˲ʱµçƽ´¦Àí²å¼þ Voxengo TransGainer 1.10 Win
File size: 7.2 MB
TransGainer£¬Ò»¸öÒôƵЧ¹ûAAX, AudioUnitºÍVST²å¼þ£¬ÊʺϹ㷺µÄרҵÉùÒôºÍÒôÀÖÉú²úʹÓã¬ÊµÏÖÁËÒ»¸öÒôƵÐźŵÄÐÅ·âµ÷ÕûËã·¨£¬¶Ô˲±ä·´Ó¦£¬¶ø²»ÊÇÐźŵÄÏì¶Èˮƽ¡£Õâ¸öËã·¨ÔÊÐíÄãµ÷Õû¹¥»÷µÄÒôÁ¿ºÍά³ÖÈκÎÄãʹÓÃËüµÄÉùÒôµÄ½×¶Î¡£TransGainer±»Éè¼Æ³ÉÊʺÏËùÓпÉÄܵÄÉùÔ´-ÎÞÂÛÊǵ¥¶ÀµÄ¹ìµÀ»ò³ä·Ö»ìÒô¡£
ÔÚÐí¶àÇé¿öÏ£¬TransGainer¿ÉÒÔʹÓÃÔÚÃźÍÀ©Õ¹²å¼þµÄµØ·½£¬Í¬Ê±Ìṩһ¸ö¸üºÃµÄÉùÒôºÍÌṩһ¸ö¸üÈÝÒ׵ĿØÖÆ¡£³ý´ËÖ®Í⣬TransGainer¿ÉÒÔÓÃÓÚÒôƵ¼Òô»Ö¸´/ÖØÐÂÕÆÎÕµÄÄ¿µÄºÍ»ìÏìβ²¿ÐÞ¸ÄÓëÓÅÐãµÄ½á¹û¡£
TransGainerÔÊÐíÄãÖ¸¶¨Ò»¸öÉùÒôµÄ˲̬½×¶ÎµÄÕýÔöÒæ»ò¸ºÔöÒæµ÷Õû¡£Äú»¹¿ÉÒÔÔÚ˲̬ºÍ˲̬ãÐֵˮƽ֮¼äÑ¡ÔñÒ»¸öÔ¤ÆÚƽ¾ùʱ¼ä£¬ÒÔ±ãËã·¨Äܹ»Ìṩ×ȷµÄ½á¹û¡£ÔÚTransGainerµÄ°ïÖúÏ£¬Äã¿ÉÒÔͨ¹ý±ß½ç´ÓºÃµÄµ½ÓÅÐãµÄ¼Òô¡£
ÌØµã:
˲̬½×¶ÎÏì¶Èµ÷Õû
Ëĸö´¦ÀíËã·¨
¡°ÒÅÁô¡±Ëã·¨ÖеÄ5ÖÖ´¦Àíģʽ
Transient-to-transientʱ¼ä¿ØÖÆ
Á¢ÌåºÍ¶àͨµÀ´¦Àí
ÄÚ²¿Í¨µÀ·ÓÉ
ÐŵÀ·Ö×é
ÖÐÆÚ/±ß´¦Àí
´ïµ½8x¹ý²ÉÑù
64λ¸¡µã´¦Àí
Ô¤ÖùÜÀíÆ÷
³·Ïú/ÖØ×öÀúÊ·
A / B±È½Ï
ÉÏÏÂÎÄÌáʾÏûÏ¢
ËùÓÐÑù±¾ÂÊÖ§³Ö
Áã´¦ÀíÑÓ³Ù
Óû§½çÃæÅäÉ«·½°¸
¿Éµ÷Õû´óСµÄÓû§½çÃæ
ÊÓÍøÄ¤ºÍHighDPIÖ§³Ö
¼æÈÝÐÔ
Õâ¸öÒôƵ²å¼þ¿ÉÒÔ¼ÓÔØµ½ÈκÎÒôƵÖ÷»úÓ¦ÓóÌÐò£¬·ûºÏAudioUnit»òVST²å¼þ¹æ·¶¡£AAX°æ±¾µÄ²å¼þ¿ÉÒÔÔÚProTools 12+ÖмÓÔØ¡£
´Ë²å¼þ¼æÈÝWindows(32λºÍ64λWindows XP, Vista, 7,8,10ºÍ¸ü¸ß°æ±¾)¼ÆËã»ú(2.5 GHzË«ºË»ò¸ü¿ìµÄ´¦ÀíÆ÷£¬ÖÁÉÙ4 GBµÄϵͳÄڴ棬SSE4.2Ö¸ÁîÖ§³Ö£¬ÀýÈçÈκÎIntel Core i-£¬ AMDÍÆÍÁ»ú-»òzenbase´¦ÀíÆ÷)¡£Ò»¸öµ¥¶ÀµÄ¶þ½øÖÆ·Ö²¼ÎļþÊÇ¿ÉÓÃÓÚÿ¸öÄ¿±ê¼ÆËã»úƽ̨ºÍÒôƵ²å¼þ¹æ·¶¡£Èç¹ûÖ§³ÖÒ»¸öÌØ¶¨µÄ´¦ÀíÆ÷£¬²å¼þ¿ÉÄÜÄÚ²¿ÀûÓÃavx2ÓÅ»¯µÄ´úÂë¡£
¼æÈÝWindows²å¼þÈí¼þ:Cubase, Logic Pro, ProTools, Ableton Live, Reaper, Presonus Studio One, FL Studio, Cakewalk, Nuendo£¬Ð¡²¨£¬GarageBand, Vegas, SoundForge, Audition, Samplitude, Digital Performer, Mixcraft, Bitwig Studio, Edius, others¡£
ʲôÐÂ:
*Ìá¸ßÁËʵʱͼµÄ·Ö±æÂÊ¡£
*¸ÄÉÆÑ¹Ëõ×ÖÌåµÄ¿É¶ÁÐÔ¡£
*ÔÚÔ¤Éè¹ÜÀíÆ÷ÖÐÔö¼ÓÁËÔ¤ÉèÁбíÅÅÐò¹¦ÄÜ¡£
ÖØÐÂÉè¼ÆÁËÐýÅ¥µÄÐÎÏó¡£
*ʹÓÃÑÕÉ«ÐÞ¸ÄÆ÷À©Õ¹ÁË¡°ÑÕÉ«±à¼Æ÷¡±¡£
*Ôö¼ÓÁË¡°»ÒÀ¶É«¡±ºÍ¡°º£¾üÀ¶¡±µÄÅäÉ«·½°¸¡£
TransGainer, an audio effect AAX, AudioUnit and VST plugin suitable for a wide range of professional sound and music production uses, implements an audio signal envelope adjustment algorithm that reacts on transients rather than on a signal¡¯s loudness level. This algorithm allows you to adjust volume of attack and sustain stages of any sounds you use it on. TransGainer was designed in a way to be suitable for all possible sound sources ¨C be it individual tracks or full mixes.
