RME Babyface Pro FS רҵ¼ÒôUSBÍâÖÃÉù¿¨ ÍÞÍÞÁ³¸ßÆ·ÖÊÖ÷²¥Ö±²¥K¸èÉù¿¨»î¶¯¼Û£º5800
ÒôƵϵÁÐ
СÇɱãЯ ²Ù×÷¼òµ¥RME Babyface Pro FS ÒôƵ½Ó¿ÚÓÃÓÚ¶à¹ìÏÖ³¡ºÍÑݲ¥ÊÒ£¬ËæÊ±ËæµØÂ¼ÖÆ
É豸»¹°üÀ¨Ò»¸ö Toslink ¹âѧ I/O£¬Ö§³ÖADAT¸ñʽ£¨´øÓÐSMUX£©
ºÍ SPDIF£¨½Ï¸ß 192kHz£©£¬Babyface Pro FS ÓëÍⲿ ADAT ת»»Æ÷Ò»ÆðÌṩ¶à´ï12¸öÄ£ÄâÊäÈëºÍÊä³ö
Ð嵀 Babyface Pro FS ¾ßÓиü¶àµÄ¸Ä½ø£º• µ×²¿µÄ+19/+4dBu¿ª¹ØÔö¼ÓÁËÖ±½Ó½µµÍÊä³öµçƽµÄ·½Ê½£¬¸ÄÉÆÁéÃôµÄÓÐÔ´¼àÌýµÄÐÅÔë±È £¬±ÜÃâÊ§Õæ/¹ýÔØ£¬ÓÐÖúÓÚTotalMix FXÍÆ×Ó½Ó½ü0dB¶ø·Ç¸ßË¥¼õ
• Õë¶Ô½ÏµÍ»ò½Ï¸ß¶¶¶¯ÒÖÖÆÓëADI-2 PRO FSÖÐÒ»ÑùµÄÍêÕûSteadyClock FSµç·
• 3.5mm TRS¶ú»úÊä³ö£¬¹¦ÂÊ´Ó70mWÌáÉýµ½90mW£¬Á½¸ö¶ú»úÊä³ö×Üг²¨Ê§Õæ ¸Ä½øÁË10dB¡£ÏÖ²ÉÓÃÓëADI-2 PROÒ»ÑùµÄÊä³öÔËËã·Å´óÆ÷£¬3.5mm TRSÊä³ö×è ¿¹´Ó2 Ohms½µµÍµ½ÁË0.1 Ohms
• ¸Ä½ø»°Í²ÊäÈëÐÅÔë±È´Ó112.2dBµ½113.7dB£¬¸Ä½øTRSÏß·ÊäÈëÐÅÔë±È´Ó114dB µ½116.3dB£¨120dBA£©£¬Ïß·ÊäÈë×Üг²¨Ê§Õæ¸Ä½øÁË8dB
• ÐÂADCÔÚAD²àÑÓ³Ù¼õÉÙÁË6²ÉÑù£¨5²ÉÑùAD£¬7²ÉÑùDA²»ÄÜÔÙ¿ìÁË...£©
• ËùÓÐÉÏÃæµÄ¸Ä½ø¶¼ÊÇÔÚûÓÐÌáÉýÉ豸¹¦ºÄµÄÇé¿öÏÂʵÏÖ
• ÓÃÓÚ·ÀµÁµÄ K-Ëø²Û£¨·ÀµÁËø¿×£©
SteadyClock FSÒýÈë SteadyClock FS ʱÖÓ£¬Ê±»ùÎó²î½Ó½üÁ㣬ÊäÈ붯̬Éý¼¶ 120dB
¼Òô/Ö±²¥ÒôÖʸüͨ͸£¬A/D оƬת»»ÑÓ³Ù¸üµÍ£¬¡°Ìýʪ¼¸É¡±¸üÇáËÉ
+19/+4dBu Á½µµÊä³öµçƽ£¬¸ü¸ßµÄ¶ú·ÅÍÆÁ¦£¬Ç¿´óÄÚ¼£¬DSPЧ¹ûÖ§³ÖWin7/8/10¡¢Mac¡¢iPad
SteadyClock FS µÄËٶȷdz£¿ì£¬ËüÔÚ¼¸·ÖÖ®Ò»ÃëÄÚ¾ÍÒýÆðÁ˶ÔÊäÈëÐźŵĹØ×¢
ÉõÖÁ¸úËæ×Å¿ìËÙµÄÒô¸ß±ä»¯¶ø±ä»¯£¬²¢ÇÒÔÚ 28kHz ÖÁ 200kHz µÄ·¶Î§ÄÚÎüÒý
¸ü´óÍÆÁ¦ ´øÀ´¸ü¶àϸ½Ú3.5mm TRS ¶ú»úÊä³ö£¬¹¦ÂÊ´Ó 70mW ÌáÉýµ½ 90mW
Á½¸ö¶ú»úÊä³ö×Üг²¨Ê§Õæ¸Ä½øÁË 10dB£¬ÏÖÔÚ²ÉÓÃÁËÓë ADI-2 PRO Ò»ÑùµÄ
