Voxengo span 3.11 FFTƵÆ×·ÖÎöÒDzå¼þ·¢²¼
2021Äê4ÔÂ24ÈÕ£ºVoxengo SPAN 3.11°æ¸üÐÂÏÖÒѿɹ©ÏÂÔØ¡£SPANÊÇÒ»¿îÃâ·ÑµÄʵʱ¡°¿ìËÙ¸µÁ¢Ò¶±ä»»¡±ÒôƵƵÆ×·ÖÎöÒDzå¼þ£¬ÊÊÓÃÓÚרҵÒôÀÖºÍÒôÆµÖÆ×÷Ó¦Óá£SPAN¿ÉÓÃÓÚAudioOS£¬AAX£¬VSTºÍVST3²å¼þ¸ñʽ£¬ÊÊÓÃÓÚmacOSºÍWindows¼ÆËã»ú¡£
°æ±¾3.11Öеĸü¸ÄÁÐ±í£º
Ìí¼ÓÁËApple Silicon±¾»ú¼æÈÝÐÔ¡£
Ìí¼ÓÁË1/48±¶Æµ³ÌƵÆ×ƽ»¬Ñ¡Ïî¡£
Ìá¸ßÁËÆµÆ×ƽ»¬¶ÈµÄ¾«¶È¡£
ÔÚmacOSÉÏÆôÓÃÁË¡°Òì²½»æÍ¼¡±´°¿Úģʽ£»¿ÉÄÜ»áÐÞ¸´Óû§½çÃæ¡°Öͺ󡱡£
ÏÖÔÚ½«¡°¸´ÖƵ½¡±°´Å¥³ÆÎª¡°¸´ÖÆ¡±£º¸Ã°´Å¥ÏÖÔÚ´ÓËùÑ¡×éÖи´ÖƲÎÊý£¬¶ø²»ÊÇ´ÓËùÑ¡×éÖи´ÖƲÎÊý¡£ÕâÑù¿ÉÒÔ¸ÄÉÆ¹¤×÷Á÷³Ì¡£
ÂÔ΢¸ÄÉÆÁË×ÖÌåäÖȾ¡£
SPANΪÄúÌṩÁ˷dz£Áé»îµÄ¡°Ä£Ê½¡±ÏµÍ³£¬¿ÉÓÃÓÚÉèÖÃÆµÆ×·ÖÎöÒǵÄÊ×Ñ¡Ïî¡£Äú¿ÉÒÔÔÚÑù±¾ÖÐÖ¸¶¨¸µÁ¢Ò¶¿é´óС£¬FFT´°¿ÚÖØµþ°Ù·Ö±È£¬ÆµÆ×µÄ¿É¼ûбÂÊ¡£³ý´ËÖ®Í⣬Äú¿ÉÒÔÑ¡ÔñÏÔʾËùÐèÀàÐ͵ĸ¨ÖúƵÆ×£¨ÀýÈ磬ʵʱ×î´óÖµ£¬ÀúÊ·×î´óÖµ£©¡£¿ÉÒÔÔÚÊÓ¾õÉÏÆ½»¬ÆµÆ×£¬ÒÔ±ãÓÚ¼ì²é¡£
SPAN¹¦ÄÜ£º
Êä³öÐźŹ¦ÂÊͳ¼Æ
ƵÆ×ƽ»¬
Óû§½çÃæ´°¿Úµ÷Õû´óС
²Ã¼ôͳ¼Æ
Ïà¹ØÒÇ
EBU R128 LUFS/LU metering
²â¹â
Á¢ÌåÉùºÍ¶àͨµÀ·ÖÎö
ÖÐ/²àÃæ·ÖÎö
ÄÚ²¿Í¨µÀ·ÓÉ
ÇþµÀ·Ö×é
Ô¤Éè¹ÜÀíÔ±
³·Ïû/ÖØ×öÀúÊ·
A / B±È½Ï
ÉÏÏÂÎÄÌáʾÏûÏ¢
ËùÓвÉÑùÂÊÖ§³Ö
ÊÓÍøÄ¤ºÍHighDPIÖ§³Ö
¿ÉÒÔÔÚVoxengoÍøÕ¾ÉÏÏÂÔØVoxengo SPANºÍÆäËûרҵÒôƵ²å¼þ https://www.voxengo.com/product/span/?eref=ml
April 24, 2021: Voxengo SPAN version 3.11 update is now available for download. SPAN is a free real-time ¡°fast Fourier transform¡± audio spectrum analyzer plugin for professional music and audio production applications. SPAN is available in AudioUnit, AAX, VST, and VST3 plugin formats, for macOS and Windows computers.
The list of changes in version 3.11:
Added Apple Silicon native compatibility.
Added 1/48 octave spectrum smoothing option.
Improved spectrum smoothing precision.
Enabled the "asynchronous drawing" window mode on macOS; may fix the user interface "lagging".
The "Copy to" button is now called the "Copy": this button now copies parameters FROM the selected group, NOT TO the selected group. This should improve the workflow.
Improved font rendering slightly.
SPAN provides you with a very flexible ¡°mode¡± system which you can use to setup your spectrum analyzer preferences. You may specify Fourier block size in samples, FFT window overlap percentage, spectrum's visual slope. Beside that you can choose to display secondary spectrum of a desired type (e.g. real-time maximum, all-time maximum). Spectrum can be smoothed out visually for an easier examination.
SPAN features:
Output signal power statistics
Spectrum smoothing
User interface window resizing
Clipping statistics
Correlation meter
K-metering
Stereo and multi-channel analysis
Mid/side analysis
Internal channel routing
Channel grouping
Preset manager
Undo/redo history
A/B comparisons
Contextual hint messages
All sample rates support
Retina and HighDPI support
Voxengo SPAN and other pro audio plugins can be downloaded at the Voxengo web site: https://www.voxengo.com/product/span/?eref=ml |
