查看: 11038|回复: 2
[midi] Nektar SE25 主控键盘/MIDI键盘 25键/25key
2万
音频应用初级会员
Rank: 6Rank: 6
发表于 2009-3-20 17:50:14 | 显示全部楼层 |阅读模式
Nektar SE25 主控鍵盤/MIDI鍵盤 25鍵/25key
25 velocity-sensitive mini keys
3 velocity curves (default, soft, hard)
6 buttons: Octave Up/Down, PB1/PB2, Sustain, Part 2
PB1 & PB2 buttons (assignable to: Pitch Bend, Transpose, Vol, Pan, Track* or Patch* change)
Part Two button: Assignable to Octave, MIDI Channel, Transpose, Layer and Latch (momentary)
“S” button: Assignable to Sustain or Modulation
Transport control via secondary button function*
Works with any DAW or MIDI music software on OS X, Windows and Apple iOS.
Nektar DAW Integration for: Bitwig, Cubase, Garageband, Logic, Nuendo, Digital Performer, FL Studio, Mixcraft, Reason, Reaper, Sonar and Studio One.
Connections: Micro USB port (USB-powered)
Weight & Dimensions: 33.5 cm (L) x 10 cm (D) x 2.1 cm (H), 0.4 kgs
(*= requires Nektar DAW Integration)
2万
音频应用初级会员
Rank: 6Rank: 6
 楼主| 发表于 2009-3-23 09:46:58 | 显示全部楼层
:hug::D
1481
发表于 2009-3-23 14:45:13 | 显示全部楼层
GMT+8, 2025-5-30 22:48 , Processed in 0.030481 second(s), 8 queries , Redis On.