Êä³öÔËËã·Å´óÆ÷£¬3.5mm TRS Êä³ö×迹´Ó 2 Ohms ½µµÍµ½ÁË 0.1 Ohms
DSPµ÷Òǫ̂RME Babyface Pro FS ÒôƵ½Ó¿ÚΪÊäÈëºÍÊä³öÌí¼ÓÁËÁé»îµÄ
3²¨¶Î²ÎÊý¾ùºâÆ÷£¬»¹¿ÉÒÔʹÓûìÏìºÍÑÓ³ÙЧ¹ûÆ÷
ÄÚ¼&Ö÷²¥Áé»î·ÓÉÖ§³ÖWin¡¢Mac¡¢iPadƽ̨£¬ÎÞÐèµÚÈý·½¹¤¾ß£¬
±ã¿ÉʵÏÖ¶àͨµÀÄÚ¼/ÌøÏߣ¬
»¹¿ÉÒÔ¸øÄÚ¼ͨµÀ¼ÓÈëEQ¡¢»ìÏìµÈЧ¹û¡£
¶àƽ̨¼æÈݼòµ¥µÄ USB ²Ù×÷£¬ÊÊÓÃÓÚ MAC¡¢PC ºÍ iOS É豸
¼ò • Éè¼ÆBabyface Pro FS ¼òÁ·µÄÍâ¹Û£¬¼òµ¥µÄÉè¼Æ£¬ÊÖ¸ÐÊæÊÊ
¼¼Êõ¹æ¸ñ
• XLRƽºâÊäÈë
• ƽºâÊäÈë×迹£º2 kOhm£¬Ë¥¼õºó5.2 kOhm
• ·ÇƽºâÊäÈë×迹£º1 kOhm£¬Ë¥¼õºó2.6 kOhm
• ÐÅÔë±È£º113.7 dB RMS ·Ç¼ÓȨ£¬117 dBA
• 44.1kHz / -0.1 dBƵÏ죺18 Hz ¨C 20.8 kHz
• 96 kHz / -0.5 dBƵÏ죺7 Hz ¨C 45.8 kHz
• 192 kHz / -1 dBƵÏ죺5 Hz ¨C 88 kHz
• Ë¥¼õºó£º-0.1 dB 8 Hz, -0.5 dB < 4 Hz, -1 dB < 3 Hz
• ×Üг²¨Ê§Õ棺< -112 dB, < 0.00024
• ×Üг²¨Ê§Õæ¼ÓÔëÉù£º< -108 dB, < 0.00035
• ×Üг²¨Ê§Õæ30dBÔöÒæ£º< -115 dB, < 0.00016
• ×Üг²¨Ê§Õæ¼ÓÔëÉù30dBÔöÒæ£º< -100 dB, < 0.001
• ͨµÀ·ÖÀë¶È£º> 110 dB
• ÔöÒæ·¶Î§£º-11 dB µ½ +65 dB
• ½Ï´óÊäÈëµçƽ XLR ÔöÒæ0dB£º+8 dBu, PAD +19 dBu
• ½Ï´óÊäÈëµçƽ XLR ÔöÒæ65dB£º-57 dBu, PAD -46 dBu
• ÐÅÔë±È£º116 dB RMS ·Ç¼ÓȨ£¬120 dBA
• 44.1kHz / -0.1 dBƵÏ죺5 Hz ¨C 20.8 kHz
• 96 kHz / -0.5 dBƵÏ죺< 3 Hz ¨C 45.8 kHz
• 192 kHz / -1 dBƵÏ죺< 2 Hz ¨C 92 kHz
• ½Ï´óÊäÈëµçƽ +4 dBuÔöÒæ0dB£º+13 dBu
• ½Ï´óÊäÈëµçƽ -10 dBV ÔöÒæ9dB£º-5 dBu• TS·ÇƽºâÊäÈë
• ÊäÈë×迹£º1 MOhm
• ¶¯Ì¬·¶Î§£º115 dB RMS¼ÓȨ£¬118dBA
• 44.1kHz / -0.5 dBƵÏ죺0 Hz ¨C 20.8 kHz
• 96 kHz / -0.5 dBƵÏ죺0 Hz ¨C 45 kHz
• 192 kHz / -1 dBƵÏ죺0 Hz - 89 kHz
