Tim Petherick U76 V3 Nebula 4 Library ( Skin Included )°üº¬Æ¤·ô
Tim Petherick U76 V3 Nebula 4 Library ( Skin Included ) Nebula 4 Library ( Skin Included ) |Samples, presets, patches, impulses 26.12 MB ( 8.39 MB )
U76ÏÞÖÆÆ÷µÄµÚ 3 °æ£¬Ç°Ö÷ŴóÆ÷µÄ 4 ¸ö²ÉÑùÂÊ ¸üÐÂÁËËùÓвÉÑùÂÊѹËõÆ÷ʵÀý¡£
±ÈÂÊ 4¡¢8¡¢12¡¢20ºÍËùÓа´Å¥N4 ºÍ N3 jpn Ƥ·ô
²àÁ´³ÌÐò ·¢ÉúÁË
ʲô±ä»¯£¿ÔÚ v2 ʱ£¬ÎÒ¹¹½¨ÁËÁ½ÖÖÑùʽµÄÔ¤É裬×Ô¶¯£¨Ê±¼äÏà¹Ø£©ºÍ¶¯Ì¬£¨Ó°ÏìÊÍ·Åʱ¼äµÄѹËõÁ¿£©¡£V3 ½«ÕâÁ½Õß½áºÏÆðÀ´ÒÔÌṩ¸üÕæÊµµÄÄ£Äâ¡£×÷ΪÔÚÐÇÔÆÖй¹½¨¸üºÃÄ£°åµÄÖ±½Ó½á¹û£¬V3 ¸ü¼ÓÎȶ¨¡£ÕâÈÔÈ»ÊÊÓÃÓÚ 1.3.903¡£ÎÒÏàÐÅÄã»á±ÈÒÔÍùÈκÎʱºò¶¼¸üϲ»¶Õâ¸öͼÊé¹Ý£¡£¡
ËùÓа´Å¥Ä£Ê½ÏÖÔÚ»¹¾ßÓз´Ïò·ÅµçÊÍ·ÅÌØÐÔ£¬ËüÌṩÁËÖøÃûµÄ¿ìËÙ·ÛËéÉùÒô£¡£¡£¡
ÕýÔÚʹÓà £º
´Ó²Ëµ¥ÖÐÑ¡ÔñÄúµÄ±ÈÂÊ£¬Èç¹ûÐèÒª£¬Ìí¼ÓǰÖ÷ŴóÆ÷£¡
ÔÚ comp ʵÀýºóʹÓÃǰÖ÷ŴóÆ÷
Version 3 of the U76 Limiter,
4 sample rates for preamp
Updated all sample rates compressor instance.
ratios 4, 8, 12, 20 and All buttons
N4 and N3 jpn skins
Side chain programs
What¡¯s changed? at the time of v2 I had built two styles of presets, auto (time dependence) and Dynamic (Compression amount effecting release time). V3 features both of these combined to give a truer emulation. V3 is more stable as a direct consequence of building a better template in nebula. This still works with 1.3.903. I believe you will enjoy this library more than ever!!
All buttons mode now also features an inverse discharging release character, which gives that fast crushed sound it¡¯s famous for!!!
In Use :
Select your ratio from the menu and if desired add the preamp!
USE Preamp after comp instance |
