Ableton Live 10 Suite 10.1.41 WiN MacOSX
Ableton Live 10 Suite 10.1.41 WiN MacOSX& S8 z' s" _2 B' y
+ T! |/ f" h+ a. P- o3 }' |3 _) a1 B- l0 P. Z6 w5 d
& Q8 p3 f4 [; n8 H4 o$ l: L- y
Ableton Live Suite 10.x Multilingual| WIN 1.64 GB / MAC 2 GB
( Z! N& C" |' L5 z8 {
+ ]- Q7 `( C9 I  a+ V7 W7 yOS X 10.11.6 or later (see compatibility notes on macOS Mojave here)
8 E( O  o; }" R& G5 @Intel® Core™2 Duo processor. Intel® Core™ i5 processor or faster recommended.
2 i; J4 d. K! W- h; @4 GB RAM (8 GB or more recommended)
9 I8 |1 n* B, B6 |Live is fast, fluid and flexible software for music creation and performance. It comes with effects, instruments, sounds and all kinds of creative features¡ªeverything you need to make any kind of music. Create in a traditional linear arrangement, or improvise without the constraints of a timeline in Live¡¯s Session View. Move freely between musical elements and play with ideas, without stopping the music and without breaking your flow.3 P+ L+ N. M. I- F; U0 B
0050bedc_medium.jpg , e* K4 x' B9 s4 R$ V# k
What¡¯s New in Ableton Live Suite 10:
- F7 \* F: Q9 Q' y3 G( R" S4 U; D8 E% k9 J( @% F5 g
Create with new devices
) B/ W1 E* t% N8 m: G+ JMeet Wavetable, Echo, Drum Buss and Pedal: new devices that mean colorful new sounds are possible with Live¡¯s instruments and effects., E0 {2 K% C) O: }& ~" [0 p4 C
" X* Z1 U: s* H+ Q# m7 g4 v) {
Stay in the flow
  P2 g6 p9 \) I) R* w4 G% j+ E) LYou¡¯ll find improvements to Live that help you stay in the flow at every stage of your creative process, whether you¡¯re getting ideas down, organizing your setup or editing the details of your music.) e' a5 }$ u) I8 X& @6 f
% o1 [: L; k! S/ |0 V
Do even more from Push
# G) R$ _! |) ~8 A$ K4 HLive 10 brings new functionality and new high-res visualizations to Push. Now you¡¯ll spend even less time with the computer¡ªwhether you¡¯re composing ideas, editing MIDI or shaping and mixing sounds.
. k: V- M: x& G# P" ?9 z9 R, z/ v: E
New library of sound
$ }' r, b# P6 S9 m8 Y1 cWith new collections of Packs, Live 10 has more sounds that are ready for finished music, right out of the box. They¡¯re set up for tweaking to your needs or taking in different directions. Plus the library has been reorganized to make it easier to find what you¡¯re looking for.
7 f0 \) b, {% B. M; Z3 X8 G
6 r7 T7 r* ]6 q, }1 qMax for Live ¨C no limits, built in
  [1 o4 c, Q' m1 gMax technology is now fully integrated into Live 10 Suite. No additional download or set up is required to create with and customize Max For Live devices. They just work. Plus new devices and capabilities bring more possibilities for musicians and device developers.
% c' k9 g! ^  [) N& x* ?% E7 F9 _
Home Page ¨C https://www.ableton.com
( h4 ]- ~* _  u
. L6 x8 H$ s: R; C. D
