izotope Stutter Edit 2 v2.0.0 macOS-XDIE MIDI¿ØÖÆÆ÷
nakasi
2020-7-2 09:55:38
midi
´´½¨¼´Ê±½á°ÍЧ¹û:´ÓBTµÄÏë·¨£¬½á°Í±à¼­2ÈÃÄã´´½¨ÖøÃûµÄ¡°½á°Í¡±±à¼­Ð§¹ûÓëÒ»¸ö°´Å¥£¬ÇÐÆ¬ºÍ÷»×ÓÄãµÄÑù±¾£¬¹ìµÀ£¬ºÍ»ìºÏ¡£ÌáÉýÄãµÄÉùÒô£¬²¢µÃµ½Ò»¸öÎÞµ×¾®µÄÁé¸ÐÔÚÒ»¸öµ¥Ò»µÄ²å¼þ¡£
middi¿ØÖƵĽÚ×àºÍÒô¸ßЧ¹û
ʹÓÃStutter Edit 2£¬Ìí¼ÓÒÆ¶¯µ½ÄãµÄ»ìºÏ´ÓÀ´Ã»ÓиüÈÝÒס£Ì½Ë÷ÐµĹ¦ÄÜ£¬Èç×Ô¶¯Ä£Ê½£¬·è¿ñµÄÐÂЧ¹ûÄ£¿é£¬ÇúÏ߱༭Æ÷¡£
Ó°ÏìÔ½´ó£¬Ç±Á¦Ô½´ó
×¢ÈëеÄÑÕÉ«ºÍÎÆÀíµ½ÄúµÄÒôÀÖÓëеÄЧ¹ûÄ£¿éºÍÎÞÏ޵ĿÉÄÜÐÔÓëеÄÇúÏ߱༭Æ÷¡£
ÊýÊ®¼ÒеÄÒøÐкÍ×Ë̬
Ó¢¹úµçÐÅÉè¼ÆµÄÐÂÔ¤É裬ÌṩÁ˷ḻµÄЧ¹û£¬Ïë·¨ºÍÉùÒô£¬ÔÚÄãµÄÖ¸¼â¡£
Ϊʲô»á½á°Í±à¼­2?
Ö»ÐèÒ»´Î»÷¼ü¾Í¿ÉÒÔ½øÐÐÊýСʱµÄ±à¼­
¼´Ê±´´½¨¸´ÔӵĽÚ×àЧ¹ûÓëеÄ×Ô¶¯Ä£Ê½¡£Fire off effects on the fly»òʹÓÃMIDI¿ØÖÆÆ÷·ÃÎʼ¸Ê®¸öÊÖÊÆÓëÒ»¸ö¼üµÄ´¥Ãþ¡£
´´ÔìһЩ·è¿ñµÄÐÂЧ¹û
Ò»¸öеĻìÏ죬ÊᣬºÍºÏ³ªÄ£¿é¼ÓÈëÁË11¸ö·è¿ñµÄЧ¹û£¬¿ÉÒÔËæÄãµÄ»ìºÏʱ¼äÒÆ¶¯¡£½áºÏÄúµÄ¿Ú³Ô±à¼­ÓëÇÖÂÔÐÔŤÇú£¬×Ô¶¯Æ½ÒÆÐ§¹û£¬Çãб»ìÏ죬ºÍ¸ü¶à¡£
¶ÀÒ»ÎÞ¶þµÄÉùÒô£¬Í¨¹ýеÄÇúÏ߱༭Æ÷
µã»÷±à¼­2ÖеÄÈκλ¬¿éÀ´±à¼­Æä¶ÀÌØµÄÇúÏß¡£¿ØÖÆÄãµÄ¹ø£¬½á°Í£¬ÃÅ£¬Å¤ÇúºÍ¸ü¶àµÄʱ¼äÀ´´´ÔìÕæÕýÁîÈ˷ѽâµÄЧ¹û¡£Ã¿Ò»¸ö²ÎÊý¶¼ÊÇÄãµÄÓÎÀÖ³¡!
Õâ¸ö°æ±¾ÓÐʲôеĵط½:
¹Ù·½ÍøÕ¾²»ÌṩÈκιØÓڴ˰汾±ä»¯µÄÐÅÏ¢¡£
ϵͳÐèÇó
Mac: High Sierra (10.13) ¨C macOS Catalina (10.15)
²å¼þ¸ñʽ:
AU AAX VST2 VST3¡£ËùÓвå¼þ¸ñʽ¶¼ÊÇ64λµÄ¡£
Ö§³ÖÖ÷»ú:
Logic Pro X, Live 9.7-10, Cubase 9.5-10.5, Pro Tools 12-2020, FL Studio 20, Studio One 4, REAPER 6, Reason 11, Bitwig Studio 3, Cakewalk by Bandlab, Digital Performer 10¡£
CREATE INSTANT STUTTER EFFECTS: From the mind of BT, Stutter Edit 2 lets you create the famous ¡°stutter¡± editing effect with one button to slice and dice your samples, tracks, and mixes. Elevate your sound and get a bottomless well of inspiration in a single plug-in.
MIDI-controlled rhythm and pitch effects
With Stutter Edit 2, adding movement to your mix has never been easier. Explore new features like Auto Mode, insane new effects modules, and the Curve editor.
More effects, more potential
Inject new colors and textures into your music with new effects modules and limitless possibilities with the new Curve Editor.
Dozens of new banks and gestures
New presets designed by BT deliver a wealth of effects, ideas, and sounds right at your fingertips.
Why Stutter Edit 2?
Hours of editing with a single keystroke
Instantly create complex rhythmic effects with the new Auto mode. Fire off effects on the fly or use a MIDI controller to access dozens of gestures with the touch of a key.
Get creative with insane new effects
A new Reverb, Comb, and Chorus module join a suite of 11 insane effects that can move in time with your mix. Combine your stutter edits with aggressive distortion, auto-pan effects, pitch-bent reverb, and much more.
One-of-a-kind sounds via the new Curve editor
Click any slider in Stutter Edit 2 to edit its unique curve. Control the timing of your pans, stutters, gates, distortions, and more to create truly mind-bending effects. Every parameter is your playground!
Whats new in this version:
Official site does not provide any info about changes in this version.
System Requirements
Plugin Formats:
AU, AAX, VST2, VST3. All plug-in formats are 64-bit only.
Supported Hosts:
Logic Pro X, Live 9.7¨C10, Cubase 9.5¨C10.5, Pro Tools 12¨C2020, FL Studio 20, Studio One 4, REAPER 6, Reason 11, Bitwig Studio 3, Cakewalk by Bandlab, Digital Performer 10.
XDIE | 30 June 2020 | vst2 vst3 component | 70 MB
Download rapidgator
https://rg.to/file/96e478e1c5e51 ... acOS-XDIE_.zip.html
Download nitroflare
https://nitroflare.com/view/5910 ... 0.0_macOS-XDIE_.zip
izotope Stutter Edit 2 v2.0.0 macOS-XDIE MIDI¿ØÖÆÆ÷.txt (123 Bytes, ÏÂÔØ´ÎÊý: 0)
