˼¿ÆÂ·ÓɹýÂËÃüÁîÏêϸ½âÊÍ
mpptzajj
2005-6-24 05:28:00
£¨Ò»£© Route Maps
ÌØÐÔ£º
Route MapsÀàËÆÓÚaccess lists£¬²»Í¬Ö®´¦ÔÚÓÚRoute Maps¿ÉÒԸıäPackets/RoutesµÄ²¿·ÖÊôÐÔ¡£
ÓÃ;£º
Route MapsÖ÷ÒªÓÃÓÚRedistributionºÍPolicy Routing¼°BGPµÄʵÏÖ¡£
ʵÏÖ£º
Policy Routing·¢ËÍPacketsµ½Route MapsʵÏÖ²ßÂÔ·ÓÉת·¢¡£
Redistribution·¢ËÍRoutesµ½Route MapsʵÏÖ·ÓÉÌõÄ¿µÄ¹ýÂË¡£
ÅäÖÃ˵Ã÷£º
Route MapsÈç¹ûûÓÐÖ¸¶¨Action¼°Sequence NumberÊôÐÔ£¬Ä¬ÈÏ£º
Action£º   permit
Sequence Number£º   10
ÇÒSequence Number²»»á×Ô¶¯Ôö¼Ó¡£
¼´Èç¹ûÔÚʹÓÃRoute MapsÓï¾äʱ²»Ö¸¶¨Sequence Number£¬Ôò¸²¸ÇSequence NumberΪ10µÄĬÈÏÌõÄ¿¡£
Route Maps Deny Action£º
Redistribution£º ÌØ¶¨Â·ÓÉÌõÄ¿²»»á±»ÖØ·Ö²¼¡£
Policy Routing£º ÌØ¶¨µÄPackets²»»á°´²ßÂÔ·ÓÉת·¢£¬µ«»á¹£¸ÅÕý³£µÄ·ÓɱíÌõĿת·¢¡£
Case Study£ºPolicy Routing
×¢£º£¨1£©Policy RoutingÖ»Ó°ÏìÈëÁ÷Á¿¡£
£¨2£©¿ÉÒÔʹÓÃStandard¼°Extended ACL.
¡¡¡¡£¨3£©È«¾ÖÅäÖÃip local policy route-map sense¿É½«²ßÂÔ·ÓÉÓ¦ÓÃÓÚRouter±¾Éí·¢Ë͵ÄPackets.
¡¡¡¡<1> Standard ACL
interface Serial 0
   ip address 172.16.5.1 255.255.255.0
   ip policy route-map sense
access-list 1 permit 172.16.6.0 0.0.0.255
access-list 2 permit 172.16.7.0 0.0.0.255
route-map sense permit 10
   match ip address 1
   set ip next-hop 172.16.4.2
route-map sense permit 20
   match ip address 2
   set ip next-hop 172.16.4.3
¡¡¡¡<2> Extended ACL
interface Ethernet 0
   ip address 172.16.1.4 255.255.255.0
access-list 105 permit tcp 172.16.1.0 0.0.0.255 eq ftp any
access-list 105 permit tcp 172.16.1.0 0.0.0.255 eq ftp-data any
access-list 106 permit tcp 172.16.1.0 0.0.0.255 eq telnet any
   match ip address 105
   set ip next-hop 172.16.2.1
   match ip address 106
   set ip next-hop 172.16.3.1
¡¡¡¡<3> Length of the Packets
interface Ethernet0
   match length 1000 1600
   match length 0 400
¡¡¡¡<4> Router's Packets
interface Ethernet0
access-list 120 permit ip any 172.16.1.0 0.0.0.255
access-list 120 permit ospf any any
   match ip address 120
route-map sense permit 30
   match length 0 400
¡¡¡¡×¢£ºÈç¹ûûÓеÚÒ»¸öroute-mapÌõÄ¿£¬router±¾ÉíµÄPackets¼°OSPFµÄPackets¶¼»áÓÉÓÚºóÁ½¸öroute-mapÓï¾ä±»×ª·¢µ½´íÎóµÄµØÖ·¡£
¡¡¡¡Case Study£º Policy Routing and Quality of Service Routing
¡¡¡¡Policy Routing½áºÏip°üÍ·µÄPrecedenceºÍType of Service£¨TOS£©¿ÉÒÔʵÏÖ»ùÓÚQOSµÄ²ßÂÔ·ÓÉ¡£
¡¡¡¡×¢£ºPrecedenceºÍTOSµÄÅäÖüȿÉʹÓÃNumber×ֶΣ¬Ò²¿ÉÒÔʹÓÃKeyword.
