´´Òâ¹Ä½ÚÅÄÒôÐòÆ÷ Rigid Audio Sodium KONTAKT
´´Òâ½ÚÅıà³Ì¡£
SODIUMÊÇKONTAKT 6.2.2µÄ´´Òâ¼Ü×ӹĺÍÒôÐòÆ÷¡£
Ëü°üº¬200¸öÆô·¢ÐԵĵ±´ú¹¤³§Ì×¼þ¡£Ëü»¹´øÓÐÊý°ÙÖÖ¸½´øµÄ¹ÄÉù£¬ÒÔ°ïÖúÄúÈëÃÅ¡£ £¨ÄúÒ²¿ÉÒÔͨ¹ýÍϷŲÙ×÷µ¼Èë×Ô¼ºµÄWAVÑù±¾£©¡£
SODIUM¾ßÓÐËĸö¹ÄÒôÐòÆ÷-ÿ¸öÒôÉ«¶¼ÓÐËĸö²»Í¬µÄ¹ÄÉùºÍ
32¸ö²½Ö裨·ÖΪÁ½¸ö¼ü¿ÉÇл»Ä£Ê½£©¡£Ã¿¸öÒôÐòÆ÷¶¼¿ÉÒÔ¿ØÖÆËÙ¶È£¬ÒôÁ¿ºÍÉùÏñ£¬Òôµ÷£¬Ë¥¼õ£¬£¨µÍÇУ©Â˲¨Æ÷£¬»ìÏ죬¶àÖØÐ§¹û£¬²ÉÑùÆ«ÒÆºÍ»ðÑæ¡£
´´ÔìÁ¦½öÏà¾àÒ»¸öÐýÅ¥-ʹÓÃÔ¤ÉèÐýťΪÿ¸öÒôÐòÆ÷²¦È벻ͬµÄÔ¤É軨Ñù±ä»¯¡£»òͨ¹ýÒ»¸ö°´Å¥ÍêÈ«Ëæ»ú»¯Ì×¼þ¡£
ÄúÒ²¿ÉÒÔÔÚϲ»¶¸Ã»¨Ñùºó½«Æä¡°Ëø¶¨¡±£¬È»ºóÇáËɵؽ«ÆäÓëÀ´×Ô²»Í¬Ô¤ÉèÌ×¼þµÄ¹ÄÉù½øÐн»»»¡£
¶àÊä³ö·ÓÉÒ²¿ÉÓÃÓÚDAWÖеĽøÒ»²½´¦ÀíºÍ»ìºÏ¡£
SODIUMÖеÄÿ¸öģʽ¶¼¿ÉÒÔ²¥·Å°üÀ¨µÄËĸö¹ÄÉùÖ®Ò»¡£
ÕâÑùÒ»À´£¬Äú¾Í¿ÉÒÔ¼´Ê±Çл»ÉùÒô£¬ÇáËɳ¢ÊÔ¸÷Öֱ仯¡£
ÆäÖаüÀ¨Ò»Ð©ÌØÊâģʽ£¬ÀýÈç¡°Ñ»·¡±ºÍ¡°Ëæ»ú¡±£¬ÒÔˢз½Ê½¸ü¸Äģʽ¡£
-200¸ö¹ÄÎèÈËÐĵļÜ×Ó¹Ä
-·á¸»µÄµçÓ°£¬µç×Ó£¬ÉùѧºÍ»ìºÏ¹Ä×é
-°üº¬Êý°ÙÖÖ¹ÄÉù
-¾ßÓÐ20¸öÄÚ²¿Ô¤ÉèµÄËĸöÒôÐòÆ÷
-ģʽ±à¼£¨¸´ÖÆ£¬Õ³Ìù£¬Ëæ»ú»¯£¬³õʼ»¯£¬Öظ´£©
-°ËÖÖ²»Í¬µÄÑù±¾²¥·Åģʽ
-µ¥¶À»òÈ«²¿²¥·Åģʽ
-´¥·¢Ã»ÓÐģʽµÄÑù±¾
-¾ßÓлØÉù£¬Çý¶¯£¬ºÏ³ªºÍ·ç¸ñµÄ¶àЧ¹ûÒýÇæ
-ÄÚÖÃÉú²úÖÊÁ¿µÄ°å»ìÏì
-¶àÊä³ö·ÓÉ£¨½«Ã¿¸ö¹ÄÉù·Óɵ½Æä×Ô¼ºµÄͨµÀ£©
-Çïǧ»¬¸ËºÍÀÖÆ÷Ì×¼þËæ»ú
»¹ÓÐʲô£¿
-SODIUMÊÇÍêÈ«×Ô¶¯»¯µÄ
-´¥Êֿɼ°µÄ¼´Ê±¿ÉÓÃÇÒ¹ÄÎèÈËÐĵÄÉùÒô
-100£¥Ãâ°æË°
-´Ó¿ìËÙ·þÎñÆ÷¹ºÂòºóÁ¢¼´ÏÂÔØ
×¢Ò⣺ÐèÒªNI KONTAKT v6.2.2»ò¸ü¸ß°æ±¾µÄÍêÕû°æ±¾£¡
KONTAKT ¨C 279 MB
CREATIVE BEAT PROGRAMMING.
SODIUM is a creative drum and beatsequencer for KONTAKT 6.2.2.
It features 200 inspiring contemporary factory kits. It also comes with hundreds of included drum sounds to get you started. (You can also import your own WAV samples via drag and drop).
SODIUM features four drum sequencers ¨C each one has four distinct drum sounds and
32 steps (divided into two key-switchable patterns). Each sequencer gives you control over velocity, volume and panning, pitch, decay, (lowcut) filter, reverb, multi-fx, sample offset and flam.
Creativity is just one knob away ¨C dial in different preset pattern variations for each sequencer using the preset knobs. Or completely randomize the kit with a single button.
You can also ¡°lock¡± a kit once you like the pattern and exchange it with drumsounds from different preset kits easily.
Multi output routing is also available for further processing and mixing in your DAW.
Each pattern in SODIUM can play back one of four included drumsounds.
With this, you can switch sounds on the fly to try variations with a breeze.
There are some special modes included like ¡°cycle¡± and ¡°random¡± to alter patterns in a refreshing way.
Rigid Audio Sodium KONTAKT screenshotWHAT YOU GET
¨C 200 inspiring drumkits
¨C a wealth of cinematic, electronic, acoustic and hybrid drumkits
¨C hundreds of included drumsounds
¨C four sequencers with 20 internal presets
¨C pattern editing (copy, paste, randomize, init, repeat)
¨C eight different sample playback modes
¨C play patterns separately or all together
¨C trigger samples without patterns
¨C multi-fx engine with echo, drive, choral and flair
¨C production quality plate reverb built-in
¨C multi output routing (route each drumsound into its own channel)
¨C swing slider and musical kit randomization
WHAT ELSE?
¨C SODIUM is fully automatable
¨C instantly useable and inspiring sounds right at your fingertips
¨C 100% royalty free
¨C instant download after purchase from fast servers
NOTE: FULL version of NI KONTAKT v6.2.2 and higher required! |
