¸´¹Å¹ÄºÏ³ÉÆ÷
Beatskillz Synthwave Drums ¼ò½é£º
Beatskillz Synthwave Drums for MacÊÇÒ»¿î¸´¹Å¹ÄºÏ³ÉÆ÷¡£ÊÇ20ÊÀ¼Í60Äê´ú80Äê´ú¹ÄÉùµÄ¸´ÐË£¬²¢×ñѸ´¹ÅÖÆ×÷·ç¸ñµÄÔÔò¡£Synth wave Drums²»½öΪÄú´øÀ´ÁËËùÓÐÁ÷ÐеĹÄWavesfactory Cassette»úÉùÒô£¬¶øAcon Digital VerberateÇÒ»¹´øÀ´¸ÉÉùºÍ´¦ÀíAcon Digital Verberate°æ±¾£¬MusicLab RealGuitarÌýÆðÀ´¾ÍÏñÄúÌý¹ýµÄ³ªÆ¬Ò»Ñù¡£ÕâÓÐÖúÓÚ½â¾öÕâЩÃüÖÐÉùÒô±³ºóµÄ¡°´¦ÀíÖ®ÃÕ¡±¡£Í¨³£µ±Ä㹺Âò¹Ä»úµÄ·ÂÕæ»òÑùƷʱ£¬ÉùÒôÌ«Ôʼ£¬ÌýÆðÀ´¾ÍÏñÊÇÕâÖÖÀàÐ͵ÄÉùÒô¡£
80s / Synthwave¹ÄRompler
80Äê´ú¶¨ÒåÁËºÏ³ÉÆ÷ºÍ¹Ä»úµÄʱ´ú¡£ÕâÊÇΰ´óµÄÒôÀÖ¼ÒÃÇͻȻӵÓеç×ÓÀÖÆ÷µÄʱ´ú£¬Ò»ÖÖеÄÒôÀÖÀàÐ͵õ½ÁË·¢Õ¹¡£Ä³Ð©¹Ä»ú¶¨Ò岢ʹ80sÌýÆðÀ´Á¢¼´¿Éʶ±ð¡£ÕâЩ¹ÄÉùÀ´×ÔÔçÆÚµÄ²ÉÑùÆ÷ºÍÄ£ÄâºÏ³É¡£Romplers / Samplers·Ö±ðΪ8λºÍ12룬²¢ÇÒÈκηÅÈëÆäÖеÄÑù±¾ÌýÆðÀ´¶¼ÊÇ¡°¶ÀÌØµÄ¡±£¬ÌýÆðÀ´²»ÏñÔʼ¼Òô¡£½ÏµÍµÄ10-22khz²ÉÑùÂʺÍÔçÆÚµÄD / Aת»»Æ÷ÔÚ¶¨Òå¹Ä»úÉùÒô·½ÃæÒ²·¢»ÓÁËÖØÒª×÷Óã¡
SYNTHWAVE¹ÄÊÇ20ÊÀ¼Í80Äê´ú80Äê´ú¹ÄÉùµÄ¸´ÐË£¬²¢×ñѸ´¹ÅÖÆ×÷·ç¸ñµÄÔÔò¡£Synth wave Drums²»½öΪÄú´øÀ´ÁËËùÓÐÁ÷ÐеĹĻúÉùÒô£¬¶øÇÒ»¹´øÀ´¸ÉÉùºÍ´¦Àí°æ±¾£¬ÌýÆðÀ´¾ÍÏñÄúÌý¹ýµÄ³ªÆ¬Ò»Ñù¡£ÕâÓÐÖúÓÚ½â¾öÕâЩÃüÖÐÉùÒô±³ºóµÄ¡°´¦ÀíÖ®ÃÕ¡±¡£Í¨³£µ±Ä㹺Âò¹Ä»úµÄ·ÂÕæ»òÑùƷʱ£¬ÉùÒôÌ«Ôʼ£¬ÌýÆðÀ´¾ÍÏñÊÇÕâÖÖÀàÐ͵ÄÉùÒô¡£
ÎÒÃÇΪÄúÍê³ÉÁ˼è¿àµÄ¹¤×÷£¬²¢ÎªÄúÌṩÁ˳¬¹ý100¸öÔ¤Éè¿â£¬Ã¿¸öÔ¤Éè12¸öÉùÒô¡£ÕâÊdz¬¹ý1200¹ÄÉù£¡
ÎÒÃDz»½ö½öÍ£ÁôÔÚÄÇÀÎÒÃǵIJå¼þGUIÖ¼ÔÚ¼¤·¢ÄúµÄÁé¸Ð£¬Ê¹Äú¸ÐÊܵ½¡°ºÏ³É²¨¡±
PADS£¨12¸ö¹Äµæ£©
ÿ¸öÌ×¼þµÄ12¸ö¹ÄÑù±¾´Ó¼üC1Ó³Éäµ½B2
Ì×¼þ1- 63ÔÚ12¸ö°´¼üÉ϶¼ÓС°¹ÄÐÍ¡±Ó³É䣬ËùÒÔÕâЩÌ×¼þ¿ÉÒÔ½»»»£¬Ìߣ¬Ð¡¹Ä£¬Ã±×ӵȶ¼ÔÚͬһ°ÑÔ¿³×ÉÏ¡£
c1Ìß1
c££1Ìß2
d1ȦÌ×1
d££1ȦÌ×2
e1ÅÄÊÖ
f 1îà
f££1Îû¹þ1
g1 tom 1
g ££1ϲñ2
A2ÌÀÄ·2
££2´ò»÷ÀÖÆ÷1
B2´ò»÷ÀÖÆ÷2
È«¾ÖЧ¹û
1£©PITCH
2£©»ìÏì
3£©VOLUME
PER PAD CNTRL
1£©VOLUME
2£©PAN
3£©RELEASE
PRESET BANKS
*ÿ¸öÌ×¼þ/ÒøÐаüº¬12¹ÄÉù
63 MULTI DRUM KITS
13 KICK SNARE×éºÏÊÔ¼ÁºÐ
5ÅÄÊÖBANKS
4 CYMBALS BANKS
8 HI HAT BANKS
4 PERCUSSION BANKS
2·´ÏòÉùÒôÒøÐÐ
2·´ÏòCYBAL BANKS
12 TOMS BANKS
*°üº¬×ܹ²113¸öÉùÒôÌ×¼þ/ BANKS
¹²1356¹Äµ¥ÉùµÀ
* .WAVһǹËùÓÐÑùÆ·µÄÎļþ¼ÐÒ²°üÀ¨
¹Ù·½¼ò½é£º
