Ilya Efimov Production Uilleann Pipes
Uilleann PipesÊǰ®¶ûÀ¼µÄ¹ú¼Ò·çµÑÀÖÆ÷¡£ÕâÊÇÒ»¸ö²»Í¬Ñ°³£µÄ¸´ÔÓ¹¹Ô죬 ÒªÇóÑÝ×àÕß¶ÔÆäÑÝ×༼ÇɱØÐë¾ßÓÐÒ»¶¨µÄÕÆÎÕ£¬ ÓµÓд˿â»áÈÃÄãµÄ´´×÷±äµÃÈÝÒ×Ò»·«·ç˳£¡
ÔÚÎÒÃǵÄÒôÉ«¿â£¬ÎÒÃDzɼ¯ÁËÁ½¸öÍêÕûµÄ°Ë¶ÈÒô½×£¬Ö÷ÒªÊÇÀÖÆ÷µÄ»ÉƬ£¬°üÀ¨¿ìËÙºÍÂýËÙµÄlegatoÒô·û£¬ÒÔ¼°ÆäËû·¢Òô£¬Èç²üÒô£¬ÉùÒôºÍ·¢Òô¡£ legatoËÙ¶È¿ÉÒÔͨ¹ýÈýÖÖ·½Ê½½øÐпØÖÆ - ͨ¹ý°´¼ü¿ª¹Ø£¬midi¿ØÖÆÆ÷»òËÙ¶ÈÁéÃô¶È¡£
ÔÎÄ
The Uilleann Pipes are the national bagpipe instrument of Ireland. It¡¯s unusual and complex one in its construction, requiring from a player quite a bit of mastership. With this library - a complicated instrument like the Uilleann Pipes ¨C now becomes easy available to anybody!
In our library we sampled two full octaves for the chanter ¨C main instrument¡¯s reed, including fast and slow legato notes, as well as other articulation like vibrato, staccato and mordents. The legato speed can be control in three ways ¨C through a keyswitch, midi-controller or velocity sensitivity.
Another outstanding feature of the library - a special range on keyboard for playing regulators and regulators¡¯ chords like a real bagpiper usually does it with his wrist accompanying chanter¡¯s melody with simple harmonic backing. But for you it will be no intricacy - just use your left hand like on a piano.
Usually the Uilleann Pipes¡¯ drones are tuned to D key and thus their regulators can produce only certain notes. We removed that limitation! You can choose any tonality to perform in. Also the regulators range was extended to a chromatic scale. Plus we designed the suitable ways to turn on/off drones, bellows noise and other bagpipe FXs, which help to provide the realistic sound of the library. With this library you are given at your disposal the unique reeds¡¯ blend and harmonic structure of the complex Uilleann Pipes, which are famous of sounding sweeter and quieter than many other bagpipes.
Features:
• 750 samples, 44,1 Hz/24 bit, stereo
• 2 natural legato types: normal and glissando
• 8 different articulations
• Two vibrato types
• Control of realistic vibrato ¨C its amount and speed
• 6 round-robim realistic staccato
• Reassignable keyswitches and midi-controllers
• 3 modes of legato performance
• Drones start, tune and volume control
• Chromatic scale for regulator keys
Requirements:
• Native Instruments FULL RETAIL Kontakt +5.6 or later
Ilya Efimov Production Uilleann Pipes KONTAKT | 576 Mb
ÏÂÔØµØÖ·£ºÓοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë »Ø¸´ |
