AudioBox 44 VSL 4½ø/³öÒôƵ½Ó¿Ú
²úÆ·¼ò½é
»°Í²ÊäÈë Á¬½ÓÆ÷ÀàÐÍCombo,XLR,female,ƽºâµÄ »°·ÅEIN-133dB,20kHzBW,×î´óÔöÒæ,Rs=40¦¸,A-wtd ƵÏì20Hz-22kHz,¡À0....
| »°Í²ÊäÈë |
| | Á¬½ÓÆ÷ÀàÐÍ | Combo, XLR, female, ƽºâµÄ | | »°·ÅEIN | -133 dB, 20 kHz BW, ×î´óÔöÒæ, Rs=40¦¸, A-wtd | | ƵÏì | 20 Hz - 22 kHz, ¡À0.25 dB, ÕûÌåÔöÒæ | | THD+N | 0.002%, +4 dBu, 1 kHz, ÕûÌåÔöÒæ, 22 kHz BW, A-wtd | | ÐÅÔë±È | 97 dB, +4 dBu, 1 kHz, ÕûÌåÔöÒæ, 22 kHz BW, A-wtd | | ÔöÒæ¿ØÖÆ·¶Î§ | -15 dB ÖÁ +65 dB | | ÊäÈë×î´óHeadroom | +16 dBu, < 0.5% THD | | ÊäÈ뿹×è | 1.7 k¦¸ | »ÃÏóµçÔ´
| +48 VDC, 32 mA total unit
| | Ïß·ÊäÈë |
| | Á¬½ÓÆ÷ÀàÐÍ | Combo, ?¡± TRS, female, ƽºâµÄ | | ƵÏì | 20 Hz - 22 kHz, ¡À0.25 dB, ÕûÌåÔöÒæ | | THD+N | 0.002%, +4 dBu, 1 kHz, ÕûÌåÔöÒæ, 22 kHz BW, A-wtd | | ÐÅÔë±È | 98 dB, +4 dBu, 1 kHz, ÕûÌåÔöÒæ, 22 kHz BW, A-wtd | | ÔöÒæ¿ØÖÆ·¶Î§ | -20 dB ÖÁ +20 dB | | ÊäÈë×î´óHeadroom | +21 dBu, < 0.5% THD | ÊäÈ뿹×è
| 10 k¦¸
| | ÀÖÆ÷ÊäÈë |
| | Á¬½ÓÆ÷ÀàÐÍ | Combo, ?¡± TS, female, ƽºâµÄ | | ƵÏì | 20 Hz - 22 kHz, ¡À0.25 dB, ÕûÌåÔöÒæ | | THD+N | 0.003%, +4 dBu, 1 kHz, ÕûÌåÔöÒæ, 22 kHz BW, A-wtd | | ÐÅÔë±È | 89 dB, +4 dBu, 1 kHz, ÕûÌåÔöÒæ, 22 kHz BW, A-wtd | | Êä³öµçƽ | -30 dBÖÁ +50 dB | | ÊäÈë×î´óHeadroom | +21 dBu, < 0.5% THD | ÊäÈ뿹×è
| 1 M¦¸
| | Ä£ÄâÊä³ö |
| | Á¬½ÓÆ÷ÀàÐÍ | ?¡± TRS, female, ƽºâ¿¹×è | | ƵÏì | 20 Hz - 22 kHz, ¡À0.25 dB | | THD+N | 0.003%, 1 kHz, 22 kHz BW, A-wtd | | ÐÅÔë±È | 109 dB, 1 kHz, 22 kHz BW, A-wtd | | Êä³öµçƽ | +10 dBu, <0.5% THD | Êä³ö¿¹×è
| 51¦¸
| | ¶ú»úÊä³ö |
| | Á¬½ÓÆ÷ÀàÐÍ | ?¡± TRS, female, Á¢ÌåÉù | | ×î´óµçÔ´ | 120 mW/ch @ 60¦¸ load | | ƵÏì | 20 Hz - 20 kHz, ¡À0.5 dB, ×î´óÔöÒæ | | THD+N | 0.01%, 1 kHz, max gain, 20 kHz BW, A-wtd | ÐÅÔë±È
| 96 dB, 1 kHz, ×î´óÔöÒæ, 20 kHz BW, A-wtd
| | Êý×Ö |
| | ADC¶¯Ì¬·¶Î§ | 114 dB, 48 kHz, A-wtd | | DAC¶¯Ì¬·¶Î§ | 114 dB, 48 kHz, A-wtd | | Ö÷½Ó¿Ú | USB 2.0 | | BitÉî¶È | 24-bit | | ²ÉÑùÂÊ | 44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz | | ×î´óÑÓ³Ù | 6 ms, Ä£ÄâÊäÈëÖÁÄ£ÄâÊä³ö | MIDI I/O
| 5Õë DINÁ¬½ÓÆ÷
| | µçÔ´ |
| | Íâ½ÓµçԴת»»Æ÷ | +12 VDC, 1 A, center-positive(ÄÚº¬) | ÀàÐÍ
| Barrel: 5.5 mm OD, 2.1 mm ID, 9.5 mm³¤
| | ÎïÀí²ÎÊý |
| | Ìå»ý | 1/2U »ú¼Ü£¨²»°üº¬±ê×¼¹ìµÀÖᣩ | | ¸ß¶È | 1.75¡± (44.45 mm) | | Éî¶È | 5.5¡± (139.7 mm) | | ¿í¶È | 9.5¡± (241.3 mm) | | ÖØÁ¿ | 2.6 lb. (1.2 kg) | ¼¼ÊõÖ¸±ê
ϵͳ×îµÍÒªÇó
Windowsϵͳ
Windows XP SP3, Vista x64/x32 SP2, Windows 7 x64/x32 SP1, Windows 8 x64/x32
Intel Core Duo»òAMD Athlon X2 ´¦ÀíÆ÷£¨½¨ÒéʹÓÃIntel Core 2 Duo»òAMD Athlon X4 »ò¸ü¸ßÅäÖã©
2 GB RAM £¨½¨ÒéʹÓÃ4 GB»ò¸ü¸ßÅäÖã©
Macϵͳ
Mac OS X 10.6.8»ò¸üÐÂϵͳ
Intel Core Duo´¦ÀíÆ÷£¨½¨ÒéʹÓÃIntel Core 2 Duo »ò Intel Core i3»ò¸ü¸ßÅäÖã©
Windows ºÍMac ϵͳ
USB 2.0½Ó¿Ú
ÍøÂçÁ¬½Ó£¨Ö»ÏÞ¼¤»îʹÓã©
DVD-ROM Çý¶¯
×îµÍ1024x768·Ö±æÂʼàÌý
20 GB Ó²Å̿ռä
Ç¿ÁÒÍÆ¼öÓµÓÐÄÚÖûòÍâÖÃ7200 RPM´æ´¢¿Õ¼ä
²úÆ·²âÆÀ
StudioLive ¼Ó³Ö£ºAudiobox VSL
PreSonusÊÇÒ»¼ÒºÜÓнøÈ¡ÐĵĹ«Ë¾£¬ÈýÄêǰÆÀ²âFireStudioµÄʱºò£¬¸Ð¾õÖ»ÊÇÒ»¼ÒÆÕͨÒôƵ¹«Ë¾£¬Í¬Ò»Ä꣬ËûÃÇ¿ªÊ¼±¬·¢£¬²»¶ÏÍÆ³öвúÆ·½øÈëÐÂÁìÓò£¬¶øÇÒвúÆ·È«²¿³É¹¦£¨ÄѵÀAvid´ó²ÃÔ±Ö®ºóµÄ¾«Ó¢...
