×îÐÂWaves Complete v12 20.12.20²å¼þÍêÕû°æ/ʹÓý̳̣¨Win/Mac£©
0306lw
2020-12-27 14:27:57
Waves V12²å¼þʹÄú¿ÉÒÔµ÷Õû²å¼þµÄ´óС£¬ÒÔ±ã¸üÇáËɵز鿴ËüÃÇ¡£V12»¹ÒýÈëÁËеÄÔ¤ÉèËÑË÷ÒýÇæ£¬¿ÉÈÃÄú²éÕÒºÍÊÔÌýÇúÄ¿µÄÀíÏëÔ¤É裬ÒÔ¼°¸ü¶àй¦ÄÜ¡£ÏÖÔÚ¸üе½V12¡£
°²×°·½·¨:
1. תµ½waveÎļþ¼Ð°²×°Waves Central²¢ÔËÐÐ
2. Ñ¡ÔñÍÑ»ú°²×°³ÌÐò£¬È»ºó´ÓÍÑ»ú°²×°³ÌÐòµ¥»÷°²×°
3. ä¯ÀÀÄúÏÂÔØµÄ WavesÎļþ¼Ð£¨¶ÔÓÚ Mac Óû§£¬½«Îļþ¼ÐÒÆ¶¯µ½¡±Óû§/ÄúµÄÐÕÃû/¹«¹²/¡±£©
4. Ñ¡ÔñÄãϲ»¶µÄ²å¼þ²¢°²×°£¡
5. Ó¦Óò¹¶¡²¢ÏíÊÜ
·¢ÐÐ˵Ã÷£º
2020Äê12ÔÂ20ÈÕ£¬
ËùÓÐWaves SoundGridÓ¦ÓóÌÐò£¬¹Ì¼þºÍÇý¶¯³ÌÐò£ºÈ«Ãæ¸üе½V12£º
УºSoundGrid QRec v12.2.0.155£º¼ò»¯µÄSoundGridÖ÷»ú£¬ÓÃÓÚ½«Mac / PCÁ¬½Óµ½SoundGrid I / O»òÍøÂç¡£QRecÔÊÐíÄú´ÓSoundGrid I / O¿¨µ½DAWÂ¼ÖÆÏÖ³¡±íÑÝ£¬´ÓDAWÖ´ÐÐÐéÄâÉùÒô¼ì²é£¬»ò½«ÈκÎSoundGrid I / OÓÃ×÷¼ÒôÅïÂ¼ÖÆºÍ»Ø·ÅµÄ½Ó¿Ú¡£
¸üУºStudioRack v12.4.0.157
ÐÂÔö£ºÄÚ²¿²àÁ´¨C¾ßÓвàÁ´¹¦ÄܵIJå¼þÏÖÔÚÌṩÁ˸½¼ÓµÄ·Óɲ˵¥£¬´Ó¶ø¿ÉÒÔ´ÓStudioRackÄÚ²¿½ÓÊÕÄÚ²¿²àÁ´Ô´¡£
¹Ì¶¨£º½«Ïàͬ²å¼þµÄÁ½¸öʵÀý²åÈëStudioRack²¢Ðлò¶àƵ´ø´¦Àí»ú¼ÜÖУ¬²¢ÇÒÔÚÁ½¸ö²å¼þʵÀýÖмǼÁËÏàͬ²ÎÊýµÄ×Ô¶¯»¯£¬´Ë´íÎóµ¼ÖÂDAWÖеÄÁ½¸ö×Ô¶¯»¯Í¨µÀ½öÏÔʾµÚÒ»¸ö×Ô¶¯»¯£¬²»¿ÉÄܵ¥¶ÀÐ޸ĵڶþÌõ×Ô¶¯»¯Í¨µÀ¡£ÏÖÔÚ£¬´Ë´íÎóÒÑÐÞ¸´¡£
StudioRack SoundGrid´¦Àíģʽ¨C´íÎóÐÞ¸´£ºÒÑ
ÐÞ¸´£ºÔÚ²¥·Å¹ý³ÌÖÐÇл»SoundGrid´¦Àíģʽʱ£¬DAW±ÀÀ£¡£
ÐÞÕý£º²åÈëStudioRackʱ¸ü¸Ä²ÉÑùÂʻᵼÖÂÂß¼­±ÀÀ£¡£
¸üУºSoundGrid Studio v12.4.0.150
ÐÂÔö¹¦ÄÜ£º32ÖÖÑÕÉ«£¬¿Éͨ¹ýÔ¤Éè²Ëµ¥×Ô¶¨Òå¹ìµÀÑÕÉ«±àÂë¡£
ÐÞ¸´£ºµÚ¶þ¸öµÇ¼Óû§ºÍµÚÒ»¸öÓû§ÔÚͬһMacÉϼÓÔØSoundGrid Studioʱ³öÏÖµÄÎÊÌâ¡£
ÐÞÕý£ºAuto ConfigÎÞ·¨ÔÚSGPģʽÏÂÐÞ²¹DiGiGrid DLI / DLS¡£
ÐÞ¸´£ºÖØÐ´ò¿ªGUIºó£¬µ¼Ö²å¼þλÖøü¸ÄµÄ´íÎó¡£
