8Dio Liberis Angelic Choir Instrument v2 KONTAKT
ÎÒÃǵÄÐÂÒ»´ú³ªÊ«°àͼÊé¹ÝÊÇÎÒÃǵÄÐÂÒ»´úºÏ³ªÍÅ£¬ËüÊÇÓɺϳªÖ¸»Ó£¬Bob GearyµÄº¢×ÓÃǵĺ¢×ÓÃǵĺϳª¶Ó¡£Õâ¸öͼÊé¹Ý´ú±íÁËÊг¡ÉÏ×ȷ¡¢×îÏêϸµÄ½»ÏìÀÖ¶ùͯºÏ³ªÍÅ£¬°üÀ¨ÍêÕûµÄºÏ³ªÍźÍ3¸öÉîÈ¡ÑùµÄ¶À×à¡£
liberaÔÊÐíÄãͨ¹ýʹÓø÷ÖÖÐÂÒ»´úµÄÌØÐÔÀ´´´½¨ÕæÊµµÄºÏ³ª£¬°üÀ¨ÕæÊµµÄ·Ö²ãµÄÀ³ÍУ¬°üÀ¨»ùÓÚËٶȵÄÕý³£µÄºÍÃÅÍеÄLegato¡£¸ÃͼÊé¹Ý°üº¬28¸ö²»Í¬µÄ¶àÔªÒôºÍ22¸ö²»Í¬µÄ¶àÔªÒô¡£¶àÔªÒô¶¼ÊÇbpm-ͬ²½µÄ£¬ÎÒÃÇÉõÖÁÓò»Í¬µÄËٶȼǼËüÃÇ£¬ÒÔÊÊÓ¦²»Í¬ÀàÐ͵ķÖÊý¡£ÕæÕýµÄ¶à²ã´ÎµÄÍȺͶàÔªÒôµÄ»ìºÏ¿ÉÒÔÈÃÄã´´Ôì³ö100%ÌýÆðÀ´ºÜÓÐÒâÒåµÄºÏ³ª¡£¸ÃͼÊé¹Ý»¹°üÀ¨ÁË3¸ö¶ÀÌØµÄ¶À×࣬ËüÃDZ»Éè¼Æ³ÉÓëÕû¸öºÏ³ªÍźÏ×÷£¬ÔÚÐèÒªµÄʱºò¼ÓÈëÒ»¸ö¸üÇåÎúµÄ×éºÏ¡£
ÎÒÃÇ»¹°üÀ¨ÁËÒ»¸öÎÞÓëÂױȵÄЧ¹û²¿·Ö£¬ËüÓÐ+1000¸öЧ¹û£¬´Ó»ù±¾µÄÔªÒô/ÔªÒô¡¢¼¯Èº¡¢É¨¹ý¡¢µÍÓï¡¢º°½ÐÉù¡¢ßóßóÉù¡¢¶ùͯ¸èÇú¡¢ÅÄÊÖÉù¡¢¿ìÕյȵȡ£ÔÚÎÒÃǵÄAdagio¡¢É¿¶¯¡¢AdagiettoºÍÑ¡¼¯ÏµÁÐÖУ¬ÎÒÃÇʹÓõÄÊÇŵÒÁÂüÂó¿Ë·çµÄ´óÊý×é¡£¸ÃͼÊé¹Ý°üÀ¨3¸ö²»Í¬µÄÂó¿Ë·ç(5.1)£¬°üÀ¨½ü¡¢ÖС¢ÊÒ/Ô¶¡£ËùÓеĶ«Î÷¶¼±»¼Ç¼ÔÚԭʼµÄ24λÖУ¬Ê¹ÓÃÁËһЩ×îºÃµÄǰÖúͼÒôÉ豸¡£
¸Ã¿â»¹¾ßÓи߶ÈÖ±¹ÛºÍ¿ÉÍæµÄÓû§½çÃæ(UI)¡£UIÔÊÐíÄúÔÚ²»¼ÓÔØ¸½¼Ó²¹¶¡µÄÇé¿öÏÂ×ÔÓÉÇл»¡£ÎÒÃÇ´´ÔìÁ˶îÍâµÄ¿ØÖÆ£¬±ÈÈçAmp Env£¬Òô¸ßEnv£¬ÒÔ¼°ÔڹؽÚÖ®¼äÓнÚ×àµÄÂö³å¡£ÎÒÃÇ»¹Ôö¼ÓÁËеÄǰÖÃЧ¹û£¬°üÀ¨²»Í¬µÄÂ˾µÑ¡Ïî¡¢bpm-ͬ²½ÃÅ¡¢Á¢ÌåÉùÑÓ³Ù¡¢Ñ¹Ëõ¡¢ÎÆÀíµÄ¾í»ý¡¢ÊµÑéµÄ¾í»ýÒÔ¼°À´×ÔÎÒÃǵÄ˽ÈËÑù±¾Ä¿Â¼µÄ´óÁ¿¶¨ÖƵĻìÏìÂö³å£¬ËùÒ԰ѺϳªÍÅ·ÅÔÚÄãÏëÒªµÄÈκεط½¡£
Ô­ÎÄ
LIBERIS ¨C Exquisite Angelic Choir VST ¨C is our new-generation choir library featuring the professional 45-Piece Multi-Award Winning Piedmont¡¯s Children¡¯s Choir lead by choral conductor, Bob Geary. The library represents the most accurate and detailed deep-sampled Symphonic Children¡¯s Choir on the market, including Full Ensemble Choir and 3 Deep-Sampled Soloists.
LIBERIS allows you to create realistic-sounding choir by using a variety of next-generation features, including True Layered Legato, which includes both normal and portamento legato based on velocity. The library contains a deep section of over 28 different Multi-Vowels for the Ensemble and 22 