Positive Grid BIAS FX Desktop v2.3.0.6070 Elite WIN ¼ªËûЧ¹ûÆ÷
ÏëÒª·ÃÎÊÖøÃûµÄ¾­µäºÍÏÖ´ú·Å´óÆ÷ºÍЧ¹ûÆ÷£¬¾ÍÔÚÄúµÄÖ¸¼â£¿ BIAS FX 2 ¼ªËûÈí¼þΪ Mac ºÍ PC ÌṩÁËÕâ¸öºÍ¸ü¶à¹¦ÄÜ£¬×÷Ϊֱ¹Û¡¢ÍêÈ«¿É¶¨ÖƵÄÐéÄâµç¼ªËû¡¢±´Ë¹»òÔ­Éù¼ªËû×°±¸¡£×÷Ϊ¶ÀÁ¢µÄ¼ªËûЧ¹û´¦ÀíÓ¦ÓóÌÐòÔËÐУ¬ÈÃÄú¿ÉÒÔÔÚÑÝ×à¡¢Á·Ï°ºÍ¼´ÐËÑÝ×àÖÐ×¢ÈëеÄÒôµ÷ºÍ´´ÔìÁ¦¡ª¡ªÎÞÐèÈÎºÎÆäËû¼ªËûÈí¼þ»ò DAW¡£
й¦ÄÜ£º
¨C ÐµĶ¥À¸²¼¾Ö¡£ Looper¡¢Tuner¡¢Pedalboard ÊÓͼºÍ°ïÖú¹¦ÄÜÏÖÔÚÒÆÈë¡°¹¤¾ßÏ䡱ÒÔ»ñµÃ¸üÇåÎúµÄÍâ¹Û£¬ÒÔ¼°ÐÂÌí¼ÓµÄ½ÚÅÄÆ÷¹¦ÄÜ£¬ÒÔ±ãÔÚʹÓöÀÁ¢Ó¦ÓóÌÐòʱÇáËÉÁ·Ï°¡£
-еÄÔ¤ÉèÃû³Æ²¼¾Ö¡£Ô¤Éè±»±à¼­ºó£¬¡°*¡±±ê¼Ç»á³öÏÖÔÚÔ¤ÉèÃû³ÆÖ®Ç°¡£
¨C ²å¼þ°æ±¾ÖÐɾ³ýÁË Looper ºÍ Tuner ¹¦ÄÜ¡£
¹Ì¶¨µÄ£º
-MIDI ²»ÊÊÓÃÓÚ VST3 ²å¼þ¡£
¨C BIAS FX 2²å¼þÉèÖÃÔÚÉý¼¶µ½v2.2.0»ò¸ü¸ß°æ±¾ºó²»»á±£´æÔÚStudio OneÖС£
×îµÍÒªÇó (PC)
Windows 8 »ò¸ü¸ß°æ±¾
×îµÍ 4GB RAM£¬ÍƼö 8GB »ò¸ü¶à
×îµÍ 1.5GHz Ë«ºË´¦ÀíÆ÷£¬ÍƼö 2.0GHz Ë«ºË»ò¸ü¸ß
ÒôƵ²å¼þ¸ñʽ£ºVST 2¡¢AAX Native
500MB ¿ÉÓôÅÅ̿ռ䣨64 λ°æ±¾£©
°²×° ¡ª Ìæ»»Îļþ ¡ª µÇ¼ ToneCloud ¡ª Íê³É
ÐèÒª Internet Á¬½ÓÀ´¼¤»îÄúµÄÐí¿ÉÖ¤ºÍ·ÃÎÊ ToneCloud¡£ Positive Grid Èí¼þ²úÆ·Ôݲ»Ö§³ÖÀëÏß¼¤»î¡£Èí¼þ¼¤»îºó¿ÉʹÓÃÀëÏßģʽ¡£
Ö÷Ò³£ºhttps://www.positivegrid.com/bias-fx/
Want access to famous classic and modern amplifiers and effects, right at your fingertips? BIAS FX 2 guitar software provides this and more as an intuitive, fully customizable virtual electric guitar, bass or acoustic guitar rig for Mac and PC. Works as a standalone guitar effects processing app, allowing you to inject new tones and creativity into your playing, practicing and jamming ¡ª no need for any other guitar software or DAW.
-New Top bar layout. Looper, Tuner, Pedalboard view, and Help functions now moved into the ¡°Toolbox¡± for a cleaner look, along with the newly added Metronome feature, for easy practicing when using the Standalone app.
-New preset name layout. ¡°*¡± mark shows up before the preset name when the preset has been edited.
-Looper and Tuner functions are removed from the plugin version.
Fixed:
-MIDI is not working with the VST3 plugin.
-BIAS FX 2 plugin settings are not saved in Studio One after upgraded to v2.2.0 or above.
Minimal Requirements (PC)
Windows 8 or later
4GB of RAM minimum, 8GB or more recommended
1.5GHz Dual core processor minimum, 2.0GHz Dual core or more recommended
Audio plug-in formats: VST 2, AAX Native
500MB free disk space (64-bit version)
Install ¡ª Replace files ¡ª log in to ToneCloud ¡ª Done
An Internet connection is required to activate your license and access ToneCloud. Positive Grid software products do not support offline activation at this moment. Offline mode is available after software activation.
home page: https://www.positivegrid.com/bias-fx/
https://www.4download.net/539-po ... x-full-version.html
