Line 6 Helix Native ¼ªËûЧ¹ûÆ÷²å¼þÃâ·ÑÏÂÔØ
275590
2021-6-15 12:30:45
Year / Date of Release : 06.2021
Version : 3.11
Developer : Line6 Developer
site : Line6
Format : VST, VST3, AAX * (* MODiFiED)
Bit depth : 64bit
Tablet : present / R2R
System requirements : Compatible OS: Windows 7, Windows 8, Windows 10 , VST / AAX host
ÃèÊö£ºHelix Native ÊÇÒ»¿î³ÉÊìµÄ²å¼þ¸ñʽ¼ªËûЧ¹û´¦ÀíÆ÷¡£
Helix® Native£ºÔÚ²å¼þÖÐʵÏÖ¹¦ÄÜÇ¿´óÇÒÒôÉ«ÕæÊµ¡¢ÂÅ»ñÊâÈÙµÄ HX ½¨Ä£¼¼Êõ¡£Óë Helix ϵÁмªËû´¦ÀíÆ÷µÄÓ²¼þ³ÉÔ± ¨C Helix Floor¡¢Helix Rack ºÍ Helix LT Ò»Ñù£¬Helix Native ²å¼þ¿É׼ȷÔÙÏÖ¸´¹ÅºÍÏÖ´ú·Å´óÆ÷¡¢ÏäÌå¡¢Âó¿Ë·çºÍЧ¹û£¬ÒÔ¼°ÐźÅ·ÓɺÍÖ±¹ÛµÄÓû§½çÃæ¡£ Helix Native ²å¼þ²»½öÊÊÓÃÓÚ¼ªËûÊÖ£¬»¹ÊÊÓÃÓÚÖÆ×÷È˺ÍÒôÏ칤³Ìʦ¡¢µçÓ°/µçÊÓ/ÓÎÏ·×÷Çú¼Ò¡¢µç×ÓÒôÀÖ¼ÒÒÔ¼°ÈκÎÏëÒª´´ÔìÁîÈËÐ˷ܵÄÐÂÉùÒôºÍÌØÐ§µÄÈË¡£Õû¸ö Helix ϵÁеÄÔ¤Éè¼æÈÝÐÔÔÊÐí Helix Ó²¼þÓû§Í¨¹ý¼òµ¥µØ½«Ô¤Éè´ÓËûÃǵIJå¼þ´«Êäµ½ËûÃÇµÄ Helix Floor ´¦ÀíÆ÷À´Á÷ʽ´«ÊäÔÚ¹¤×÷ÊÒÖд´½¨µÄÉùÒô
а汾
Helix Native 3.11 °üº¬¶àÏîÎȶ¨ÐÔºÍÐÔÄܸĽøÒÔ¼°´íÎóÐÞ¸´¡£Ç¿ÁÒ½¨Òé¸üС£
BugÐÞ¸´£º
С¸Ä½øºÍ´íÎóÐÞ¸´¡£
3.11 HX Stomp ÖеÄй¦ÄÜ£¬½öÏÞ HX Stomp XL ¡ª Èç¹ûδ·ÖÅä×Ô¶¨Òå±êÇ©£¬Ôòµã»÷¾ßÓжà¸ö·ÖÅäµÄµ¥¿é¿ª¹Ø½«ÏÔʾ¡°MULTIPLE [X]¡±¶ø²»ÊÇÏÔʾÆä·ÖÅä ¡ª ÒÑÐÞ¸´
3.11 HX Stomp ÖеÄй¦ÄÜ£¬½öÏÞ HX Stomp XL ¡ª Stomp ģʽ½Å̤¿ª¹Ø²»»á×ñÑ­È«¾ÖÉèÖà > ÏÔʾ > LED »·ÁÁ¶ÈÖµ ¡ª ÒÑÐÞ¸´
½öÏÞ 3.11 HX Stomp XL ÖеÄÐÂÔö¹¦ÄÜ ¡ª ²¥·ÅÊÓͼÖÐÊ§ÕæºÍ»ìÏì¿òµÄÑÕÉ«ÒÑ·´×ª ¡ª ÒÑÐÞ¸´
3.11 ÖеÄй¦ÄÜ ½ÓÊÕ MIDI CC67 ¿ÉÄܵ¼Ö Helix LT ¶³½á ¡ª ÒÑÐÞ¸´
3.11 ÖеÄй¦ÄÜÔÚijЩÇé¿öÏ£¬Èç¹ûÔÚ PC ÏûÏ¢Ö®ºóÁ¢¼´·¢ËÍ MIDI ¿ìÕÕ (CC69) ÏûÏ¢¿ÉÄÜÎÞ·¨Ê¶±ð ¡ª ÒÑÐÞ¸´
3.11 ÖеÄй¦ÄÜ£¨Helix Native / HX Edit£©½ö HX Stomp / HX Stomp XL ¡ª ÖØÃüÃûµÄ¿ìÕÕ²»»á³öÏÖÔÚ HX Edit µÄÃüÁîÖÐÐÄ´°¿ÚÖÐ ¡ª ÒÑÐÞ¸´
3.11 ÖеÄÐÂÔö¹¦ÄÜ£¨Helix Native / HX Edit£©½öÏÞ HX Stomp ¡ª ÔÚ´Ó±¸·Ý»Ö¸´ºóµÄ¼«ÉÙÊýÇé¿öÏ£¬HX Stomp µÄÊäÈë¿é¿ÉÄÜÏÔʾΪ¡°ÎÞ¡±¡ªÒÑÐÞ¸´
Description : Helix Native is an established guitar effects processor in plugin format.
