Tokyo Dawn Labs TDR Limiter 6 GE ÏÖ´ú¶¯Ì¬Ñ¹ËõºÍÏÞÖÆÆ÷²å¼þ
TDR Limiter 6 GEÊÇÒ»ÖÖÏÖ´ú¶¯Ì¬Ñ¹ËõºÍÏÞÖÆ¹¤¾ß°ü£¬¾ßÓÐÁù¸ö¿ÉÒÔ°´¿É±ä˳ÐòÅÅÁеÄרÓÃÄ£¿é¡£ËüÃÇÒ»Æðº­¸ÇÁË´Ó΢ÃîµÄÏì¶È¿ØÖƵ½²Ð¿áµÄ¡°×©Ç½¡±ºÍ´´ÔìÐԵĻìÒô×ÜÏß´¦ÀíµÈһϵÁзǷ²µÄÓ¦Óá£
Ä£¿é
¶¯Ì¬Ñ¹Ëõ»ú¡£
¿ì´¬¡£
¸ßƵÏÞ·ùÆ÷¡£
·åÖµÏÞÖÆÆ÷¡£
Êä³ö±£»¤ÏÞÖÆÆ÷¡£
ÕæÕýµÄ·åÖµºÍ EBU Ïì¶È¼Æ¡£
ÿ¸öÄ£¿é¶¼Ìṩ¶Ô²»Í¬ÀàÐÍʼþµÄרÓÿØÖÆ£¬´Óºê¹Ûµ½Î¢¹Û£¬²¢ÔÊÐíÄúÈ·¶¨ÐźÅ·¾¶¡£½«ËüÃÇÇÉÃîµØ½áºÏÆðÀ´£¬¿ÉÒÔ´ó´óÔö¼Ó»ìÒôµÄ¸ÐÖªÏì¶È£¬Í¬Ê±±£³Ö׿ԽµÄÒôÀÖ±£Õæ¶È¡¢³å»÷Á¦ºÍ´Ì¼¤ÐÔ¡£
ƾ½èÆäÒýÈËÈëʤµÄÊÓ¾õÃÀ¸Ð£¬ÏȽøµÄÕæÊµ·åÖµºÍ·ûºÏ EBU R128 µÄÏì¶È¼ÆÁ¿²¿·ÖÌṩÁ˶ÔÐźŶ¯Ì¬µÄÏêϸ¶´²ì¡£µÈÏì¶ÈÅÔ·»¹½«È·±£²Ù×÷Ô±µÄÌý¾õ²»»á±»ÈκÎÏì¶È²îÒìËùÆÛÆ­¡£
һϵÁкÏÀíµÄÆðµãÔÊÐí¿ìËÙ¶ø¾«È·µÄÏì¶È×î´ó»¯¡£Èç¹ûÐèÒª£¬¹ã·ºµÄÑ¡ÏîΪ»ñµÃ×î¼ÑÉèÖÃÌṩÁËÎÞÏ޵Ĵ´Òâ¿ÉÄÜÐÔ¡£¸ü½øÒ»²½£¬Limiter 6 »¹Ê¹²Ù×÷Ô±Äܹ»¹¹½¨Ëý¸öÈ˵ĽÓÊÕÏì¶È×î´ó»¯¡¢×ÜÏß´¦ÀíµÈµÈ¡£
¸ü¸ÄÈÕÖ¾£º
1.2.3 ά»¤¸üÐÂ
Ìí¼ÓÁ˶ÔÔ­Éú Mac Silicon µÄÖ§³Ö¡£
1.2.2 ά»¤¸üÐÂ
ÐÞ¸´ÁË HF ÏÞÖÆÆ÷ DRY WET/DRY MIX Ë«»÷²»Æð×÷ÓõÄÎÊÌâ¡£
ÄÚÁª°ïÖú²¼¾ÖÒѸüС£
¹Ì¶¨µÄÏÂÀ­²Ëµ¥ÓÐʱ²»»áÔÚµã»÷ʱ´ò¿ª¡£
ÐÞ¸´ÁËСµÄͼÐÎϸ½Ú¡£
VST3 ¸ñʽ¼æÈÝÐÔÐÞ¸´¡£
Logic 10.5 ¼æÈÝÐÔÐÞ¸´¡£
ÐÞ¸´ÁË¶àÆµ¶ÎģʽÖеĴíÎó¡£
1.2.1 ά»¤¸üÐÂ
MacOSX °²×°³ÌÐòÐÞ¸´¡£
ÉèÖãºÎªÖ÷Òª UI ÔªËØ£¨ÒÇ±í¡¢·ÖÎöÒÇ£©Ìí¼ÓÁËÖ¡ËÙÂÊ¿ØÖÆ¡£
Óû§ÊÖ²áÒÑÒÆÖÁÍøÉÏ£¨ÒÑɾ³ý pdf£©¡£
1.2.0 ά»¤¸üÐÂ
Ìí¼ÓÁË MacOS Catalina ¼æÈÝÐÔ¡£
Ìí¼ÓÁË VST3 Ö§³Ö¡£
Ìí¼ÓÁËÖØÐÂÅÅÐòµÄÏà¶ÔÔöÒæ±£Áô£¨°´×¡ cmd/alt Í϶¯¾ÉÐÐΪ£©¡£
¸Ä½øÁË GR-meter ¹ýÔØ/×Ô¶¯Ëõ·ÅÐÐΪ¡£
ÐÞ¸´ÁËÒDZíÄ£¿éÊó±êÐÐΪÖеĴíÎó¡£
¸÷ÖÖС¸Ä½ø¡£
TDR Limiter 6 GE is a modern dynamics compression and limiting toolkit featuring six specialized modules that can be arranged in variable order. Together, they cover a remarkable range of applications from delicate loudness control, to brutal ¡°brick-walling¡± and creative mix bus crunching.
Modules
Dynamics Compressor.
Clipper.
High Frequency Limiter.
Peak Limiter.
Output Protection Limiter.
True Peak and EBU Loudness Meter.
