Xfer Records Serum incl. SerumFX 1.35b1 x86 x64 Unlocked
WiN | Size: 167MB
The dream synthesizer did not seem to exist: a wavetable synthesizer with a truly high-quality sound, visual and creative workflow-oriented interface to make creating and altering sounds fun instead of tedious, and the ability to ¡°go deep¡± when desired - to create / import / edit / morph wavetables, and manipulate these on playback in real-time.
Features:
* No serial key input needed
* No need to mark the user.dat file read only
* No browser windows opening because of a faulty key
* No need to backup your user.dat file (explained below)
* No need for an internet connection
* Update function disabled
* All plugins unlocked (VST, AAX, 32Bit & 64Bit)
Mods:
This release uses its own file (user.cfg) to store
activation related data. That way, any previously stored
License data stays untouched. This means you can run the
unlocked VST along with the untouched AAX binaries from
the previous 'Regged' release in your legit Pro Tools.
The Standalone has a new Icon and some issues with the
installer got fixed as well.
Additional Info's:
The AAX plugins are unlocked as well! To use them, you need
an unlocked AAX Host like Avid Pro Tools 2021.7.0 by R2R
Install Notes:
1. Run the setup.
2. Choose the options you want to use & install.
3. Enjoy!
Xfer Records Serum incl. SerumFX 1.35b1 x86 x64 Unlocked.txt (182 Bytes, ÏÂÔØ´ÎÊý: 0)
ÆÀÂÛÁÐ±í£¨1£©
ллÀϵܣ¬:handshake:handshake
2009-9-11 15:46:35 »Ø¸´
