APT EquinoxרҵISDN¡¢IPºÍX.21´«ÊäÆ÷
²úÆ·ÃèÊö
World Cast EquinoxרҵIP,X.21&ISDNÒôƵ´«Êä
World Cast EquinoxÊÇÒ»¿î¶àËã·¨£¬È«Ë«¹¤£¬Á¢ÌåÉùÒôƵ±à½âÂëÆ÷£¬²¢ÌṩIP,ISDNºÍX.21/V.35ÍøÂçÁ¬½Ó¡£
Ö÷ÒªÓÃÓÚÖ±²¥¼äÖÁ·¢Éä»úÁ´Â·ºÍ¿çÖ±²¥¼äÍøÂçÓ¦Óã¬World Cast EquinoxÔÚ´«Êä¹ã²¥¼¶ÒôÖÊ´ø¿É¿¿24/7/365ÌṩÎȶ¨¿É¿¿µÄƽ̨¡£
Ìṩ׿ԽµÄÒôƵÖÊÁ¿
ȫ˫¹¤Á¢ÌåÉùÒôƵ´ø¿í£¬´Ó10HzÖÁ22.5KHz
Ä£ÄâºÍAES/EBU I/O½Ó¿Ú£¬Êý×Öͬ²½ÊäÈë
ͬʱ¿ÉÒÔÓÐÄ£ÄâºÍÊý×ÖÊä³ö
±ê×¼Ëã·¨°üÀ¨£ºLinear PCM (16 bit and 24 bit resolution),Enhanced apt-X algorithm (16 bit & 24 bit), MPEG Layer II, MPEG Layer III, G.711 and G.722
ÏȽøµÄËã·¨°ü°üÀ¨£ºMPEG 4 AAC LC, AAC LD, AAC ELD & AAC HEv2
È·±£¹ã·ºµÄÁ¬½ÓÐÔ£º
ͨ¹ýÓ¦ÓÃRTP/UDPºÍSIP/SDP IPÍøÂç´«Êä¸ßÖÊÁ¿ÒôƵ
µ¥¶ÀµÄÊý¾ÝÁ÷ºÍ¿ØÖƲÉÓÃË«IP¶Ë¿Ú
ISDN½Ó¿Ú´ø¼æÈݶàÖÖÉ豸&L3 TelosÎÞ·ì¶Ô½Ó
CCS, H221 & Hitachi ISDN ½áºÏ
X.21/V.35½Ó¿ÚÄÜÈÝÒ×Á¬½Ó¹Ì¶¨Êý×ÖÁ´Â·
ǶÈëʽAUX¸¨ÖúÊý¾ÝÕë¶ÔRBDS / RDS or PAD´«Êä
¶à´ï8¸ö¹âµçñîºÏÊäÈëºÍ8¸ö¼ÌµçÆ÷Êä³ö
ͨ¹ýIPÍøÂç´ïµ½×¨ÒµÒôƵ
Ö§³Öµ¥²¥ºÍ×é²¥Ó¦ÓõÄÁé»îµÄIPÅäÖá£
EBU N/ACIP¼æÈÝÖ§³ÖP/ SDPÐÒé
Èç¹ûÁ¬½ÓµôÏߣ¬ÔöÇ¿APT-XÌØµã¡°AutosyncTM¡±ÔÚ¸ßËÙÎȶ¨ÍøÂçÏ¿ÉÒÔ¿ìËÙ×Ô¶¯ÖØÐÂÁ¬½Ó
ÔÊÐíµÄÍøÂçÌõ¼þ£¬ÈçÊý¾Ý°ü´óС£¬»º³åÇøºÍQoS¼¶±ðÒÔ´ïµ½×î¼ÑµÄÒôƵÐÔÄܹÜÀí
ÌṩÁËÒ»¸öÇ¿´óµÄרҵƽ̨
ÈßÓàµçÔ´
´ø¿íÄÓÇú£¨µ±Ä¬Èϼì²âʱ£¬Ëü±£³ÖʹÓÃ×îÉٵĴø¿íÁ¬½Ó£©
ÒôƵ±¸·Ý´ÓAES / EBUµ½Ä£ÄâÊäÈ룬¿Éµ÷¾²Òô¼ì²âÓ뱨¾¯Êä³ö
´ÓSD¿¨¾²Ì¬ÒôƵ±¸·Ý
ÍêÈ«¿ØÖÆºÍ¼à¿Ø
Ç°Ãæ°å²Ù×÷µçƽ±íºÍ¶ú»ú
