Audiority Polaris v1.8.1 WIN OSX »ìÏì²å¼þ
±±¼«ÐÇÊÇÒ»¸ö»ØÉù/»ìÏì²å¼þ£¬Áé¸ÐÀ´×Ô70Äê´úºóÆÚµÄÔçÆÚÓ²¼þÊý×Ö»ìÏì(ÈçUrsa Major SST-282)£¬Äܹ»Ìṩ»ØÉù£¬·ÕΧºÍ»ìÏìµÄµ¥Ò»¶àtapÑÓ³ÙÏß¡£µ±Ó²¼þÊý×Ö»ìÏì³öÏÖÔÚÊг¡ÉÏʱ£¬ËüÃÇÕæµÄºÜ¹ó¡£´ó¶àÊýÖÆÔìÉÌÒѾ­ÔÚ¿ª·¢Êá×´ºÍȫͨÂ˲¨Æ÷Á´(¸üƽ»¬µÄ»ìÏ죬µ«ÔÚ×ÊÔ´ºÍоƬÉ϶¼ºÜ°º¹ó)£¬»¹ÓÐÆäËû¼¼Êõ£¬°üÀ¨Ê¹Óõ¥Ò»µÄ¶àtapÑÓ³ÙÏßÀ´´´½¨ºÏÀíµÄ»ìÏ죬ͬʱ±£³Ö³É±¾¿É³ÐÊÜ¡£
Õâ¸öÏë·¨ºÜ¼òµ¥£¬µ«ºÜÇ¿´ó:Ä㽫һ´®Î´µ÷ÖÆµÄÇáÅÄ(ÔçÆÚ·´Éä)ÓëÆäÓàµÄµ÷ÖÆÇáÅÄ(À©É¢)»ìºÏ£¬´´Ôì³öÁ®¼Ûµ«ÁîÈËÐÅ·þµÄ»ìÏì¡£
ÎÒÃÇÀ©Õ¹ÁËÕâÏî¼¼Êõ£¬Ê¹»ØÉùÇû÷ÓëÀ©É¢²¿·ÖÑ­»·£¬ÔÊÐí¸ü³¤µÄ»ìÏìβ°Í¡£´ËÍ⣬Äú¿ÉÒÔÇáËɵر༭ËùÓеĵã»÷À´´´½¨Äú×Ô¼ºµÄ·¿¼äÏìÓ¦£¬¹²ÕñÊᣬ¿¨²¼Àû˹һÑùµ÷гÑÓ³ÙÏߣ¬ºÏ³ª£¬·­±ß£¬²üÒôºÍ¸ü¶à¡£
¹æ·¶
µ¥¶àµãÑÓ³ÙÏß
Pre-Delay
ÔçÆÚÓ³Ïñ(8¸ö¿É±à³ÌË®ÁúÍ·)
À©É¢(16¸ö¿É±à³Ìµ÷ÖÆË®ÁúÍ·)
Echo (Ms£¬Í¬²½£¬µ÷г£¬³¤)
»Ø²¨µ÷ÖÆ
µ÷ÖÆÌá¸ß
3Ƶ´ø·´À¡¾ùºâÆ÷
LFO (Sin/Tri/Rnd ¨C Hz£¬Í¬²½)
΢¹â
²ÉÑùÂʼõÉÙ
Á¢ÌåµÄ¿í¶È
ÅòÕÍ
v1.8.1(2021Äê7ÔÂ)
ÐÞ¸´:Ðí¿É֤ʧЧµÄº±¼ûÇé¿ö
Polaris is an echo/reverb plugin inspired by early hardware digital reverbs of the late 1970s (like the Ursa Major SST-282) and able to provide echo, ambience and reverb out of a single multitap delay line.
When hardware digital reverbs came out to the market they were really expensive. Most manufacturers were already exploiting chains of comb and allpass filters (smoother reverbs, but expensive in both resources and chips), there were other techniques involving the use of a single multitap delay line to create a reasonable reverb while keeping the cost affordable.
That idea is so simple yet powerful: you mix a bunch of unmodulated taps (Early Reflections) with the remaining modulated taps (Diffusion) to create a cheap but convincing reverb.
We extended this technique by making the Echo tap recirculating with the Diffusion section, allowing longer reverb tails. Furthermore you can easily edit all taps to create your own room responses, resonant combs, Karplus-like tuned delay lines, Chorus, Flanging, Vibrato and much more.
SPECIFICATIONS
Single Multitap Delay Line
Pre-Delay
Early Reflections (8 Programmable Taps)
Diffusion (16 Programmable Modulated Taps)
Echo (Ms, Sync, Tuned, Long)
Echo Modulation
Modulation Boost
3 Band Feedback Equalizer
LFO (Sin/Tri/Rnd ¨C Hz, Sync)
Shimmer
Sample Rate Reduction
Stereo Width
Swell
v1.8.1 (July 2021)
¨C FIX: Rare condition where licenses get invalidated
PC VST2/VST3 is unpacked from UPX-MOD for the better installer compression.
Otherwise, they are fully original binaries. AAX works in legit PT.
Audiority protection is similar to u-he (see last R2R NFO 2020-JAN). Once
legit license is leaked, other legit license can be generatable.
https://plugincrack.com/plugins/audiority-polaris/