Helix® Native: Implements the powerful and tonal authentic award-winning HX Modeling technology in the plugin. Like the hardware members of the Helix family of guitar processors ¨C Helix Floor, Helix Rack and Helix LT, the Helix Native plug-in provides accurate reproduction of vintage and modern amps, cabinets, mics and effects, as well as signal routing and an intuitive user interface. The Helix Native plugin is intended not only for guitarists, but also for producers and sound engineers, film / TV / game composers, electronic musicians, and anyone else who wants to create exciting new sounds and special effects. And preset compatibility across the entire Helix family allows Helix hardware users to stream sounds created in the studio by simply transferring presets from their plugins to their Helix Floor processors
New in version
Helix Native 3.11 contains several stability and performance improvements as well as bug fixes. Updating is highly recommended.
Bug Fixes:
Minor improvements and bug fixes.
New in 3.11 HX Stomp, HX Stomp XL only ¡ª If a custom label is not assigned, tapping a stomp switch with multiple assignments would display ¡°MULTIPLE [X]¡± instead of displaying its assignments ¡ª FIXED
New in 3.11 HX Stomp, HX Stomp XL only ¡ª Stomp mode footswitches would not follow the Global Settings> Displays> LED Ring Brightness value ¡ª FIXED
New in 3.11 HX Stomp XL only ¡ª The colors for Distortion and Reverb boxes on Play view were reversed ¡ª FIXED
New in 3.11 Receiving a MIDI CC67 could cause Helix LT to freeze ¡ª FIXED
New in 3.11 In some cases, a MIDI snapshot (CC69) message could fail to be recognized if sent immediately after a PC message ¡ª FIXED
New in 3.11 (Helix Native / HX Edit) HX Stomp / HX Stomp XL only ¡ª Renamed snapshots would not appear in HX Edit¡¯s Command Center window ¡ª FIXED
New in 3.11 (Helix Native / HX Edit) HX Stomp only ¡ª On rare occasions after restoring from a backup, HX Stomp¡¯s Input block could appear as ¡°None¡± ¡ªFIXED
Line 6 Helix Native ¼ªËûЧ¹ûÆ÷²å¼þÃâ·ÑÏÂÔØ.txt (67 Bytes, ÏÂÔØ´ÎÊý: 0)