set ip precedence
Bits     Number     Keyword
000        0        routine
001        1        priority
010        2        immediate
011        3        flash
100        4        flash-override
101        5        critical
110        6        internet
111        7        network
set ip tos
Bits     Number     Keyword
0000       0        normal
0001       1        min-monetary-cost
0010       2        max-reliability
0100       4        max-throughput
1000       8        min-delay
interface Serial0
   ip address 10.1.18.67 255.255.255.252
interface Serial1
   ip address 10.34.16.83.255.255.255.252
access-list 1 permit 172.16.0.0 0.0.255.255
access-list 110 permit tcp any eq www any
   match ip address 1 110
   set ip precedence critical
   set ip tos 10
   set ip precedence priority
¡¡¡¡Case Study£º Route Tagging
¡¡¡¡ÓÃ;£º
¡¡¡¡ÓÃÓÚË«ÏòÖØ·Ö²¼Ê±±êÊ¶ÌØ¶¨DomainµÄ·ÓÉ£¬ÒÔ·À·Óɱ»ÖØ·Ö²¼»ØÆðÔ´Domain.
¡¡¡¡Ê¹Ó÷½°¸£º
¡¡¡¡Í¨¸æÂ·ÓÉÌõÄ¿µÄ±ßÔµRouterÔÚÖØ·Ö²¼Ê±¸øÂ·ÓÉÌõÄ¿¼ÓÉÏTag±êʶ£¬×öΪTransit NetworkµÄDomain£¬²»ÐèҪʹÓúÍʶ±ðTag£¬½ö½öÐèÒª½«Ëü´«µÝµ½ËüµÄÍâ²¿ÍøÂç¼´¿É¡£
¡¡¡¡Â·ÓÉЭÒéÏà¹Ø£º
¡¡¡¡Support£º RIPv2£¬EIGRP£¬IS-IS£¬OSPF£¬BGP
¡¡¡¡Not Support£º RIPV1£¬IGRP
¡¡¡¡Packets Format£º
¡¡¡¡RIPv2£º Ö§³Ö16-bit tags    ±íʾΪʮ½øÖÆ£º0 ~ 65535
¡¡¡¡EIGRP external route TLVs£º Ö§³Ö32-bit tags    ±íʾΪʮ½øÖÆ£º0 ~ 4294967295
¡¡¡¡OSPF type 5 LSAs£ºÖ§³Ö32-bit tags    ±íʾΪʮ½øÖÆ£º0 ~ 4294967295
¡¡¡¡ÅäÖÃʵÀý£º
router ospf 1
   redistribute igrp 1 metric 10 subnets tag 1
   redistribute rip metric 10 subnets route-map sense
   network 10.100.200.1 0.0.0.0 area 0
router rip
   network 10.0.0.0
router igrp 1
   network 10.0.0.0
access-list 1 permit 10.1.2.3
access-list 2 permit 10.1.2.4
   match ip route-source 1
   set tag 2
   match ip route-source 2
   set tag 3
¡¡¡¡£¨¶þ£© Distribute-list
¡¡¡¡×÷Óãº
¡¡¡¡<1> ¿ØÖÆÂ·ÓÉÌõÄ¿µÄ·Ö·¢£¬¼°Â·ÓɵÄÖØ·Ö²¼¡£
¡¡¡¡<2> ½¨Á¢Ò»¸ö"route firewall"
¡¡¡¡¹ØÓÚ·ÓÉЭÒ飺
¡¡¡¡Distance Vector Routing Protocol£º Route Filtering¿ÉÒÔ¿ØÖÆÆäͨ¸æ/½ÓÊյķÓÉÌõÄ¿£¬¼°ÖØ·Ö²¼µÄ·ÓÉÌõÄ¿¡£
¡¡¡¡Link-State Routing Protocol£º Route FilteringÖ»¿ÉÒÔ¿ØÖÆÆäÔÚÖØ·Ö²¼Ê±µÄ·ÓÉÌõÄ¿¡£
¡¡¡¡×¢£º LS Routing ProtocolµÄÒ»¸ö»ù±¾µÄÒªÇó¾ÍÊÇÔÚÒ»¸öareaÄÚËùÓÐRoutersµÄLink State Database±ØÐëÒ»Ö£¬ËùÒÔÈç¹ûRoute FilteringÄܹýÂ˵ôLS Routing ProtocolµÄLSAͨ¸æ£¬¾ÍÎ¥±³ÁËLS Routing ProtocolµÄ¹æ·¶¡£
