iZotope RX 9 Audio Editor Advanced v9.2.0 MacOS ìî³ýÔëÒô¹¤¾ß
Êܵ½¶¥¼¶ºóÆÚÖÆ×÷¹¤³ÌʦµÄÐÅÀµ£¬¿ÉÒÔ¿ìËÙ¿É¿¿µØÌṩ¸É¾»µÄÒôƵ
ÔÚ°æ±¾ 9 ÖУ¬ÎÒÃÇÌí¼ÓÁËÐÂÌØÐԺ͹¦ÄÜÀ´½â¾öµ±½ñºóÆÚÏîÄ¿ÖдæÔÚµÄһЩ×î³£¼ûµÄÐÞ¸´ÎÊÌ⣬ʹÆä³ÉΪÒôƵºóÆÚÖÆ×÷µÄ×îÖÕÑ¡Ôñ¡£
ÊÖÊõÔëÒôÈ¥³ý
ʹÓø÷ÖÖÑ¡Ôñ¹¤¾ßÀ´Ñ±·þ¡¢Ìæ»»»òÍêÈ«Ïû³ýÈκβ»ÐèÒªµÄÔëÒô¡£
ÔÚ DAW »òÓ¦ÓóÌÐòÖй¤×÷
RX ´øÓÐÒ»×é¶à¹¦ÄܵIJå¼þºÍÓ¦ÓóÌÐòÄ£¿é£¬ÓÃÓÚ´¦ÀíÎËÎËÉù¡¢Ï÷²¨¡¢ÔëÒôµÈµÈ¡£
ÖÇÄܼӹ¤
ͨ¹ý»úÆ÷ѧϰºÍ¸¨Öú¼¼Êõ£¬RX ¿ÉÒÔÊÕÌýÄúµÄÒôƵ²¢Á¢¼´ÌṩÐÞ¸´»ò¸Ä½ø½¨Òé¡£
RX 9 ÓÐʲôй¦ÄÜ£¿
ÐÂËã·¨£¡
ÈÃÄãµÄ¶Ô»°ÉÁÒ«
ÔÚ Dialogue Isolate ÖÐʹÓÃÐ嵀 iZotope »úÆ÷ѧϰ£¬´Ó·ÇƽÎȵı³¾°ÔëÒôÖÐÌáÈ¡¸É¾»µÄ¶Ô»°£¬ÀýÈçÈËȺ¡¢½»Í¨¡¢½Å²½Éù¡¢ÌìÆø»òÆäËû¾ßÓи߶ȿɱäÌØÕ÷µÄÔëÒô¡£
ÐÂģʽ£¡
˲¼äÏû³ýÎËÎËÉù
ÔÚ De-hum ÖÐʹÓÃÐµĶ¯Ì¬Ä£Ê½¿ÉÒÔ°²È«µØÏû³ýÈκÎÊýÁ¿µÄÎËÎËÉù¡¢ÁåÉù¡¢ÎËÎËÉù»ò¸ÉÈÅ£¬¶ø²»»á³öÏÖαӰ»òÓ°ÏìÒôƵÖÊÁ¿¡£
ÐÂģʽ£¡
Ô˶¯Ê¹³¡¾°èòèòÈçÉú
ʹÓà Ambience Match ÖеÄи´ÔÓģʽ½«¶Ô»°ºÍ ADR ¼ô¼ÓëÕæÊµµÄ±³¾°Ô˶¯ºÍÎÆÀíÎÞ·ìÁ¬½Ó¡£¿ìËÙÆ¥ÅäǰËùδÓеķÕΧ£ºº£Ñó¡¢·ç¡¢½»Í¨¡¢ÈËȺµÈµÈ£¡
RX 9 ÖеŤ×÷Á÷³ÌÔöÇ¿
»Ö¸´Ñ¡Ôñ
½«ÒôƵѡÔñ»Ø¹öµ½ÀúÊ·¼Ç¼ÁбíÖеÄÈκÎÉÏÒ»²½£¬ÒÔ´ÓÈκÎʱ¼äµã»ñµÃ×î¼Ñ×éºÏÒôƵ´¦Àí¡£
ÓÃÓÚ Logic Pro µÄƵÆ×±à¼Æ÷ ARA
ʹÓÃÐÂµÄÆµÆ×±à¼Æ÷ ARA Ö±½ÓÔÚ Logic ÖÐÇå³ýÈκβ»ÐèÒªµÄÉùÒô¡£Ñ¡ÔñÔëÒô²¢µ¥»÷һϼ´¿É½«ÆäÏû³ý¡£
¿ÉÀ©Õ¹µÄÀúÊ·Ãæ°å
ÐèÒª²é¿´ 5 ²½ÒÔÉϵij·ÏúÀúÊ·£¿Ã»ÎÊÌâ¡£¿ÉÀ©Õ¹µÄÀúÊ·¼Ç¼ÁбíÏÖÔÚ×î¶àÏÔʾ 30 ¸ö×îºóµÄ³·Ïû²½Ö裬ÎÞÐè¹ö¶¯¼´¿É¿ìËٲο¼¡£
´Ë°æ±¾µÄй¦ÄÜ£º
iZotope RX v9.0.1
ÐÂÌØÐÔ
¿ÉÀ©Õ¹µÄÀúÊ·Áбí
»Ö¸´Ñ¡Ôñ
ÓÃÓÚ Logic Pro µÄƵÆ×±à¼Æ÷ ARA ²å¼þ
¸Ä½ø
·ÕΧƥÅä¸üÐÂ
Ïû³ýÎËÎËÉù¸üÐÂ
¶Ô»°¸ôÀë¸üÐÂ
ϵͳҪÇó
macOS Mojave (10.14.6) ¨C macOS Big Sur (11.6)
Trusted by top post production engineers to quickly and reliably deliver clean audio
With version 9, we¡¯ve added new features and functionality to address some of the most common repair problems that exist in today¡¯s post projects, making it the definitive choice for audio post production.
Surgical noise removal
Use a variety of selection tools to tame, replace, or completely remove any unwanted noise.
