查看: 50812|回复: 0
打印 上一主题 下一主题
[插件] Tube/valve distortion emulation plug-in
跳转到指定楼层
1#
发表于 2020-7-4 21:43:26 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Voxengo Tube Amp
Tube Amp is an audio effect plug-in that applies asymmetric tube triode overdrive usually found in single-tube microphone pre-amp boxes. The sound this plug-in produces varies from a mild "warm" overdrive to a fuzzy distortion. Beside that, Tube Amp includes a -6 dB/oct low-pass filter that is built-in into plug-in's valve modeling equation, and can be used to imitate a lower-quality tube triode.
Tube Amp also features all standard advanced Voxengo plug-in features like full multi-channel operation and built-in oversampling.
Features
* Asymmetric tube triode overdrive
* Multi-channel processing
* Internal channel routing
* Channel grouping
* Mid/side processing
* Up to 8x oversampling
* 64-bit floating point processing
* Preset manager
* Undo/redo history
* A/B comparisons
* Contextual hint messages
下载:http://www.dontcrack.com/freewar ... /software/Tube-Amp/