In many cases TransGainer can be used in place of gate and expander plugins while delivering a better sound and offering an easier control. Beside that, TransGainer can be used for audio recording restoration/re-mastering purposes and reverb tail modifications with excellent results.
TransGainer allows you to specify positive or negative gain adjustment for a sound¡¯s transient stage. You can also choose an expected average time between transients and transient threshold level so that the algorithm delivers you the most precise results possible. With the help of TransGainer you can pass the border from good to excellent audio recordings.
Features:
Transient stage loudness adjustments
Four processing algorithms
5 processing modes in the ¡°legacy¡± algorithm
Transient-to-transient time control
Stereo and multi-channel processing
Internal channel routing
Channel grouping
Mid/side processing
Up to 8x oversampling
64-bit floating point processing
Preset manager
Undo/redo history
A/B comparisons
Contextual hint messages
All sample rates support
Zero processing latency
User interface color schemes
Resizable user interface
Retina and HighDPI support
Compatibility
This audio plugin can be loaded into any audio host application that conforms to the AudioUnit or VST plugin specification. Plugins with AAX version available can be loaded in ProTools 12+.
This plugin is compatible with Windows (32- and 64-bit Windows XP, Vista, 7, 8, 10 and later versions) computers (2.5 GHz dual-core or faster processor with at least 4 GB of system RAM, SSE4.2 instructions support required, e.g. any Intel Core i-, AMD Bulldozer- or Zen-based processor). A separate binary distribution file is available for each target computer platform and audio plugin specification. If supported on a specific processor, the plugin may internally utilize AVX2-optimized code.
Compatible Windows plugin software: Cubase, Logic Pro, ProTools, Ableton Live, Reaper, Presonus Studio One, FL Studio, Cakewalk, Nuendo, WaveLab, GarageBand, Vegas, SoundForge, Audition, Samplitude, Digital Performer, Mixcraft, Bitwig Studio, Edius, others.
Whats New:
* Improved the resolution of the real-time graph.
* Improved readability of the condensed font.
* Added the preset list sorting function to the preset manager.
* Redesigned the knob image.
* Extended the ¡°Color Editor¡± with color modifiers.
* Added the ¡°Gray Blue¡± and ¡°Navy¡± color schemes.