¡¡¡¡Case Study£º Filtering Specific Routes
router rip
   version 2
   network 192.168.75.0
   distribute-list 1 in Serial1
ip classless
access 1 permit 0.0.0.0
¡¡¡¡Case Study£º Route Filtering and Redistribution
¡¡¡¡×¢£º
¡¡¡¡distribute-list ÃüÁîÓÃÓÚLink-State Routing Protocolʱ£º
¡¡¡¡Óë½Ó¿ÚÁªÓ㺠  Ö»ÄÜʹÓÃin²ÎÊý
¡¡¡¡Óë·Óɽø³ÌÁªÓ㺠ֻÄÜʹÓÃout²ÎÊý
¡¡¡¡Á½ÖÖ·½°¸Ð§¹ûÏàͬ¡£Óë½Ó¿ÚÁªÓõķ½°¸ÔÚÒÖÖÆroute feedbackÉÏЧ¹û±È½ÏºÃ£»Óë·Óɽø³ÌÁªÓõķ½°¸ÔÚÒÖÖÆroute feedbackʱ£¬ÓÉÓÚÔÚ¹ýÂËʱ£¬ÏàÓ¦µÄ·ÓÉÌõÄ¿ÒѾ­½øÐÐÁË·ÓÉ±í£¬ËùÒÔʧЧ¡£
¡¡¡¡<1> Óë½Ó¿ÚÁªÓÃ
router ospf 25
   redistribute rip metric 100
   network 172.16.1.254 0.0.0.0 area 25
   network 172.16.8.254 0.0.0.0 area 25
   network 172.16.50.254 0.0.0.0 area 25
   distribute-list 3 in Ethernet0/0
   distribute-list 3 in Ethernet0/1
   distribute-list 3 in Ethernet0/2
router rip
   redistribute ospf 25 metric 5
   passive-interface Ethernet0/0
   passive-interface Ethernet0/1
   passive-interface Ethernet0/2
   network 192.16.0.0
   distribute-list 1 in Ethernet0/3
   distribute-list 1 in Ethernet2/0
   distribute-ilst 1 in Ethernet2.1
ip classless
access-list 1 permit 172.16.128.0 0.0.127.255
access-iist 3 permit 172.16.0.0 0.0.127.255
¡¡¡¡<2> Óë·Óɽø³ÌÁªÓãº
router ospf 25
   distribute-list 10 out rip
router rip
   passive-interface Ethernet0/3
   passive-interface Ethernet2/0
   passive-interface Ethernet2/1
   network 172.16.0.0
   distribute-list 20 out ospf 25
ip classless
access-list 10 permit 172.16.130.0
access-list 10 permit 172.16.145.0
access-list 10 permit 172.16.240.0
access-list 20 permit 172.16.23.0
access-list 20 permit 172.16.9.0
access-list 20 permit 172.16.75.0
¡¡¡¡£¨Èý£© Prefix-list
¡¡¡¡¹¦ÄÜ£º
¡¡¡¡¹ýÂËÌØ¶¨Â·ÓÉЭÒé·Ö·¢µÄRoutes£¬Ö÷ÒªÓÃÓëBGP.
¡¡¡¡ÌØÐÔ£º
¡¡¡¡ÓëACLÏà±È£¬¾ßÓÐÏà¶Ô½ÏÇ¿µÄÁé»îÐÔ¡£ÔÚÑÚÂëÆ¥ÅäÉÏ£¬Ò²±È½ÏÈÝÒ×Àí½â¡£
¡¡¡¡Case Study£º Standard Syntax
¡¡¡¡ip prefix-list {list-name | list-number} [seq number] {deny network/length | permit network/length} [ge ge-length] [le le-length]
¡¡¡¡no ip prefix-list {list-name | list-number} [seq number] {deny network/length | permit network/length} [ge ge-length] [le le-length]
¡¡¡¡×¢£º
¡¡¡¡<1> ip prefix-listʹÓÃ×ƥÅ乿Ôò¡£
¡¡¡¡<2> Èç¹û²»Ö¸¶¨seq number£¬ÔòĬÈÏΪ5£¬ÇÒÿÔö¼ÓÒ»¸öÌõÄ¿×Ô¶¯Ôö¼Ó5.
