Klevgrand Slammer v1.0.2 MacOSX ¹ÄÒôÔ´
SlammerÊÇÒ»¸ö¶à²ÉÑù¹Ä²å¼þ£¬°üº¬ 30 ÖÖ²»Í¬µÄÀÖÆ÷£¬ÕâЩÀÖÆ÷ÓÉ´óÁ¿¾«ÐÄÂ¼ÖÆºÍ±à¼µÄÑù±¾ÖƳɡ£¼¯³ÉµÄ¶¨ÖÆÊµÊ±Ð§¹ûÓëһЩÇÉÃîµÄ·ÓÉÏà½áºÏ£¬Ê¹ Slammer ³ÉΪһÖֶ๦ÄÜÇÒÁé»îµÄÐéÄâÀÖÆ÷£¬Äܹ»äÖȾ´Ó×ÔÈ»Éùѧµ½ÑÏÖØÊ§ÕæºÍѹËõµÄ¹ÄÉùµÄÈκÎÄÚÈÝ¡£Ã¿¸öÉùÒô¶¼¿ÉÒÔʹÓø÷ÖÖÉèÖýøÐÐ×Ô¶¨Ò壬ÀýÈçÒô¸ß¡¢¹ýÂË¡¢Ð§¹û·¢ËÍ¡¢Ë¥¼õʱ¼ä¡¢Á¦¶ÈÓ³ÉäµÈµÈ¡£
»¹ÓÐÒ»¸öÓÃÓÚÊ§ÕæºÍѹËõ¡¢»ìÏìºÍÒôµ÷¿ØÖƵġ°ÎÛ¹¸¡±²¿·Ö¡£¿ÉÒÔΪÿ¸öÀÖÆ÷µ¥¶Àµ÷Õû¡°ÎÛ¹¸¡±ºÍ»ìÏìµÄÊýÁ¿¡£×îÖØÒªµÄÊÇ£¬Slammer ´øÓÐÒ»×é³ö³§Ô¤É裬º¸ÇÁË´ÓÇáÈáµ½³ÁÖØºÍ¼áÈ͵ÄÈκÎÊÂÎï¡£Èç¹ûÄúÕýÔÚѰÕÒÒ»ÖÖ¹ÄÀÖÆ÷£¬´ÓµÚÒ»´Î´ò»÷¾ÍÈÃÄú¡°¼´Ê±Âú×㡱£¬¾ÍÊÇÕâÑù¡£
ÌØµã
* 30 ¸ö¶à²ÉÑùÀÖÆ÷£¬Ê¹Óó¬¹ý 2000 ¸öÑù±¾
* 12 ¸ö²å²Û/ÀÖÆ÷²¥·ÅÆ÷£¬¾ßÓе¥¶ÀµÄµ÷Õû¿ÉÄÜÐÔ
*ѹËõºÍÊ§Õæ²¿·Ö£¨ÎÛ¹¸£©¾ßÓÐ 8 ÖÖ²»Í¬µÄ dist Ëã·¨
*¾ßÓжà¸öÔ¤ÉèµÄ»ìÏì
*´óÁ¿µÄ¹¤³§Ô¤Éè
* È«¾ÖÒôµ÷¿ØÖÆ
Slammer v1.0.2 (changelog)
v1.0.2
ÓÒ»÷»ò shift µ¥»÷²å²Û»á´¥·¢ÉùÒô¡£
ÔÚ±à¼Ä£Ê½Ïµ¥»÷ÀÖÆ÷ͼÏñ»á´¥·¢ÉùÒô¡£
v1.0.1
ÏÖÔÚÔÚ´ïµ½×î´ó¸´ÒôʱÇÔÈ¡×î¾ÉµÄÒô·û¡£
ÒªÇó£º[iNTEL] + [M1] Mac OS 10.11 »ò¸ü¸ß°æ±¾
Slammer is a multi-sampled drum plug-in that contains 30 different instruments made from a large number of carefully recorded and edited samples. Integrated custom-built real-time effects combined with some clever routing makes Slammer a versatile and flexible virtual instrument that is capable of rendering anything from natural acoustic to heavily distorted and compressed drum sounds. Each sound can be customized with a wide array of settings like pitch, filtering, effect sends, decay time, velocity mapping and much more.
There¡¯s also a ¡°Dirt¡± section for distortion and compression, a reverb and tone control. The amount of ¡°dirt¡± and reverb can be tweaked individually for each instrument. On top of all, Slammer comes with a set of factory presets, covering anything from light and slick to heavy and gritty. If you¡¯re looking for a drum instrument, giving you ¡®instant gratification¡¯ from the first hit, this is it.
Features
* 30 multi-sampled instruments using more than 2000 samples
* 12 slots / instrument players with individual tweaking possibilities
* Compression and Distortion section (dirt) with 8 different dist algorithms
* Reverb with several presets
* Plenty of factory presets
* Global tone control
v1.0.2
Right- or shift clicking a slot triggers the sound.
Clicking the instrument image in edit mode triggers the sound.
v1.0.1
Now steals oldest note when max polyphony is reached.
REQ: [iNTEL] + [M1] Mac OS 10.11 or higher |
