯s Dynamics plug-in. Add classic punch and energy to vocals with Nectar Compressor¡¯s four selectable modes.
Professional mastering tools
Keep your mixes competitive with Ozone¡¯s Maximizer and Vintage Limiter, letting you quickly add loudness without sacrificing dynamics.
Innovative and modern DSP
Fix impossible mix problems with specialized tools like Spectral Shaper and Low-End Focus. Use target-based processing to easily add impact and clarity to your instruments with Neutron Sculptor.
Repair the perfect take
Save your takes from common audio issues like noise, clicks, and other artifacts with 10+ RX plug-ins for audio repair.
included:
Neutron Pro v3.8.0
Ozone Pro v9.11.0
Nectar Pro v3.6.1
Melodyne v5.1.1
Relay v1.2.1
Visual Mixer v3.7.0
Neoverb Pro v1.1.0
Tonal Balance Control Pro v2.4.0
Insight Pro v2.2.0
rev.2 ¨C RX updated to v9.2.0
home page
https://www.izotope.com/en/shop/ ... te-pro-monthly.html