• ×Üг²¨Ê§Õæ+ÔëÉù£º-102 dB, 0.0008
• Êä³ö×迹£º300 Ohm ƽºâ, 150 Ohm ·Çƽºâ
• 0dBFSÊä³öµçƽ£ºÆ½ºâ +19 / +4 dBu, ·Çƽºâ +13 / +7 dBu
• 0dBFSÖ±Á÷µçѹ£º6.35mm 4.8 V, 3.5mm 2.4 V, XLR bal. 9.6 V• ×Üг²¨Ê§Õ棺- 106 dB, 0.0005
• Êä³ö£ºXLRƽºâ
• 0dBFS, 1 kOhm¸ºÔØÊä³öµçƽ£º+13dBu
• 0.1%×Üг²¨Ê§Õ湦ÂÊ£º60mW
• ÐÅÔë±È£º114.8dB RMS·Ç¼ÓȨ£¬118dBA
• 0dBFS, 1 kOhm¸ºÔØÊä³öµçƽ£º+7dBu
• 0.1%×Üг²¨Ê§Õ湦ÂÊ£º90mW
• ÐÅÔë±È£º114dB RMS·Ç¼ÓȨ£¬117dBA• Êä³ö£º6.3mm TRS£¬·Çƽºâ
• Êä³ö×迹£º10 Ohm
• µ×Ô룺-101.8 dBu
• Êä³ö£º3.5mm TRS£¬·Çƽºâ
• Êä³ö×迹£º0.1 Ohm
• µ×Ô룺-107 dBu• ͨ¹ýÀ©Õ¹ÏßʵÏÖµÄ2¸ö5ÕëDIN½Ó¿Ú£¬Ò»¸öÊäÈëÒ»¸öÊä³ö
• ͨ¹ý¹âñîºÏÊäÈëµç¸ôÀë
• ¸ßËÙģʽ£ºÊ±»ùÆ«ÒÆºÍÏìӦʱ¼äͨ³£µÍÓÚ1ºÁÃë
• ¶ÀÁ¢128 byte FIFOÊäÈëÊä³ö25.3
• ʱÖÓ£ºÄÚ²¿¡¢ADATÊäÈë¡¢SPDIFÊäÈë
• ÍⲿʱÖÓʱ»ùÆ«ÒÆÒÖÖÆ£º> 50dB (2.4kHz)
• ADºÍDAת»»µÄÓÐЧʱÖÓʱ»ùÆ«ÒÆÓ°Ï죺ÔÚ>100ÄÉÃëʱ»ùÆ«ÒÆÒ²¿É½Ó½üÁãPLLÒÔ
È·±£Á㶪ʧ
• Êý×Ö±ÈÌØÊ±ÖÓPLLÎÞËðʧ±äËÙËÙ¶ÈADAT²Ù×÷
• Ö§³Ö²ÉÑùÂÊ£º28kHzµ½200kHz
• ±ê×¼£º8ͨµÀ24bit£¬½Ï¸ßÖ§³Ö48kHz
• Ë«ËÙS/MUX£º4ͨµÀ24bit/96kHz
• ËÄËÙS/MUX4£º2ͨµÀ24bit/192kHz
• ±ÈÌØÊ±ÖÓPPL¼´±ãÔÚ±äËÙ²Ù×÷ÏÂÒ²¿Éȷͬ²½• 1¸öTOSLINK
• Ëø¶¨·¶Î§£º31.5kHz-50kHz
• ʱ»ùÆ«ÒÆÒÖÖÆ£º>50dB (2.4kHz)• 1¸ö¹âÏ˽ӿڣ¬¸ù¾ÝIEC 60958Ö¸¶¨
• ¿ÉÖ§³ÖרҵºÍÏû·Ñ¸ñʽ
• Ëø¶¨·¶Î§£º27kHz-200kHz
• ʱ»ùÆ«ÒÆÒÖÖÆ£º> 50dB (2.4kHz)• 1¸ö¹âÏ˽ӿڣ¬¸ù¾ÝIEC 60958Ö¸¶¨
• ¿ÉÖ§³ÖרÏû·Ñ¸ñʽ
• ²ÉÑùÂÊ£º28kHz-200kHz
• 1¸öTOSLINK
• ±ê×¼£º8ͨµÀ24bit£¬½Ï¸ß48kHz
• ËÄËÙS/MUX4£º2ͨµÀ24bit/192kHz• ¹¦ºÄ£º3.7W
• ¹©µç£ºUSBÖ±¹©»òÍâÖù©µç
• ³ß´ç£º108 x 35 x 181 mm
• ÖØÁ¿£º680g
