ºÏ³ÉÆ÷: LinPlug MorphoX v1.1.1 Win/Mac
aidabuli
2020-7-9 12:53:44
ÓÃÆÆ½âµÄ²å¼þÌæ»»²å¼þ
v1.1.1±ä»¯:
ÐÞ¸´ÁËCubaseµÄ¼æÈÝÐÔÎÊÌ⣬µ¼Ö»ỰÉèÖÃÎÞ·¨»Ö¸´
-ÐÞÕýÁËÒ»¸öµ¼ÖÂÀÖÆ÷ûÓÐÉùÒôµÄ´íÎó
-¹Ì¶¨½»Ìæµ÷ÖÆÔ´²»ÕýÈ·µÄµ¥Ä£
²»ÒªÏÝÈ븴ÔÓ£¬Ê¹ÓÃMorphoXÄãÖ»ÐèÒªµ÷ÖÆÂÖ
ÒÔ¼°ÔÚÉùÒôÖÐÌåÑéÎÅËùδÎŵıí´ïºÍת±äµÄÔ¿³×¡£
±äÐμòµ¥£¬ÔÚʵʱ£¬¼±¾ç±ä»¯µÄÉùÒô£¬¾ÍÔÚÄãµÄ±äÐÎÂÖ¡£
µ±ÄãÌåÑéÐÎ̬µÄÉùÒôµñËÜʱ£¬Äã²»»áÏàÐÅËüÖ»ÊÇÒ»ÖÖ°²¾²
´øÓкϳª¡¢ÑÓ³ÙºÍÅÃÒôµÄ¼òµ¥¼õ·¨ºÏ³ÉÆ÷¡£ËüºÜÈÝÒ×´´Ôì
Äã×Ô¼ºµÄ±äÐÎÒô¡£ÎªÁËÈÃÄ㿪ʼ£¬ÎÒÃǹÍÓ¶ÁËһЩ×îºÃµÄÉùÒô
Éè¼ÆÊ¦´´ÔìÁË600¶à¸ö¹¤³§Ô¤Éè¡£
¨C Install from DEMO Installer
¨C Replace Plug-Ins with cracked ones
Changes v1.1.1 :
¨C Fixed a compatibility problem with Cubase which prevented session settings to restore
¨C Fixed a bug causing no sound coming out of instrument
¨C Fixed Alternate modulation source not correct in Mono-Mode
Don¡¯t get stuck in complexity, with MorphoX you just need the modulation wheel
and the keys to experience yet unheard expression and transformation in sound.
Morphing made simple, in realtime, drastic changes in sound, right at your morph wheel.
When you experience the sound sculptures of MorphoX you wont believe its just a quite
simple subtractive synth with chorus, delay and an arpeggiator. Its dead easy to create
your own morphing sounds. To get you started we hired some of the finest sounds
designers to create more than 600 factory presets.