Each module offers dedicated control over different types of events, from macro to micro, and allows you to determine the signal path. Combined wisely they can greatly increase the perceived loudness of a mix while preserving superior musical fidelity, punch, and excitement.
With its appealing visual aesthetic, the advanced true peak and EBU R128 compliant loudness metering section gives a detailed insight into the signal¡¯s dynamics. The equal loudness bypass will also make sure the operators¡¯ aural perception doesn¡¯t get tricked by any loudness differences.
A collection of sensible starting points allows for quick, yet precise loudness maximization. If needed, a wide range of options offer endless creative possibilities for getting that optimal setting. Going further, Limiter 6 also enables the operator to build her personal take loudness maximization, bus processing and much more.
Changelog:
1.2.3 Maintenance update
Added support for native Mac Silicon.
1.2.2 Maintenance update
Fixed HF Limiter DRY WET/DRY MIX double-click not functioning.
Inline help layout updated.
Fixed dropdown menus occasionally not opening on click.
Fixed small graphical details.
VST3 format compatibility fixes.
Logic 10.5 compatibility fixes.
Fixed bug in multiband modes.
1.2.1 Maintenance Update
MacOSX installer fixes.
Settings: Added frame-rate control for primary UI elements (meters, analysers).
User-manual moved online (pdf removed).
1.2.0 Maintenance update
Added MacOS Catalina compatibility.
Added VST3 support.
Added relative gain preservation on reordering (hold cmd/alt on drag for the old behaviour).
Improved GR-meter overload/autoscale behaviour.
Fixed bug in meter-module mouse behaviour.
Various little improvements.
ÏÂÔØµØÖ· https://www.torrentmac.net/tokyo ... imiter-6-ge-v1-2-3/
