SSL Alpha Channel µ¥Í¨µÀ»°Í²·Å´óÆ÷
SSL Alpha Channel µ¥Í¨µÀ»°Í²·Å´óÆ÷ÊÛ¼Û£º£¤9800Ôª
( X* r6 ?% ]. r! H: _# P6 F; I4 L( W0 n- y+ |- \
ÓÉÓÚËùÓеط½¶¼ÐèÒªÂ¼ÖÆ³öÃÀÃîµÄÈËÉùºÍÀÖÆ÷¹ì¡£Alpha ChannelÌṩһ¸ö¼ÒôÊÒ¼¶±ðµÄ»°Í²Ç°Ö÷ŴóºÍ´¦Àí£¬»ùÓÚSSLÔÚÄ£Äâ¼Òôµ÷̨É϶àÄêµÄ¾­Ñé¡£ºÜ´óÒ»²¿·ÖÒôÀÖ¶¼ÊÇÔÚSSLÉÏÂ¼ÖÆµÄ£¬ÒÔ³öÉ«µÄÒôÖÊÖø³Æ.ÄÇÒ²ÊÇAlpha ChannelͬÑù¾ßÓеÄÒòËØ¡£ ͨ¹ý»°Í²·Å´ó£¬Â˲¨£¬EQºÍ¶¯Ì¬µÄ½Ü³ö×éºÏ£¬ XLogic Alpha ChannelΪÄãµÄÊý×ÖÒôƵ¹¤×÷Õ¾´øÀ´ÁËÍêÃÀµÄǰ¶Ë£¬ÖÁ½ñΪֹÔÚÄ£ÄâͨµÀÌõÉÏÌṩµÄSSLµÄÒôÉ«¡£
/ I7 w( ^, ^8 o3 H" K/ n2 M
7 w, R2 H" G( ]9 V% a! i
% ?' b8 G: m# d+ A
, p5 E1 x5 E) `$ M. uͨ¹ý»°Í²·Å´ó£¬Â˲¨£¬EQºÍ¶¯Ì¬µÄ½Ü³ö×éºÏ£¬ XLogic Alpha ChannelΪÄãµÄÊý×ÖÒôƵ¹¤×÷Õ¾´øÀ´ÁËÍêÃÀµÄǰ¶Ë£¬ÖÁ½ñΪֹÔÚÄ£ÄâͨµÀÌõÉÏÌṩµÄSSLµÄÒôÉ«¡£- \) b7 Q( o2 K0 ?, j" z3 k: F
2 ~/ x5 P2 j+ z3 M  t2 L/ H. Z; |  \0 j2 `$ B
Ö÷ÒªÌØÕ÷£º. Z+ n+ I- Q2 C# I1 {/ a
! i3 N0 O" d2 y& a
רҵµÄ¼«¸É¾»»°Í²Ç°Ö÷Ŵ󣬴øÏß·µçƽºÍHi ZÀÖÆ÷ÊäÈ뿪¹Ø1 L( H; w" G+ ^+ s
5 j) W/ `# _$ ~, e
¿É±äг²¨Çý¶¯µç·----Ê§ÕæÌØÕ÷µÄʱ¼ä»úÆ÷
) |( F( o- M3 b6 J2 v
9 Z, [( ~% |/ R# c5 [/ v´ø¿ÉÑ¡µÄ40Hz£¬ 80Hz »ò 120Hz·ÖƵµãµÄ¸ßͨÂ˲¨Æ÷
& G& C( C; u1 [/ E& I& I7 ?