¸ß¶ÈÖ±¹ÛµÄ±à½âÂëÆ÷¹ÜÀíÈí¼þ£¨CMS£©
´ÓÈÎÒâλÖÿÉÒÔ·ÃÎÊ¿ØÖÆÄÚǶWeb·þÎñÆ÷
Ö§³ÖSNMP£¬±¨¾¯ºÍʼþ¼Ç¼
Óû§¿É¶¨ÒåµÄ·ÃÎʼ¶±ðºÍµÇ¼ά»¤ÍøÂ簲ȫ
µÚÈý·½É豸SNMPÔ¶³Ì¿ØÖÆ
Ö§³Ö´®¿ÚÔ¶³Ì¿ØÖƹ¦ÄÜ
¼¼ÊõÖ¸±ê£º
¹æ¸ñU x 19¡± »ú¼Ü
³ß´ç£º44mm x 480mm x 360mm
ÖØÁ¿£º3.5Kg
µçÔ´£º100-250VAC, 50-60Hz
¹¦ºÄ£º<25W
»·¾³£º0¡ãC to +55¡ãC, 95%ʪ¶È
IP£ºEthernet 1 x RJ45, (Ñ¡Åä)RTP/UDP, SIP/ SDP
X.21/V.35£º15 ÕëDÐÍÍ·, RS422ËÙÂÊ 64-576 kbit/s
ISDN: 2x RJ45 ¨C ±ê×¼
AUXÊý¾Ý£º9 ÕëDÐÍÍ·, RS232
Êý¾ÝËÙÂÊ£¨Ç¶Èëʽ£©£º1200, 2400,4800, 9600²¨ÌØ
Êý¾ÝËÙÂÊ£¨Í¨¹ýIP£©: 1200, 2400, 4800, 9600, 19200 ²¨ÌØ
¿ØÖÆ£ºMS Èí¼þ& SNMPѡƲwebä¯ÀÀÆ÷&Ç°Ãæ°å
Êý×ÖÒôƵI/O: AES/EBU, ƽºâXLR-3,×迹110 Ω
Êý×Öͬ²½ÊäÈ룺XLR-3
Ä£ÄâÒôƵI/O:ƽºâ XLR-3, ÊäÈë×迹 >10k / 600 Ω Êä³ö×迹 <50 / 600 Ω
SD: Ö§³ÖSD&SDH¿¨
USB£ºUSB½Ó¿ÚÉ豸
¸æ¾¯£º8·25ÕëDÐÍÍ·£¬³£¿ª/³£±Õ´¥µã
¹âµçñîºÏÆ÷£º25ÕëDÐÍÍ·£¬8·ÊäÈëºÍ4·Êä³ö
Êý×Ö²Ù×÷£º32kHz, 44.1kHz, 48kHz
Êý×ÖÒôƵ´ø¿í£º10Hz to 22.5kHz£¨µ¥ÉúµÀ&Á¢ÌåÉù£©
Ä£Äâ²Ù×÷£º8kHz-48kH
Ä£ÄâÒôƵ´ø¿í£º10Hz to 22.5kHz£¨µ¥ÉúµÀ&Á¢ÌåÉù£©
²ÉÑùÂÊת»»£º3:1£¨´øÅÔ·ģʽ£©
A/Dת»»£º24-bit/96kHz
±ê×¼±àÂ룺Linear, Enhanced apt-X 16-Bit & 24-Bit, ISO/MPEG 1/2 Layer III, , G.711, G.722
Ë㷨ѡÏISO/MPEG 4 AAC LC ISO/MPEG4 AAC-LD & AAC-ELD AAC HEv2
ѹËõ±È£ºapt-X: 4:1
±àÂëÑÓʱ£ºÔöÇ¿ apt-X 1.9ms @48kHz Fs
¶¯Ì¬·¶Î§£º16 Bit > 85dB, 24 Bit > 120dB
ÏàλÏìÓ¦ÏßÐÔ£º0 to Fs/2
ͨ´øÎƲ¨£º< 0.2dB |