Beatskillz Synthwave Drums is a resurgence of the 80s drum sound in the 2010s and follows the principals of the retro production styles. Synth wave Drums not only brings you all the popular drum machine sounds, but also brings dry and processed versions that sound exactly like the records you¡¯ve heard. This helps in solving the ¡°processing mystery¡± behind these hit sounds. Often when you buy emulations or samples of just the drum machines, the sounds are too raw and sound nothing like the sounds of the genre.
80s / Synthwave Drums Rompler
The 80s defined the era of Synthesizers and Drum Machines. This is the time when great musicians suddenly had electronic instruments at their disposal, and a new genre of music evolved. Certain drum machines defined and made the 80s sound instantly recognizable. These drum sounds came from early samplers and analog synthesis. Romplers/ Samplers were 8 and 12 bit and made any sample put into them sound ¡°unique¡± and it did not sound like the original recording. Lower sample rates of 10-22khz and early D/A converters also played an important role in defining the Drum Machine Sound!
We¡¯ve done the hard work for you and given you over 100 preset banks of 12 sounds per preset. That¡¯s over 1200 drum sounds!
We didn¡¯t just stop there, our plugin GUI has been designed to inspire you and put you in the mood for ¡°synth wave¡±
PADS ( 12 drum pads )
The 12 drum samples per kit are mapped from keys C1 to B2
The Kits 1- 63 have ¡°drum-type¡± mapping on each of the 12 keys, so these kits can be swapped and kick, snare, hats etc will be on the same keys.
c1 kick 1
c#1 kick 2
d1 snare 1
d#1 snare 2
e1 clap
f 1 cymbal
f#1 hi hat 1
g1 tom 1
g#1 hi hat 2
a2 tom 2
a#2 percussion 1
b2 percussion 2
GLOBAL EFFECTS
1) PITCH
2) REVERB
3) VOLUME
PER PAD CNTRL
1) VOLUME
2) PAN
3) RELEASE
PRESET BANKS
*Each Kit / Bank contains 12 drum sounds
63 MULTI DRUM KITS
13 KICK SNARE COMBO KITS
5 CLAPS BANKS
4 CYMBALS BANKS
8 HI HAT BANKS
4 PERCUSSION BANKS
2 REVERSE SOUNDS BANKS
2 REVERSE CYMBAL BANKS
12 TOMS BANKS
*Contains a TOTAL of 113 Sound KITS/ BANKS
A total of 1356 Drum One Shot Sounds
* .WAV one shot folder of all samples also included
Beatskillz Synthwave Drums 1.0.0 (CR).txt
(144 Bytes, ÏÂÔØ´ÎÊý: 0)
