Ïì¶È±ê×¼Êý¾Ý²âÁ¿²å¼þTBProAudio dpMeterXT2 v2.0.1 WiN
nakasiband
2020-7-2 09:22:27
Ïì¶È±ê×¼Êý¾Ý²âÁ¿²å¼þ  TBProAudio dpMeterXT2 v2.0.1 WiN
dpMeterXT2ÊÇÒ»¸öÏì¶È²âÁ¿²å¼þºÍÓ¦ÓóÌÐòÍêÈ«·ûºÏEBU R128-2014, ITU-R BS.1770-4, ATSC a /85ºÍÆäËûµØÇøÌض¨µÄÏì¶È±ê×¼¡£
dpMeterXT2ÊÇdpMeterXTµÄsucessor¡£
dpMeterXT2Ö§³Ö¶àÖÖͨµÀÅäÖ㬴Ó1.0µ½9.1/10.0£¬¾ßÌåÈ¡¾öÓÚÄúµÄϵͳÅäÖûòDAW¹¦ÄÜ¡£ebur128
Ëü¾ßÓдó¶ÁÊý¡¢ÒÇ±í¡¢Í¼±í¡¢Ïì¶È/·åÖµÔ¤²â¡¢²âÁ¿ÀúÊ·ºÍÊý¾Ý¼Ç¼¡£
ʹÓÃdpMeterXT2£¬Äú¿ÉÒԷdz£ÏêϸµØ¶¨Òå²âÁ¿²ÎÊý(¼´¼¯³Éʱ¼ä¡¢Ãſؼ¶±ð¡¢Â˲¨Æ÷)¡£
dpMeterXT2 is a loudness metering plugin and application fully compliant with the EBU R128-2014, ITU-R BS.1770-4, ATSC A/85 and several other regionspecific loudness standards.
dpMeterXT2 is the sucessor of dpMeterXT.
dpMeterXT2 supports multiple channel configurations, from 1.0 up to 9.1/10.0, depending on your system configuration or DAW capabilities.EBUR128
It features large readouts, meters, graphs, loudness/peak prediction, measurement history and datalogging.
With dpMeterXT2, you can define the measurement parameters in a very detailed way (i.a. integration time, gating levels, filter).
home page:
https://www.tb-software.com/TBProAudio/