ÐÞÕý£ºµ¼ÖÂÑ¡¶¨µÄ¿ØÖÆÊÒÊä³öÔÚGUIÉϲ»¿É¼ûµÄ´íÎó¡£
ÐÞ¸´£ºÔÚMultiMod RackÖиü¸ÄÔ¤Éèʱ£¬µ¼ÖÂSoundGrid Studio±ÀÀ£µÄ´íÎó¡£
ÒÑÐÞ¸´£ºÓëI / O¹²ÏíºÍÇý¶¯³ÌÐò¹²ÏíÏà¹ØµÄ¸÷ÖÖÎÊÌâ¡£
¸üУºSuperRack v12.2.0.155
ÐÂÔö£ºÈ¡Ïû¹Ì¶¨²å¼þʱ£¬¶ÔWaves v12²å¼þ´óСµ÷ÕûµÄÖ§³Ö¡£
ÐÂÔö£ºÖ§³ÖWaves v12²å¼þÔ¤Éèä¯ÀÀÆ÷¹¦ÄÜ¡£
ÐÂÔö£ºÏµÍ³·¶Î§µÄÉ豸¹²Ïí¹ÜÀí³Ö¾ÃÐÔЭÒé¡£
ÐÂÔö¹¦ÄÜ£ºÖ§³ÖÔÚϵͳ֮¼ä¹²ÏíSoundGridÇý¶¯³ÌÐò¡£
ÐÂÔö¹¦ÄÜ£ºÌí¼ÓÁËΪÉÌÒµÒôƵÓÃÀýÉè¼ÆµÄ»ú¼ÜÔ¤Éè¡£
ÒÑÐÞ¸´£ºÊ¹ÓÃÒÔϲå¼þ±ÀÀ££ºAbbey Road TG Mastering Chain£¬API 550A£¬CLA MixHub£¬MultiMod Rack£¬Scheps Omni Channel£¬WLM Plus Loudness Meter¡£
ÐÞÕý£ºSoundGridÇý¶¯³ÌÐòºÍ·þÎñÆ÷ÉϵĻº³åÇø´óСÉèÖÃÏÖÔÚ¿ÉÒԺܺõØÐ­Í¬¹¤×÷£¬¶ø²»»áÍ£Ö¹ÒôƵʼþ¡£
ÒÑÐÞ¸´£ºÓëÈȲå¼þÃæ°å£¬¸¡¶¯²å¼þ´°¿Ú£¬ÓëDiGiCo¿ØÖÆÌ¨¼¯³ÉÏà¹ØµÄÆäËû´íÎóÐÞ¸´¡£
¸üУºeMotion LV1 v12.3.0.155
ÐÂÔö¹¦ÄÜ£ºÈ¡Ïû¹Ì¶¨²å¼þºó£¬Ö§³ÖWaves v12²å¼þ´óСµ÷Õû¡£
ÐÂÔö£ºÓÃÓÚ×Ô¶¨Òå¹ìµÀÑÕÉ«±àÂëµÄ32ÖÖÑÕÉ«¡£
й¦ÄÜ£º¶¥¼¶FOH¹¤³ÌʦµÄÔ¤ÉèKen¡° Pooch¡± Van Druten£¬Will Madera£¬Eran Ben Zur¡£
ÐÂÔö¹¦ÄÜ£º»ìÒôÆ÷´°¿ÚÖеÄPreamp / Localģʽ¿ØÖÆ£¬ÊäÈëģʽ¡£
ÐÞÕý£º±à¼­¡°ÉèÖá±>¡°Çåµ¥¡±Ñ¡ÏÉèÖÃʱ£¬Ó¦ÓóÌÐò¶³½áÔÚI / O¹²ÏíÉèÖÃÖС£
ÐÞ¸´£ºALL²ãÖеĴíÎ󣬵¼Ö´ӵ÷Òǫ̂µÄÍÆ×ÓÇøÓòÑ¡ÔñͨµÀÎÞЧ¡£
ÐÞ¸´£º¹Ì¼þ¸üÐÂÑ­»·ÎÊÌâ¡£
ÐÞ¸´£ºµ¼ÖÂÎÞ·¨ÕýÈ·±£´æ»òµ÷ÓÃÉ豸Ãû³ÆµÄ´íÎó¡£
¹Ì¶¨£º¸üÐÂI / O¹Ì¼þºó£¬¿ÉÄÜ»áÒªÇóÓû§Ö´ÐÐÆäËû¸üк͹ػúºóÔÙ´ò¿ª¡£
¸üУºFIT¿ØÖÆÆ÷Ö§³Ö
ÐÂÔö¹¦ÄÜ£º¸Ä½øÁËÓÃÓÚ¿ØÖÆAux Fader FlipÑ¡ÏîµÄ¹¤×÷Á÷³Ì¡£
ÐÞ¸´£º¶ÀÁ¢Ä£Ê½´íÎóÐÞ¸´£ºÒç³öģʽ·ÖÅä´íÎó
¸üУºSoundGridÇý¶¯³ÌÐò£¨ASIO /ºËÐÄÒôƵ£©12.2.0.130£¨°üº¬ÔÚSoundGrid Studio£¬eMotion LV1£¬SuperRackºÍQRecÖУ©¡£
¸üУºSoundGrid·þÎñÆ÷¹Ì¼þ12.2.0.112£¨°üº¬ÔÚSoundGrid Studio£¬eMotion LV1ºÍSuperRackÖУ©¡£