¡¡¡¡¼´Èç¹ûÄãÖ¸¶¨µÚÒ»ÌõÄ¿seq numberΪ2£¬ÔòÏÂÒ»¸ö²»Ö¸¶¨seq numberµÄÌõÄ¿µÄseq number×Ô¶¯±äΪ7.
¡¡¡¡<3>×Ô¶¯Ôö¼Óseq number¹¦ÄÜ¿ÉÒÔÓÃÃüÁno ip prefix-list sequence-numberÈ¡Ïû¡£
¡¡¡¡<4> length < ge-length < le-length <= 32
¡¡¡¡<5> ip prefix-list²»ÄÜÓëRoute MapsµÄmatch ip next-hopÓï¾äÁªÓã»Ö»ÒÔÓëmatch ip addressÓï¾äÁªÓá£
¡¡¡¡Case Study£º ip prefix-list description
¡¡¡¡Syntax£º
ip prefix-list list-name description text
Case Study: Configuration Example
router bgp 3
   no synchronization
   neighbor 172.16.1.2 remote-as 3
   neighbor 172.16.20.1 remote-as 1
   neighbor 172.16.29.1 prefix-list 1 out
   no auto-summary
ip prefix-list 1 seq 5 deny 192.68.10.0/24
ip prefix-list 1 seq 10 permit 0.0.0.0/32
¡¡¡¡£¨ËÄ£© ip as-path access-list
¡¡¡¡¹¦ÄÜ£º
¡¡¡¡¸ù¾ÝBGPµÄAS-PATHÊôÐÔ¹ýÂËBGPµÄ·Ö·¢Â·ÓÉÌõÄ¿¡£
¡¡¡¡Case Study£º Syntax
¡¡¡¡ip as-path access-list acl-number permit | deny regexp
¡¡¡¡no ip as-path access-list acl-number
¡¡¡¡×¢£ºacl-numberÓÐЧֵΪ0 ~ 500.
¡¡¡¡Case Study£º Configuration Guide
¡¡¡¡<1> ¹ýÂËËùÓеÄ˽ÓÐASµÄRoutes¸üÐÂ
¡¡¡¡ip as-path access-list 1 deny £¨_64[6-9][0-9][0-9]_|_65[0-9][0-9][0-9]_£©
¡¡¡¡ip as-path access-list 1 permit .*
¡¡¡¡<2> Ó¦ÓÃʵÀý
router bgp 3
   no synchronization
   neighbro 172.16.20.1 filter-list 1 out
   no auto-summary
ip as-path access-lsit 1 permit ^$
¡¡¡¡£¨Î壩 ÒÔÉϹýÂËÃüÁîµÄÖ´ÐÐ˳Ðò£º
¡¡¡¡<1> inbound
¡¡¡¡route-map£­>filter-list£­>prefix-list£¬distribute-list
¡¡¡¡<2> outbound
¡¡¡¡prefix-list£¬distribute-list£­>filter-list£­> route-map
¡¡¡¡prefix-list£¬distribute-listÓÃÓÚÁÚ¾ÓÔÚÒ»¸ö·½ÏòÉÏÿ´ÎÖ»ÄÜÓÃÆäÖеÄÒ»¸ö
¡¡¡¡ÆäʵÕâЩ¹ýÂËÃüÁî¶¼²»ÊÇÌ«ÄÑ£¬¹Ø¼üÊÇÒ»¸ö¹ýÂ˵ÄÀíÄî¡£
¡¡¡¡ËüÃǶ¼ÊǺÜÁé»îµÄ¶«Î÷£¬ÔËÓõĺã¬Ëü»áÓкܴóµÄ×÷Óã»ÔËÓõò»ºÃ£¬Ò²ÓпÉÄÜ»áÓз´×÷Óõġ£
ËùÒÔ˵£¬ÔÚÅäÖÃÕâЩ¹ýÂËÃüÁîµÄʱºò£¬Òª×ÐϸµÄÕå×á£Ã¿Ò»¸ö¹ýÂ˶¼ÒªË¼¿¼Ò»Ï£¬µ±°²·Åµ½ÏÖÓеÄÍøÂç»áÓÐʲôÑùµÄЧÓã¬ÕâÑù²Å²»ÖÁÓڵȵ½°²·Åµ½Â·ÓÉÆ÷ÉÏÒÔºó²ÅÈÏʶµ½¹ýÂ˵Ä©¶´£¬²Å²»ÖÁÓÚÒý·¢°²È«Òþ»¼¡£