different Multi-Vowels for the 3 soloists. The Multi-Vowels are BPM-synced and we even recorded them in different speeds to accomodate for different types of scores. The mixture of True Layered Legato and Multi-Vowels allows you to create 100% life-sounding choral renditions. The library also includes 3 unique Soloists, which were designed to work with the Ensemble Choir and add a more distinct profile to your mix when needed.
We also includes an unrivaled effects section with +1000 effects ranging from basic consonant/vowels, clusters, sweeps, whispers, shouts, chirps, childrens songs, claps, snaps etc. LIBERIS was exclusively recorded large arrays of Neumann Microphones in the same A-Frame Shaped Church we used for our Adagio, Agitato, Adagietto and Anthology String Series. The library includes three distinct microphone (5.1) positions including Close, Middle and Room/Far. Everything was recorded in pristine 24-Bit using some of the best pre-amps and recording devices in existence.
The library also comes in a highly intuitive and playable User-Interface (UI). The UI allows you to freely switch between articulations without loading additional patches. We created additional controls like Amp Env, Pitch Env and ability to rhythmically pulse between articulations. We also added new Front-Faced effects, including different filter options, BPM-synced gate, Stereo-Delays, Compression, Textural Convolutions, Experimental Convolutions and a large set of custom Reverb impulses from our private sample catalog, so put the choir anywhere you want.
8Dio Liberis Angelic Choir Instrument v2 KONTAKT | 7.16 Gb
    ÏÂÔØµØÖ·£º
Óοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë»Ø¸´
ÆÀÂÛÁÐ±í£¨4£©
:victory:
2009-4-10 00:30:56 »Ø¸´
ÒѾ­Í¶Æ±Ö§³Ö,»¹ÓÐÂÛ̳µÄÆäËûÅóÓÑ:victory:
2009-4-10 11:32:31 »Ø¸´
Ö§³Ö
2009-4-10 11:54:25 »Ø¸´
Ö§³ÖÅóÓÑ:victory::victory:
2009-4-10 12:07:10 »Ø¸´