ÒѸüУºËùÓÐSoundGrid I / O¹Ì¼þºÍ¿ØÖÆÃæ°åv12.x
Ô­Îļò½é£º
Waves V12 plugins let you resize your plugins so you can view them more easily. V12 also introduces a new preset search engine that lets you find & audition the perfect presets for your tracks, plus more new features. Update now to V12.
Release Notes
December 20th, 2020
All Waves SoundGrid applications, firmware and drivers: Across-the-board software update to V12:
New: SoundGrid QRec v12.2.0.155: A simplified SoundGrid host for connecting your Mac/PC to a SoundGrid I/O or network. QRec allows you to record live shows from a SoundGrid I/O card to a DAW, perform virtual soundcheck from a DAW, or use any SoundGrid I/O as an interface for studio recording and playback.
Updated: StudioRack v12.4.0.157
New: Internal sidechain ¨C An additional routing menu is now available in plugins with sidechaining ability, making it possible to receive internal sidechain sources from within StudioRack.
Fixed: When two instances of the same plugin were inserted into a StudioRack parallel or multiband processing rack, and automation was recorded for the same parameter in both plugin instances, a bug caused both automation lanes in the DAW to show only the first automation, making it impossible to modify the second automation lane independently. This bug is now fixed.
StudioRack SoundGrid Processing Mode ¨C Bug Fixes:
Fixed: DAW crashing when SoundGrid Processing mode is switched during play.