Work in the DAW or the app
RX comes with a versatile set of plug-ins and app modules to deal with hum, clipping, noise and much more.
Intelligent processing
With machine learning and assistive technology RX can listen to your audio and instantly offer suggestions to fix or improve it.
What¡¯s new in RX 9?
NEW ALGORITHM!
Let your dialogue shine
Using new iZotope machine learning in Dialogue Isolate, extract clean dialogue from non-stationary background noise such as crowds, traffic, footsteps, weather, or other noise with highly variable characteristics.
NEW MODE!
Instantly eliminate hum
Use the new Dynamic mode in De-hum to safely remove any amount of hum, ring, buzz, or interference without artifacts or affecting the quality of the audio.
NEW MODE!
Movement brings scenes to life
Seamlessly connect dialogue and ADR cuts with real background movement and textures with the new Complex mode in Ambience Match. Quickly match ambiences never before possible: ocean, wind, traffic, crowds, and more!
Workflow enhancements in RX 9
Restore Selection
Roll back an audio selection to any previous step in the History list to get the best combined audio processing from any point in time.
Spectral Editor ARA For Logic Pro
Clean up any unwanted sounds directly in Logic using the new Spectral Editor ARA. Select the noise and remove it with a single click.
Expandable History Pane
Need to view more than 5 steps of undo history? No problem. The expandable History list now shows up to 30 of the last undo steps for quick referencing without scrolling.
Whats new in this version:
iZotope RX v9.0.1
New Features
Expandable History List
Restore Selection
Spectral Editor ARA Plug-in for Logic Pro
Improvements
Ambience Match updates
De-hum updates
Dialogue Isolate updates
System Requirements
Homepage
https://www.izotope.com/en/products/rx.html
