¾µäÀà±ÈÉùÏì´ÓδÈç´ËÈÝÒ×Я´ø
Prophet-6 ×À»ú°æÏ൱ǿ´ó¡¢Ò×Óã¬ÈçͬÁíÒ»¸öProphet-6 ¼üÅ̰æ»úÐÍ£¬ÊÂʵÉÏ£¬Õâ´ÎÍÆ³öµÄ×À»ú°æÓë֮ǰµÄ¼üÅ̰漸ºõÎÞÒ죺
ÔÚÍâ¹ÛÉÏ£¬Á½Õß½ÔÓÐÏàͬµÄÈ«³ß´ç²ÎÊýÐýÅ¥ÒÔ¼°°´¼ü£¬ÄÚ²¿ÔòÓÐÏàͬµÄÀà±È»ØÂ·£¬Á¬½Ó×ÅÏàͬµÄVCOs ÒÔ¼°VCFs £¬ÒÔ¼°ÏàͬµÄÊýλEffects £¬¶øÀíËùµ±È»µÄ£¬×À»ú°æÒ²Äܹ»·¢³öºÍ¼üÅ̰æÏàͬµÄ¡¢ÈÃʹÓÃÕßÔÞÓþÓмӵľµäÀà±ÈÉùÏì¡£
²»Í¬Ö®´¦ÔÚÓÚ£¬ Prophet-6 Õâ´Î´îÔØÁËȫеÄPoly Chain Á¬½á·½Ê½£¬Äܹ»ÈÃÁ½Ì¨Prophet-6 Á¬½ÓÔÚÒ»Æð£¬³ÉΪһ̨ÄÜ´ïµ½12 ·¢ÉùÊýµÄÀà±ÈºÏ³ÉÆ÷¡£
¾µäÓëÏÖ´úµÄ½áºÏ
ÎÞÂÛÊÇ×À»ú»òÊǼüÅ̰æµÄProphet-6 ½Ô²»½ö½öÖ»ÊǸ´¿Ì»òÖ¾´¾µäµÄ¶à·¢ÉùÊýÀà±ÈºÏ³ÉÆ÷Prophet-5 £¬ Dave Smith ±¾ÈËÊÇÕâôÐÎÈÝProphet-6 µÄ£º Prophet-6 ÊÇÎÒÃÇŬÁ¦´òÔìÒ»²¿ÓµÓÐÎÞÓëÂױȵÄÉùÏ죬ͬʱ¾ß±¸ÏÖ´ú¶à·¢ÉùÊýºÏ³ÉÆ÷±ØÒª¹¦Äܵijɹû¡£
Prophet-6 ÖØÏÖÁËProphet-5 µÄ¾µäÔªËØ£º
True voltage-controlled oscillators £¬ Filters £¬ÒÔ¼°Amplifiers £¬²¢¼ÓÉÏÁ˼ÒôÊҵȼ¶µÄEffects ¡¢¸´ÒôÐòÁÐÆ÷¡¢ Arpeggiator ¡£¾¹ýÕâÐ©ÔªËØµÄµ÷±äºó£¬ Prophet-6 ×îÖÕÄÜ·¢³öÎȶ¨¡¢ÎÂůµÄÀà±ÈÉùÏì¡£
Ïêϸ¹æ¸ñ£º
OSCILLATORS
È«ÐÂÉè¼Æ£º Discrete VCOs per voice
ÿһ¸öOscillator ½Ô¿ÉÁ¬Ðø·¢³ö²»Í¬²¨ÐÎ
ÿһ¸öOscillator ½Ô¿É¶ÀÁ¢µ÷±äPulse ¿í¶È
Oscillator 1 ¿Éͬ²½Oscillator 2
Oscillator 1 Å䱸 Triangle sub-octave generator
Oscillator 2 : Low frequency mode
Oscillator 2 : Keyboard Tracking £¨¿É¿ª¹Ø£©
Oscillator slop amount for increased tuning instability, from subtle to extreme
MIXER
Õñµ´Æ÷1 ÊäÈëÁ¿
Õñµ´Æ÷1 Sub-octave ÊäÈëÁ¿
Õñµ´Æ÷2 ÊäÈëÁ¿
White Noise ²úÉúÁ¿
HIGH-PASS FILTER
ÿ¸ö·¢Éù½Ô¾ß±¸High Pass Filter £¬ Two-pole £¬ Resonant
Bi-polar ²¨·âÊäÈëÁ¿¿Éµ÷Õû
Velocity modulation of envelope amount
Keyboard Tracking : £¨¿ª¡¢¹Ø¡¢ Half ¡¢ Full £©
LOW-PASS FILTER
ÿ¸ö·¢Éù½Ô¾ß±¸£¬ Four-pole £¬ Resonant
Bi-polar ÊäÈëÁ¿¿Éµ÷Õû
FILTER ENVELOPE
