Take Chaos to the next level with Newfangled Audio Generate crack. Beautifully complex pads. Warm moving keys. Jittery sequenced basses. Out of control leads. Textures, oh my God textures.
create the chaos
Newfangled Audio Generate crack is based on a set of chaotic generators. What looks like randomness contains underlying patterns, interconnectedness, constant feedback loops, repetition, self-similarity, fractals, and self-organization. Each of cracked Generate¡¯s 8 chaotic generators bring out these underlying patterns and create an oscillator that can smoothly fade from a sine wave to total chaos, with an expanse of territory to explore in between. The musical textures created include distortion, harmonics, grunge, static, and noise. All of which can be predictably or unpredictably modulated.
control the chaos
Cracked Generate¡¯s chaotic generators are routed through your choice of a Buchla wavefolder, or novel Animated or Fractal wavefolders, each adding unique overtones. Followed by a low pass gate inspired by the ideas of Don Buchla. These modules combine to create a versatile and musical voice with it¡¯s own unique flavor.
modulate the chaos
Every parameter in cracked Generate¡¯s voice can be modulated by a combination of two Looping Envelope Generators, two LFOs, a Sample and Hold/Random generator, an 8 Step Sequencer, and MIDI and MPE sources. Modulators can also modulate each other for additional fun.
The innovative modulation interface allows you to easily and quickly patch any combination of sources to any destination, creating sounds that move, and which move you.
effect the chaos
Cracked Generate¡¯s voice is followed by an unparalleled EQ, Chorus, Delay, Reverb, and Limiter, all to launch your chaotic sounds into outer space or right into your listeners faces.
newfangled audio generate including presets from
Chris Tabron (Beyonc¨¦, The Strokes, Die Antwoord)
Chris Carter (Throbbing Gristle, Chris and Cosey)
Matt Lange (deadmau5, BT, Mau5trap, Anjunabeats)
Adam Schatz (Landlady)
Matthew Simms (Wire, It Hugs Back)
Jacob Bergson (Nerve, Rubblebucket, taut)
So Wylie (Gimlet, Mogul, The Habitat)
Count (Radiohead, Tycho, DJ Shadow, Zoe Keating)
Laurie Spiegel (Hunger Games, Golden Voyager Disc!)
Anthony Baldino (Interstellar, Ex-Machina, Avengers)
Jacob Shea (Planet Earth, Inception, Battleship)
ROCASound (Sting, Seal, Donna Summer, Iron Man 2)
Matthew Wang (Zoey¡¯s Extraordinary Playlist, ¡)
Symbion Project (FreQuency, Amplitude)
newfangled audio generate crack features
Novel chaotic oscillator has 8 types: Double Pendulum, Vortex, Pulsar, Discharge, Turbine, Helix, Crescent, and Magma
Wavefolders based on the Buchla 259 Complex Waveform Generator, Fractals, and a special Animated Equation
Low Pass Gate based on the Buchla 292 adds controls for POLES and RESONANCE
Modulate all controls with MIDI/MPE, two Loopable Envelopes, two LFOs, Sample and Hold/Random, and a Step Sequencer
Innovative modulation UI allows modulation over every control from the main page, including modulating modulators, allowing up to 957 simultaneous modulation routings
Innovative EQ, Chorus, Delay, Reverb, and Limiter effects to turn the sounds into magic
MPE support allows amazing control from expressive controllers
All mod sources have multiple outputs generated at once, like a modular synth should
Animations! The Double Pendulum, Wavefolder, and Low Pass Gate modules each have animations to show how each module responds to your input, and to modulation
Fully resizable UI!
Intuitive Midi Learn functionality allows you to assign MIDI CCs to any control with just a click
Color Schemes! Don¡¯t like the look of it, change it
Over 650 Presets, including many artist presets
https://plugincrack.com/plugins/newfangled-audio-generate-win/ |
