Nembrini Audio NA Voice DC30 v1.0.2 WIN ¸´¹Å¹ýÔØ¼ªËûÏäÍ·
Voice DC30 Custom Valve Guitar Amplifier ²å¼þÒÔÀÏʽ Vox AC30 Top Boost Reverb ΪģÐÍ£¬ÆäÌØµãÊÇ¡°´Ì¶ú¡±µÄ¸ß¶ËÉùÒô£¬Òѱ»Ó¢¹úÒôÀÖ¼ÒºÍÆäËûÈ˹㷺ÈϿɡ£
Voice DC30 Custom Valve Äܹ»·¢³öÃÔÈ˵ĸɾ»ºÍÐúÄֵĹýÔØÉùÒô£¬Voice DC30 Custom µÄ±êÖ¾ÐÔÖÓÉùÓë Valve µÄ¸´ÔÓÑÝ×à·ç¸ñÎÞ·ì¶Ô½Ó£¬²úÉúÕæÕýÊôÓÚÄú×Ô¼ºµÄÉùÒô¡£
Voice DC30 ÓÐÒ»¸öµ¥¶ÀµÄÃ÷ÁÁͨµÀ¡£ÕâÊÇͨ¹ýÌí¼ÓÒ»¸öÔöÒæ¼¶ºÍÒ»¸ö¡°Òõ¼«¸úËæÆ÷¡±¼¶À´ÊµÏֵ쬴Ӷø½µµÍ×迹²¢Ìá¸ßµçÁ÷²¢Ïò¸ÃͨµÀÌí¼ÓµÍÒô/¸ßÒô¿ØÖÆ¡£
´øÓпÉÑ¡¶¥²¿ÔöÇ¿¹¦ÄܵÄÃ÷ÁÁͨµÀλÓÚÒôÁ¿¿ØÖƲ¿·ÖÖ®ºóºÍ·´ÏàÆ÷֮ǰ¡£ÕâÒâζ×ÅÄú¿ÉÒÔÔÚÊ§ÕæºóËÜÔìÉùÒô¡£
Vib-Trem ͨµÀÌṩÁ˲üÒô£¨Ò¡°ÚÒô¸ß£©ºÍ²üÒô£¨Ò¡°Ú·ù¶È£©Ö®¼äµÄÑ¡Ôñ¡£Ò»¸öÐýתµÄÈýλËÙ¶È¿ª¹Ø¿Éµ÷½Úµ÷ÖÆÂÊ¡£
CABINETS
With Voice DC30 ¶¨ÖƵç×ӹܼªËû·Å´óÆ÷¿ÉÒÔÔÚÁù¸ö²»Í¬µÄ¼ªËûÏäÌå¡¢ËĸöÂó¿Ë·çÄ£ÄâÓ뿪/¹ØÖáλÖÿª¹Ø¡¢Á¬ÐøÎ»Öú;àÀëÐýÅ¥Ö®¼ä½øÐÐÑ¡Ôñ¡£
´øÓжÀ×à¡¢¾²Òô¡¢ÉùÏñºÍÍÆ×ÓµÄÍêÕû»ìÒôÆ÷²¿·Ö¿ÉÈÃÄú½«Á½¸öÂó¿Ë·çÓë·ÕΧÈÚºÏÔÚÒ»Æð¡£
Âö³åÏìÓ¦¼ÓÔØÆ÷
Impulse Loader ¿ÉÈÃÄú¼ÓÔØ×î¶àÈý¸ö 3rd ·½Âö³åÏìÓ¦£¬Äú¿ÉÒÔʹÓÃÒôÁ¿¡¢ÉùÏñ¡¢Ïàλ¡¢¶À×àºÍ¾²Òô¿Ø¼þ½«ËüÃÇ»ìºÏÔÚÒ»Æð¡£
Ìí¼ÓÁËÒ»¸öÓÐÓõÄä¯ÀÀÆ÷´°¿Ú£¬Òò´ËÄú¿ÉÒÔÇáËÉËÑË÷ËùÓеÚÈý·½ IR Îļþ¡£
CLEANER / NOISE GATE
ÔëÉùÃŲ¿·Ö¼ÓÉÏÒ»¸ö¿É¼õÉÙ¡¡ÉùºÍ´Ì¶úÉùÒôµÄÇå½àÆ÷µç·¡£
Voice DC30 Custom Valve Guitar Amplifier plugin modeled on a vintage Vox AC30 Top Boost Reverb characterised by it¡¯s ¡°jangly¡± high-end sound it has become widely recognized by British musicians and others.
Voice DC30 Custom Valve is capable of both enchanting clean and raucous overdriven sounds, the signature chime of the Voice DC30 Custom pairs Valve seamlessly the intricacies of your playing style, resulting in a sound that is truly your own.
The Voice DC30 has a separate brilliant channel. This has been achieved by adding a gain stage and a ¡®cathode follower¡¯ stage, thereby dropping the impedance and bringing up the current and adding Bass/Treble controls to this channel.
The brilliant channel with optional top boost is placed after the volume control section and before the phase inverter. This means you can shape the sound after the distortion.
The Vib-Trem channel offered a choice between vibrato (wavering pitch) and tremolo (wavering amplitude). A rotary, three position Speed switch adjusted the the rate of modulation.
CABINETS
With Voice DC30 Custom Valve Guitar Amplifier is possible select between six different guitar cabinets, four microphone emulations with on/off axis position switch, continuous position and distance knobs.
A complete Mixer section with Solos, Mutes, Pans and Faders allow you to blend together the two microphones with the ambience.
IMPULSES RESPONSE LOADER
Impulse Loader let you load up to three 3rd-parties impulse responses, you can blend them together using volume, pan, phase, solo and mute controls.
A useful browser window has been added so you can easily search through all your third parts IR files.
Noise Gate section plus a Cleaner circuit to reduce rumbling and harsh is included.
https://plugintorrent.com/nembrini-audio-voice-dc30-custom-valve-guitar-amplifier-1-0-0-vst-vst3-aax-win-x64/