Four-stage (ADSR) envelope generator
AMPLIFIER ENVELOPE
LOW FREQUENCY OSCILLATOR
ÎåÖÖ²¨ÐΣºTriangle Sawtooth Square ÒÔ¼°Ëæ»ú²¨ÐΣ¨ Sample and Hold £©
Midi Clock
ÉæÈëÁ¿¿Éµ÷
¿Éµ÷±äÄ¿±ê£ºOscillator 1 frequency Oscillator 2 frequency Oscillator 1 and 2 pulse width Low-pass filter cutoff High-pass filter cutoff
POLY MOD
Sources : filter envelope (bi-polar) and oscillator 2 (bi-polar)
Destinations : oscillator 1 frequency, oscillator 1 shape, oscillator 1 pulse width, low-pass filter cutoff, high-pass filter cutoff
¼üºó¸ÐÓ¦
Source: channel (mono) aftertouch with bi-polar amount
Destinations: oscillator 1 frequency, oscillator 2 frequency, LFO amount, amplifier envelope amount, low-pass filter envelope amount, high-pass filter envelope amount
CLOCK
Tap Tempo
BPM Control
MIDI Clock
ARPEGGIATOR
¿ÉÑ¡Òô½×£º16th note, 8th note triplet, 8th note, dotted 8th note, quarter note
·¶Î§£º¿É´ï1 ¡¢ 2 »ò3 ¸ö°Ë¶È
ģʽ£ºUp Down Up/Down Random and Assign
SEQUENCER
64 ½×¸´ÒôÐòÁÐÆ÷
EFFECTS
Stereo Àà±ÈÊ§ÕæÐ§¹û
ÊýλЧ¹û£º Reverb ( Room Hall Plate Spring ) , Delay, Chorus ,Flanger, Phase Shifters, Ring Modulator
Delay ͬ²½
PERFORMANCE CONTROLS
Polyphonic glide (portamento)
Hold switch latches held notes on
PATCH MEMORY
ÒôÉ«¼ÇÒä
10 ¸öBanks ¿É´¢´æ1000 ×éPatch ( 500 ¸öʹÓÃÕß×Ô¶©¡¢ 500 ¸öÔ³§É趨 )
IN/OUT
×óÓÒÉùµÀ6.3mm Êä³ö
6.3mm ¶ú»úÊä³ö
MIDI In ¡¢ Thru ÒÔ¼°Out
Ë«ÏòMIDI ´«ÊäUSB ½Ó¿×£¨ Type-B £©
¿ÉʹÓñíÇé̤°å£¨¿É¿ØÖÆLow-pass filter cutoff £©
µçÔ´¹©Ó¦
IEC AC ÊäÈë
Operates worldwide on voltages between 100 and 240 volts at 50 to 60 Hz; 30 watts maximum power consumption
Íâ¹Û
³¤¿í¸ß£º 54cm 18.9cm 11.2cm
¾»ÖØ£º 5.9 ¹«½ï
