Acon Digital DeVerberate »ìÏì²å¼þ
DeVerberate ÊÇÒ»ÖÖ¼õÉÙ»ìÏìµÄ²å¼þ£¬¿ÉÒÔ¼õÈõ»òÔöÇ¿ÒÑ´æÔÚÓÚÂ¼ÖÆ²ÄÁÏÖеĻìÏì¡£ÐÂÓ±µÄʵʱËã·¨¶Ôµ¥ÉùµÀºÍÁ¢ÌåÉù¼ÒôͬÑùÓÐЧ£¬²¢½«´«ÈëµÄÒôƵ·ÖΪֱ½ÓÉùÒôºÍ»ìÏìÉùÒôµÄ¹À¼Æ£¬È»ºó¿ÉÒÔ×ÔÓɵØÖØÐÂ×éºÏ¡£¿ÉÒÔʹÓÃÊäÈëºÍÊä³öÐÅºÅµÄÆµÆ×±íʾÒÔ¼°¹À¼ÆµÄ»ìÏìÀ´Ö±¹ÛµØ¼à¿Ø¸Ä½ø¹ý³Ì¡£
DeVerberate 2 ÒýÈëÁËÒ»ÖÖеĶÀÌØµÄÔçÆÚ·´ÉäÂ˲¨Æ÷£¬ËüÓë°æ±¾ 1 ÖеĺóÆÚ»ìÏìÒÖÖÆ½áºÏʹÓá£ÔçÆÚ·´ÉäÂ˲¨Æ÷ʹÓø´ÔÓµÄͳ¼Æ·½·¨À´¹À¼ÆËùνµÄÔçÆÚ·´ÉäÂö³åÏìÓ¦¡£È»ºóÀûÓÃÂö³åÏìÓ¦À´¼ÆËãµÖÏûÔçÆÚ·´ÉäÓ°ÏìµÄÄæÂ˲¨Æ÷¡£
ÓÃÀý
¸Ä½ø¶Ô»°ºÍ¶¨Î»ÉùÒô
·¨Ò½×¨¼Ò¿ÉÒÔÌá¸ßÓïÒôÇåÎú¶È
Ë¥¼õÏÖÓмÒôÖеĻìÏì
ÔöÇ¿ÏÖÓмÒôÖеÄ×ÔÈ»»ìÏì
ͨ¹ý¸Ä±äÖ±´ïÉùºÍ»ìÏìÖ®¼äµÄƽºâÀ´¸Ä±ä»ìÒôÖеĸÐÖª¾àÀë
Acon Digital DeVerberate ¿ÉÓÃÓÚ Windows (PC)¡£Ìṩ32λºÍ64λ°æ±¾£¬Ö§³Ö²å¼þ¸ñʽVST¡¢VST3¡¢AAX¡£
°æ±¾ 2 ÖеÄй¦ÄÜ
еÄÔçÆÚ·´Éä¹ýÂËÆ÷
¸Ä½øµÄ×Ô¶¯»ìÏìʱ¼ä¹À¼Æ
VST3 Ö§³Ö
EUCON ºÍÍêÕûµÄ Pro Tools Ó²¼þ¿ØÖÆÆ÷Ö§³Ö
DeVerberate is a reverb reduction plug-in that can attenuate or boost the reverberation that is already present in recorded material. The novel real-time algorithm works equally well with mono as with stereo recordings and splits the incoming audio into an estimation of the direct sound and the reverberated sound which can then be recombined freely. The improvement process can be monitored visually using the spectral representations of the input and output signal as well as of the estimated reverberation.
DeVerberate 2 introduces a new and unique Early Reflections Filter that works in conjunction with the late reverb suppression found in version 1. The Early Reflections Filter uses sophisticated statistical methods to estimate the so called impulse response of the early reflections. The impulse response is then utilized to calculate an inverse filter that cancels out the effect of the early reflections.
Use Cases
Improve dialog and location sound
Forensic specialists can improve speech intelligibility
Attenuate reverberation in existing recordings
Boost the natural reverberation in existing recordings
Change the perceived distance in a mix by changing the balance between the direct sound and the reverberation
Acon Digital DeVerberate is available for both Windows (PC). Both 32 and 64 bit versions are available, and the plug-in formats VST, VST3, AAX are supported.
New in Version 2
New early reflections filter
Improved automatic reverb time estimation
VST3 support
EUCON and full Pro Tools HW controller support
https://crack4windows.com/crack? ... berate&id=33296 |