8 G2 t) i' ~7 PÄÚ½¨×¨ÒµÆ·ÖʵÄÄ£Äâ-Êý×Öת»»£¬±ê×¼ÅäÖÃ8 T* i  Q" l4 m. }( A
2 m4 F+ b( G+ U' A( _
3¶ÎSSL±äÁ¿EQ´øÖÐÆµQÖµ¿ØÖƺÍ˫ͨµÍƵÇúÏß
! j, ?! }6 w- W+ p: i# {+ O% s, y. u( L; @# L
ÖÇÄÜ×Ô¶¯Ñ¹ËõÆ÷£¬¿É×î´óÏÞ¶ÈÀûÓüÒô¾»¿ÕºÍ±ÜÃâDACÏ÷²¨# t; `5 Y- h3 v8 }# s1 O/ @/ s1 F
' C4 C5 K# A* v0 d9 ^! j  h! \! R8 {: Z
¼¼ÊõÖ¸±ê£º0 q, W$ O- i1 s& W: g" m. i. @0 _
# ]' B- b' t3 h
Éî¶È 230mm / 9"
& H, c6 D6 e( f( S/ {/ E- ~) z/ Q. q& ^8 p( T$ ^- b  w
¸ß¶È 44.5mm / 1.75" (1 RU)$ E6 c2 L1 I4 N
- x5 c4 g8 l2 \  S2 F8 C5 j¿í¶È 482mm / 19" inc¡¯ rack ears
2 i2 a; Z6 o  w( F$ p
$ c# [' \$ E( p' ^( e! ?3 g: {ÖØÁ¿ 3.0kg / 7 Ó¢°÷  Z4 c& y2 r! R( f. p6 w; \, q
; j9 H4 ~/ X  n' E* `¹¦ÂÊ < 20 Watts
" i) i; a3 \; m+ {* P) |! H/ L% P/ E9 p+ A; v" o' Y5 h
×°Ï乿¸ñ 320mm x 550mm x 80mm 12.75" x 21.75" x 3.25"
! S% J; j, X6 k' K4 p
/ z( e. {# y2 f" H, t×°ÏäÖØÁ¿ 3.5kg / 8 Ó¢°÷
9 {" p! k" d% ]+ y
" X) C. W: m- j- t: P% H6 X»°Í²ÔöÒæÖÁÊä³ö: 20dB min£¬ 76 dB max# W+ l) e9 Z; F3 m2 n
0 V6 l( Z: M( t/ uÀÖÆ÷ÔöÒæÖÁÊä³ö: 26dB min£¬ 82 dB max, \, J9 m- y7 q! V2 A, l  H
0 B$ k3 u5 V/ Y/ `1 O
»ÃÏàË¥¼õ: 20 dB
6 U% O' v9 h& ~/ N/ I+ M) ^. f2 ^7 u3 A" @
ÊäÈë×迹 (¦¸): »°Í²: 1K / 10K( @$ R8 c8 S! V: u0 J9 h
" ~/ h% Q- Q! d& K! S8 V0 LÀÖÆ÷: 1 MEG
+ t4 v# }& Q2 s! d6 ~& E) \4 @2 N( _- z( [
ÔëÒôÌØÕ÷
" Y6 ]. ~% \% r/ ]. m% Y0 Q
6 |8 q; `7 W* U; g8 T( bEquivalent Ein:
+ `- ]3 W! l$ e+ b/ F& j5 @6 O5 P/ S' J* @3 Y
Mic£¬ ×迹 = 10R -130.5 dBU9 o$ f" @5 J$ T3 y- O# j2 Y
5 U( n3 G; t4 i1 S. }5 hMic£¬ ×迹 =150R -127.5 dBU
6 W2 P  u3 |1 H% J/ X  e" H: R1 t
) O' y. B/ V/ P' _¶¯Ì¬·¶Î§:
( T7 }( l6 v7 n3 L2 ~* b- h& b! E% S" u% j4 S- S
»°Í²ÔöÒæ×îС: 105 dB# z% C& B0 [9 N( r" l4 i+ J
+ c2 x$ C# F* M* u8 R0 ^
»°Í²ÔöÒæ×î´ó: 76 dB
3 K" i% U& z0 `9 I0 J& E0 q5 l# [( w5 H
3 q  R$ v0 D4 c3 I: g! B
* K) w  O) ?& v
ƵÂÊÏìÓ¦' [, y" ^" y- G, R
( N4 n$ P$ K# D& c( W. ]) W' A! |Mic - Out: +/- 0.2 dB£¨10Hz - 70KHz£©( n# e: d! b) h; a
5 S3 `7 r! D7 S7 X6 V4 j-3dB (LF) : 6 Hz2 F; D4 J8 E, k! U' a
3 `1 r' s/ y# ]  `% c
-3dB (HF) : 250 KHz, _0 a3 f# {2 Q& b% @) d) k
7 x1 z0 A4 n+ g$ I
# G9 I0 m9 Y% b9 u) l
7 Z! C0 }9 M- ^7 h- w7 o( S×î´óÄ£ÄâÊä³ö: +24.3 dBU (10K)
$ }) x* R/ r) g3 ]+ U" n: x/ ~$ A' G: A; W6 |( n
»ÃÏñ¹©µç: 47.5V typical
/ ]8 {' i$ E. E: }, }6 Z
: c% x) n& n; K  I$ }4 N7 wÊä³öÔöÒæ·¶Î§: +/- 19.5 dB
ÆÀÂÛÁÐ±í£¨1£©
Ö§³ÖÅóÓÑ¡£
2009-4-25 08:51:20 »Ø¸´