Fixed: Logic crashing when sample rate is changed while StudioRack is inserted.
Updated: SoundGrid Studio v12.4.0.150
New: 32 colors for customized track color coding via a preset menu.
Fixed: Issues when a second logged-in user loads SoundGrid Studio on the same Mac as the first user.
Fixed: Auto Config not patching DiGiGrid DLI/DLS in SGP mode.
Fixed: Bug causing plugin location to change once GUI is re-opened.
Fixed: Bug causing selected Control Room outputs not to be visible on the GUI.
Fixed: Bug causing SoundGrid Studio to crash when presets are changed in MultiMod Rack.
Fixed: Various issues related to I/O sharing and driver sharing.
Updated: SuperRack v12.2.0.155
New: Support for Waves v12 plugin resizing when a plugin is undocked.
New: Support for the Waves v12 plugin preset browser feature.
New: System-wide device sharing management persistence protocol.
New: Support for SoundGrid driver sharing between systems.
New: Addition of rack presets designed for Commercial Audio use cases.
Fixed: Crashes with the following plugins: Abbey Road TG Mastering Chain, API 550A, CLA MixHub, MultiMod Rack, Scheps Omni Channel, WLM Plus Loudness Meter.
Fixed: Buffer size settings on SoundGrid drivers and servers now work well together without stopping audio events.
Fixed: Miscellaneous bug fixes related to the Hot Plugin panel, floating plugin windows, integration with DiGiCo consoles, and more.
Updated: eMotion LV1 v12.3.0.155
New: 32 colors for customized track color coding.
New: Presets by top FOH Engineers Ken ¡°Pooch¡± Van Druten, Will Madera, Eran Ben Zur.
New: Preamp/Local mode control in the Mixer windows, Input Mode.
Fixed: Application freeze in I/O sharing setups, when editing the Setup > Inventory tab settings.
Fixed: Bug in the ALL layer, causing channel selection from the mixer¡¯s fader area not to work.
Fixed: Firmware update loop issue.
Fixed: Bug causing Device name not to saved or recalled properly.
Fixed: After updating I/O firmware, users may be asked to perform another update and power cycle.
Updated: FIT Controller Support
New: Improved workflow for controlling Aux Fader Flip options.
Fixed: Standalone mode bugs.Fixed: Spill mode assignment bug.
Updated: SoundGrid Driver (ASIO/Core Audio) 12.2.0.130 (included in SoundGrid Studio, eMotion LV1, SuperRack,,and QRec).
Updated: SoundGrid server firmware 12.2.0.112 (included in SoundGrid Studio, eMotion LV1, and SuperRack).
Updated: All SoundGrid I/O firmware and control panels v12.x
Instructions
1. Go to waves folder and Install Waves Central and Run
2. Select Offline Installer and Click Install from an Offline Installer
3. Browse the Waves folder you downloaded (For Mac Users, move folder to ¡°Users/yourname/public/¡±)
4. Select the plugins you like and Install!
5. Apply patch and Enjoy
ÆÀÂÛÁÐ±í£¨7£©
0306lw Â¥Ö÷
Ô­Îļò½é£º
Release Notes
December 20th, 2020
Instructions
2020-12-27 14:28:43 »Ø¸´
À´ÊÔÊÔÕâ¸ö²å¼þÔõôÑù
2020-12-27 16:36:34 »Ø¸´
111111111111111111111111111111111111111111111
2020-12-30 15:59:40 »Ø¸´
¸Ðл¥Ö÷·ÖÏí
2021-1-1 22:54:41 »Ø¸´
¸Ðл¥Ö÷·ÖÏí
2021-1-8 16:42:53 »Ø¸´
¸Ðл¥Ö÷·ÖÏí½Ì³Ì£¬»¹ÔÚÃþË÷ѧϰÖС£
2021-1-21 17:07:04 »Ø¸´
lzdily2021
³öÖ· ¼ò»¯ Ê¡ÂÔ Ð§ÂÊ
2021-6-3 16:04:47 »Ø¸´
