Ò»¿î¿ÉÒÔÈÃÄãÖ»ÐèҪһ̨ iPad/iPhone ¾Í¿ÉÒÔʵÏÖÄãµÄÒôÀÖÃεÄÈí¼þ¡£ËüÄÚÖÃÁËÒ»¸±¸ÖÇÙ¼üÅÌ£¬ÒÔ¼° 65 ÖÖ²»Í¬µÄÀÖÆ÷£¬127 ¹ìµÄÒôÐòÆ÷¾ø¶ÔÄÜÂú×ãÄãµÄ±à¼ÐèÒª£¬»¹ÓбʼDZ¾¹¦ÄÜ£¬²¢ÇÒÖ§³ÖÊµÊ±ÌØÐ§¡£7 ]* A% Z7 A% R6 U2 I U' {
; L4 M4 t" L: H7 q! e6 _$ Z3 _
& ]& K! J# i0 Q0 N
, B8 S8 Q. D' D7 i
FEATURES8 i9 }/ M4 m" ?5 v. v: w7 A
• Photorealistic dynamically configurable 85-key keyboard
$ I& B$ g. Y. V0 L# r! a• Instant positioning via the slide gesture and resize with the pinch gesture" `# K3 z& f) J* D" e8 C
• Drum pads, chord pads and chord programming
0 T' ] P% c/ j! L• 125 studio-recorded instruments (16bit 44.1kHz sampled from real instruments)
9 x: ]: h* B+ f; w• 65 free instruments, 60 available in the in-app shop' e( K! E; n) Y# E" g/ T+ U1 ?
• 4 categories: classic, band, electronic, world
# w" \- w! a) f% o" [• Release and attack time configurable per instrument( _. P9 \0 Y/ e: j4 ?* P
• Sustain samples
: O$ l! t8 D9 H' q% X• Pitch bend wheel and accelerometer control* K! L5 b/ p, j6 G
• Audio tracks:% @& W/ J7 m1 z ?$ Z9 S" r" f/ P
• Microphone recording
9 f# v7 e8 x, S& ~8 K8 k• AudioCopy & AudioPaste+ X0 n d) I6 a6 e
• iPod library or wav/mp3/AAC/ogg file import' t1 V4 q0 l' V3 D- H- i# o6 G) j
• Waveform and audio region editing) d, j$ H6 j) k4 [- M( Z
• Low-latency, highly optimized, 64x polyphony, battery saving audio engine
+ L7 D6 x& d/ o8 I: h5 c$ F* Q+ Y& w• 100 drum loops0 z5 U/ R# }( \! I# z# Y, s# m
• 5 real-time effects with lots of parameters:/ {1 D5 `' R+ s. g0 d4 u4 }
3 high-quality reverb algorithms, delay, 3-band equalizer, amplifier, filter
5 b; o k& _ p5 B$ r• 127-track sequencer3 i- d, B8 g5 P" F! k
• Beat & metronome settings (tempo and signature)! S, u3 G* B# o7 L+ I
• Mute, solo, effect bus, pan and volume adjustment for each track
( w4 y/ L# p" M- i/ @8 V7 l3 k• Edit tracks, bars and even individual notes:5 b6 {1 ^* m; W
Draw, quantize, transpose, repeat, move, length, velocity, etc.
- n2 i9 ^5 L2 T0 L1 q- M• MIDI import and export
# S, D# K- c4 m4 U% Y! o: X• Save and load your songs and export to wav and AAC formats
2 L! E& M2 D* s% ~" T- A• Share your songs via email, AudioCopy and SoundCloud( e# F$ E, c# z! W& u _
• Wi-Fi and iTunes file transfer to your computer9 R, Y3 g, B: z: v; u
• Songs and MIDI files can be opened directly from Safari and Mail
g3 C- ^: u2 B( r8 G+ Y• Unlimited undo and redo. @# _, o* `* S+ k6 L0 l! o0 Y
• Detailed in-app help
5 T; y0 |8 t- d4 {, T1 m! z2 E0 @1 P• Play or record 2 different instruments at the same time with 2 keyboard rows6 b8 n5 q& Q( J( R/ \" J
• iPhone 4 Retina Display supported1 L0 }# c" J5 y4 R% \3 k6 \
• Compatible with: CoreMIDI (MIDI in and out), Line 6 MIDI Mobilizer I & II, Akai SynthStation 25, iRig, iRig Mic, iRig MIDI, Ampkit Link, Apogee Jam, Blue Mikey, Alesis IO Dock and iConnectMIDI
) h8 q! R4 p+ I; ]' J
& d- H- ^: R J$ |
- n7 G" F6 T+ ^3 a G$ I" R* ?( Z
( N& V5 i, {# J+ g$ N
$ i4 {! I9 B: h4 L1 n) J, t+ P: u2 H$ r% O4 G& u: K
°æ±¾ 2.6.2 ÖеÄй¦ÄÜ
: O z' ~) M- Q; d' B" Q8 Q4 e1 c2 N: z; z+ I# \: b( n) l7 Y
- iOS 9 compatibility$ z' \0 F5 ]8 f7 Z L6 i( r
- Bug fixes |
