ËÞÖ÷ ¨C BandLab Cakewalk 26.09.0.006 WIN
9 f- z g" G! q: D$ T/ D% t. A# I 0 i; k" h( v0 j$ { g3 f
Ò»¿î¹¦ÄÜÇ¿´óµÄÒôÆµÖÆ×÷ƽ̨£¬°üº¬ÁË×÷Çú¼ÒºÍÒôÀÖ¼Ò´´×÷ÒôÀÖËùÐèµÄËùÓй¤¾ß£¬¿ÉÒÔ׫д¸èÇú¡¢±à¼ÒôƵ¡¢¼Ç¼Òô¹ì¡¢Ä¸´øÖÆ×÷£¬ÈÃÄã¿ÉÒÔ˳ÀûµÄÍê³ÉÒôÀֵĴ´×÷¡£
& O- V) ^' F- w3 J- @. t
* c3 i2 |8 T4 T2 A) |( nFile size: 573 MB
( X2 P* X7 r( {4 H4 }( P9 k& W- P4 ]1 a% i5 t$ T5 K5 {
Fueled by over 30 years in the relentless pursuit of innovation, Cakewalk by BandLab is the new standard for the modern recording studio.6 ]9 d. {: v( F
" v* y F" f" q" F8 F! C* ?The most complete music production package- p0 {8 ~0 P0 L. q
The creative experience only SONAR offered: advanced technology, effortless workflow, and an interface that amplifies inspiration.
& n) ^( v1 o5 y" c; X0 m$ R( I9 S0 h& s
Compose
& p; F' }' Z1 ]3 A& PEasily compose complete songs and performances with creative songwriting tools and instruments u( l# Q7 o% v8 v" L% W
: X) _0 B/ s6 W8 |5 ORecord
+ |- t; K% M) a5 t% JCapture inspired performances with pristine quality and unlimited audio and MIDI tracks
$ |: F/ Q6 D7 s0 `9 D5 h
) O6 ?( d/ u( @& ^. W2 }Edit
8 X P9 Z& A* U0 LFix mistakes, arrange parts, and manipulate pitch, time, and any other aspect of your recordings
) ~! E5 M; Y( y5 \8 R. N2 E3 x8 b
& K- z0 l/ g" {2 S- {# O0 N) J$ q, r, Q! KMix
- {) }* i' o- A% yAchieve pristine pro-studio sounds and create big, clear, dynamic mixes with advanced mixing tools; V# E2 U6 D& R
% L) s# O m. d( m
Master
! y. C& R9 r* H- i8 `* EPolish your finished mixes to perfection with built-in mastering tools9 M' P q, L" _! W* `' q
# \, h7 }4 T( C `; n5 QShare
7 d7 T& o8 x& q7 V! u* I GExport and publish your songs directly to YouTube, SoundCloud, Facebook and more
8 ^( e$ K. `' I) F& `' b( I8 t; R* P) S8 a' c" \5 ^
Creativity without limits
4 z6 }. ^0 c3 N( @( YAward-winning UI
0 \9 R. E. e: l# t& ]Navigate your projects with the award-winning fully customizable Skylight Interface/ B( p5 k/ q0 q! A4 x+ J4 y
; @! {2 M, \7 Y% }9 v
Unlimited Tracks9 B2 F( q1 O, D
Enjoy unlimited Audio, MIDI, Instrument, Loop, and Auxiliary Tracks in every project
2 T- x3 D; Y8 B& q' B
7 d1 K! o; V& K, R0 kIndustry-best Engine# v) M( X& d& w, e. J7 _
Experience the industry-best audio engine, VST3, Touch and all the leading technologies$ h4 L" e3 K% \7 V) g- m% w
1 |* Y; P2 |0 `7 W/ ?, k! n
A World of Instruments
7 b7 E; V9 V4 b- V2 L9 x$ RWhether you¡¯re a songwriter, producer, or composer, Cakewalk by BandLab has the instruments you need to build your production from the ground up./ y! c1 b0 a9 R6 z* ?5 o3 I1 I
: h* i3 e9 z, m9 t7 j! x0 C
Studio Quality Effects5 y. ^6 b. j, m3 D2 c0 ?) r& y# _
For tracking, mixing, or mastering, with FX ranging from the essential to the unique, Cakewalk by BandLab has you covered. Designed to emulate the layout of an analog console, build and upgrade your channel strip with an expandable library of ProChannel modules ranging from convolution reverb, resonant filtering, dynamic compression, and powerful EQ to tape and console emulation, peak limiting, and tube saturation.
% Z% k+ o6 t8 m, ? G5 ^
( L6 E p' ^3 N$ ~& I- w' `* ZMinimum System Requirements:
9 B2 j* g- D0 RWindows 7 or higher (64-bit only)0 x8 f5 V$ l) Y: w- N
Multi-core Intel or AMD CPU/ a% P/ y& `! L' [
4GB RAM
# {! k0 B, S# v$ O3GB free disk space
: W0 ]1 @# k- D+ N( O$ `( J3 o7 j1280¡Á800 screen resolution- \. O. h$ e {$ H: i8 Y
ASIO compatible hardware is recommended
5 L! z) u# w) R Z" J, G( d' W# K; d: n$ l! `! m- U
Homepage2 A; d' O) i4 c- b, E! k) o9 h
: o* T c0 Y& e1 |/ Z" r
http://www.bandlab.com% s; j& y0 G# H' [/ d" H9 v
' G4 V. ]$ C) V8 n% ]/ s" t
1 M, h' m' \! ?! q- }ËÞÖ÷ ¨C BandLab Cakewalk 26.09.0.006 WIN# O0 ^1 U' L j% |/ ?* [
2 Y! D6 O- a' Z* ^* ?% V. @& z
ËÞÖ÷ ¨C BandLab Cakewalk 26.09.0.006 WIN.txt
(143 Bytes, ÏÂÔØ´ÎÊý: 0)
4 c' {$ e, y$ e7 h2 B, _" s |
