音频应用 首页 新闻资讯 查看内容
K-Devices TATAT: Note-generating MIDI plug-in gets you in the mood
2022-7-3 09:56| 发布者: luxon| 查看: 458| 评论: 0
摘要: K-Devices has released TATAT, a new MIDI plug-in designed to get your creative juices flowing. Depending on the “mood” you dial in, TATAT creates a never-ending stream of notes, rhythms, and unexpec ...
K-Devices has released TATAT, a new MIDI plug-in designed to get your creative juices flowing. Depending on the “mood” you dial in, TATAT creates a never-ending stream of notes, rhythms, and unexpected sequences. Sounds like a perfect way to add some variations to your tracks!
TATAT by K-Devices is a new creative MIDI plug-in available in VST3 and AU formats. The developer says that it’s an “unstable streams generator”, which pretty much sums up what TATAT does. It lets you dial in various degrees of randomness and then proceeds to churn out an always-changing stream of sequences. If you’re into generative music, randomness, and chance, TATAT should be right up your alley.
It all starts with what K-Devices calls the “mood”: a set of parameters that determines how TATAT will behave. For example, you can layer and combine three different time signatures for polyrhythmic patterns. The Pitch section allows you to define probabilities for four different notes, and the notes themselves can be randomized, too. Moreover, there’s a Bichords section that determines the chance that certain intervals will be triggered. This is followed by a Process section that lets you experiment with random MIDI velocities, note lengths, and delays.
Drag&drop export
The result is a seemingly endless sequence that revolves around a defined set of musical parameters. But there are ways to tame the chaos, as well. You can freeze the buffer content as a static pattern, and then mix between that and the live stream. And the export feature is as simple as can be: Simply export as many variations as you like by dragging and dropping them to tracks, clip slots, or folders in your favorite DAW software.
Generative plug-ins like TATAT are a great way to add some variation and unexpected movement to your tracks. They’re also perfect for jump-starting your creativity. Let TATAT get you in the mood!
Price and compatibility
K-Devices TATAT is now available for a low introductory price of
路过
雷人
握手
鲜花
鸡蛋
最新评论
GMT+8, 2025-7-12 14:42 , Processed in 0.020690 second(s), 11 queries , Redis On.
