Neumann Solution-D Êý×Ö»°Í²
ÆäËü²úÆ·
Neumann Solution-D Êý×Ö»°Í²ÊÛ¼Û£º£¤75450Ôª
Neumann ÍÆ³öµÄÊý×Ö»°Í²½â¾ö·½°¸Solution D»ñ2001ÄêPAR´ó½±¡£ÆäÓÉÊý×Ö»°Í²D-01¡¢Êý×Ö»°Í²½Ó¿ÚDMI-2ºÍÔ¶³Ì¿ØÖÆÈí¼þRCS×é³É¡£RCSÔ¶³Ì¿ØÖƿɶÔÂó¿Ë·ç½øÐеÍÇС¢Ö¸ÏòÑ¡ÔñµÄ¿ØÖÆ£¬²¢ÌṩÁËÓû§Í¼ÐνçÃæ¡¢µçƽÏÔʾÆ÷£¬ºÍ¶ÔÉèÖõı£´æ¹¦ÄÜ¡£
ÐÔÄÜÖ¸±ê£º
ÉùÒô¹¤×÷Ô­Àí£ºÑ¹Á¦Ìݶȴ«¸ÐÆ÷
ÁéÃô¶È£¨CCIR 468-3£©£º18dB
ÁéÃô¶È£¨DIN/IEC 651£©£º7dB-A
S/N±È£¨CCIR 468-3£©£º76dB
S/N±È£¨DIN/IEC 651£©£º87dB
´«¸ÐÆ÷DIN/IEC 651¶¯Ì¬·¶Î§£º130dB
A/Dת»»£ºNeumann¼¼Êõ£¬28Bit
²ÉÑùrates£º44.1 kHz /48 kHz / 96 kHz / 88.2 kHz
»°Í²Êä³ö£ºXLR 3 M,
ÖØÁ¿£º700¿Ë
Ö±¾¶£º63.5ºÁÃ×
³¤¶È£º185ºÁÃ×
DMI-2¼¼ÊõÖ¸±ê£º
ƵµÀÊýÁ¿£º2
ÊäÈ룺XLR 3 F, AES 42-2001 Êý¾Ý¸ñʽ
Êä³ö£ºXLR 3 M, AES 3-1992 Êý¾Ý¸ñʽ
»ÃÏ󹩵磺+ 10 VDC, µ¥Æµ×î´óµçÁ÷250 mA
Ô¶³Ì¿ØÖÆÊý¾Ý£º750 Bit/s Âö³å¼ÓÔØÓÚ»ÃÏóµçÔ´
¿ØÖÆ×ÜÏߣº2 ¸öRJ45 ²å×ù
У׼£ºAES 42 - Mode 2£¬Í¨¹ýPLL½øÐÐʱÖÓ¿ØÖÆ£»AES 42 - Mode 1£¬Ê±ÖÓÔÚÖÐÆµ×ÔÓÉÔËÐУ¬½ÓÊÕ·½ÐèÓÐSRC£¨Sample Rate Converter£©
Word ClockÊäÈ룺BNC, 75 Ohm.
Word ClockÊä³ö£ºBNC, 75 Ohm.
µçÔ´¹©Ó¦£º100-240 V, 50/60 Hz
Ìå»ý£º(W x H x D) 218 x 56 x 163 mm
