MAGIX CoreFX Suite 1.2.2 Win Ч¹ûÆ÷²å¼þ
Óë¾µäѹËõ»úÏà±È£¬Á½µãѹËõ»úÓÐÁ½¸öŤ½áµã¡£ÕâÔÊÐíÄú´´½¨²»Í¬µÄÌØµã£¬²¢Ìṩ¸ü¶àµÄ×ÔÓÉʱѹËõ¶¯Ì¬·¶Î§¡£
coreFXÏÞ·ùÆ÷
ÏÞÖÆÆ÷ÉèÖô¦Àí¹ýµÄÒôƵÐÅºÅµçÆ½µÄ×î´óÖµ£¬È»ºó²»»á³¬¹ýÕâ¸ö×î´óÖµ¡£ÒôÁ¿²îÒì±»Ïû³ý£¬Ê¹³³ÄֺͰ²¾²µÄ²¿·Ö±»Æ½Õû¡£
coreFXÀ©ÕÅÆ÷
ÒÖÖÆÔëÉùºÍÔö¼ÓÄúµÄ·¶Î§£¬ÒòΪÒôƵÐźŵĶ¯Ì¬Ôö¼ÓÁËÒ»¸ö¸ü×ÔÈ»µÄÉùÒô¡£
coreFXѹËõ»ú
ѹËõÒôƵÐźŵĶ¯Ì¬·¶Î§£¬Ïû³ýÈíͨµÀºÍ´óÉùͨµÀÖ®¼äµÄÒôÁ¿²îÒì¡£
coreFXÃÅ
¸ÃÃÅÓÃÓÚÒÖÖÆÐźŴ«ÊäÖеݲ¾²²¿·Ö¡£ÕâÑù¿ÉÒÔÏû³ýÔëÒô£¬²úÉú¸É¾»µÄÉùÒô¡£
coreFXÑÓ³Ù
ÖÆÔìÑӳٵĻØÉù¡£¼òµ¥ÑÓ³ÙЧӦÊÇ»ùÓÚÄ£Äâµç·ºÍ²úÉúÑÓʱ¸±±¾µÄÔʼÊäÈëÐźţ¬ÒÔ²úÉú»Ø²¨Ð§Ó¦¡£
coreFXºÏ³ª
ΪÁË·¢³ö¸ü±¥ÂúµÄÉùÒô£¬ºÏ³ªÍÅ»á²úÉúÒ»¸ö´øÓÐÇá΢Òô¸ß²îÒìµÄÒôƵÐźŵÄÑÓʱ¸±±¾¡£ÕâÑù¾Í²úÉúÁËÒ»Öֿɲì¾õµÄ±¶ÔöºÍÇôòЧ¹û¡£
coreFXÏâ±ß
Flanger´´ÔìÁËÒ»ÖÖ¶¯Ì¬µÄ£¬¸üÀäµÄÉùÒô¡£Í¨¹ýµþ¼ÓÔʼÐźźÍËüµÄÑÓʱ¿½±´£¬Îª¾µäµÄ¡°ÂþÓΡ±ÉùÒô´´ÔìÁËɨƵЧ¹û¡£
ƽ̨:WiN32/64 ¨C VST
ʲôÐÂ:
¸üÐÂ:¹Ù·½ÍøÕ¾²»ÌṩÈκιØÓÚÕâ¸ö°æ±¾±ä»¯µÄÐÅÏ¢¡£
Compared to a classic compressor, a 2-point compressor has two kink points. This allows you to create different characteristics and offers more freedom when compressing dynamic range.
coreFX Limiter
The limiter sets the maximum value of the processed audio signal level, which then won¡¯t be exceeded. Volume differences are eliminated, so that loud and quiet sections are levelled out.
coreFX Expander
Suppress noise and increase your range, as the dynamics of the audio signal are increased for a more natural sound.
coreFX Compressor
Compress the dynamic range of an audio signal and eliminate volume differences between soft and loud passages.
coreFX Gate
The gate is used to suppress quiet sections in the signal transmission. This removes noise and produces a clean sound.
coreFX Delay
Create echoes with the Delay. The simple delay effect is based on analog circuits and produces time-delayed copies of the original input signal to create the echo effect.
coreFX Chorus
For a fuller sound, Chorus produces a time-delayed duplicate of the audio signal with a slight pitch difference. A perceptible doubling and beating effect is created.
coreFX Flanger
The Flanger creates a dynamic, colder sound. By superimposing the original signal and its time-delayed copies, sweeping effects are created for the classic ¡®wandering¡¯ sound.
Platform: WiN32/64 ¨C VST
Whats New:
Updates: official site does not provide any info about changes in this version.
File size: 8.4 MB |
