Ö¸ÏòÐÔ: | ÐÄÐÍ |
¹¤×÷ÔÀí: | ѹÁ¦ÌݶÈʽ, with interference tube |
ʰÒôÍ·ÀàÐÍ: | Pre-polarized condenser, Twin Diaphragm Capsule |
ƵÂÊ·¶Î§: | 20 Hz - 20 kHz |
ƵÂÊ·¶Î§, ¡À 2 dB, at 30 cm: | 50 Hz - 17 kHz with 3 dB soft boost at 12 kHz |
ÁéÃô¶È, ±ê³Æ, ¡À 2 dB at 1 kHz: | 10 mV/Pa; -40 dB re. 1 V/Pa |
µÈЧÔëÉù¼¶, A-¼ÓȨ: | Typ. 20 dB(A) re. 20 ?Pa (max. 23 dB(A)) |
µÈЧÔëÉù¼¶, ITU-R BS.468-4: | Typ. 33 dB (max. 36 dB) |
ÐÅÔë±È (A-weighted), re. 1 kHz at 1 Pa (94 dB SPL): | Typ. 74 dB(A) |
×Üг²¨Ê§Õæ (THD) at 1 kHz: | < 1 % up to 137 dB SPL peak |
¶¯Ì¬·¶Î§: | Typ. 117 dB |
×î´óÉùѹ¼¶, Ï÷²¨Ö®Ç°µÄ·åÖµ: | 146 dB |
×îС¸ºÔØ×迹: | 2 kohm |
Êä³ö×迹: | < 200 ohm |
ÏßÀÂÇý¶¯ÄÜÁ¦: | 100 m (328 ft) |
ƽºâÊä³öÔÀí: | Impedance balancing with Active Drive |
¹²Ì¬ÒÖÖ½±È(CMRR): | > 50 dB |
¹©µçµçÔ´ (for full specifications): | 48 V Phantom power (¡À 4 V) |
µçÁ÷ÏûºÄ: | 2.8 mA |
Á¬½Ó·½Ê½: | XLR-3M. Pin 1: shield, Pin 2: signal + phase, Pin 3: - phase |
ÑÕÉ«: | Matte black |
ÖØÁ¿: | 64 g (2.3 oz) |
»°Í²Ö±¾¶: | 19 mm (0.75 in) |
»°Í²³¤¶È: | 92 mm (3.6 in) |
Êä³öµçѹÓÐЧֵ: | > 4 V |
¼«ÐÔ: | +V at pin 2 for positive sound pressure |
ζȷ¶Î§: | -40 ¡ãC to 45 ¡ãC (-40 ¡ãF to 113 ¡ãF) |
Ïà¶Ôʪ¶È(RH): | Up to 90% |
ÁéÃô¶ÈÑ¡Ôñ¹«²î (at 1 kHz): | ¡À 1.5 dB |
