查看: 28575|回复: 2
[转帖] Maselec MTC-1X
6万
音频应用高级会员
Rank: 7Rank: 7Rank: 7
发表于 2009-3-16 19:56:37 | 显示全部楼层 |阅读模式
详细介绍
供应销售Maselec全线产品!中国独家代理品牌!
The Maselec MTC-1X is the perfect tool for mastering studios as well as for high quality home recordings. With exceptional sonic properties, new functionalities and usual rock solid Maselec quality, the MTC-1 is an ideal alternative to the MTC-2 mastering console.
The MTC-1 measures 3 U height with a depth ‘behind panel’ of 260mm and 8kg weight. The front control surface has 42 push-button controls with LED lights and 12 high quality rotary switches. Gold XLRs are used for all audio connections, assisting the use of highest quality cables. Connecting and rearranging external equipment is very easy.
The Input section:
•Input source selection
•Phase invert for left and right
•Separate Left and Right gain controls
•5dB additional gain selectable for low level sources
•Low-cut and High-cut filters
•Independent Cut controls for left and right
The Output section:
•Elliptical filter with 20 frequencies
•Stereo Width control
•Output Cut control
•The stereo image circuits are identical to the famous controls of the MTC-2
The Insert section has six insert points and offers
additional powerful functions:
•M-S with gain control for the ‘difference’ signal
•Inserts 1 & 2 equipment swap (FLIP)
•Insert 4 or Inserts 2-4 cross-fade or additive mix with
•the use of a rotary switch. This function could be
•used for ‘parallel’ compression or adding reverb
•Inserts 4 & 5 equipment swap (FLIP)
•Insert 6 can be moved to Post Output. This is the preferred position for a brick-wall limiter.
The Monitor section:
•Four external Monitor Sources
•Monitor of the Input and Output sections
•Two speaker feeds
•0 to +10dB offset trim for inputs S1 and S2
•Monitor of the Stereo-, Left-, Right-, Mono- or Difference- signal
•Individual Cut controls for Left and Right speakers
•Progressive Dim function
•Meter output, which follows the monitor source
•–6dB, -8dB and –10dB Meter Offsets
We've been buying, selling and restoring the world’s best consoles since 1993
Shopping for a recording console can be an intimidating process. You can spend countless hours online searching for answers only to end up with more questions than when you started. That's why we’ve created our one-of-a-kind shopping experience to help you purchase the console that is exactly right for you and your studio.
Finding the perfect console means being connected, and for over 20 years, we’ve been one of the biggest players in the worldwide audio marketplace. We’ve helped thousands of customers complete the console buying process, while also helping to facilitate brokered sales, gear trade-ins and purchasing classic desks for refurbishment.
Each of our premium serviced consoles has passed through a rigorous multi-point inspection and meticulous testing to ensure the result is a world-class restoration. Upon completion, your console will be expertly crated and shipped to your studio, where our highly skilled technical experts can lead a worry-free integration.
No matter whether you’re interested in a vintage piece or the latest releases, our team of experts can answer even the toughest questions. From servicing and shipping consoles to creating custom furniture, patch bays and turnkey packages, we’ve been involved in every aspect of the industry. We work tirelessly to provide the best selection, service and support anywhere to help our customers find the console of their dreams. Want to see what we can do for you? Click here to see.
规格参数
品牌 :Maselec MTC-1X加工定制 :
6719
发表于 2009-3-16 20:04:42 | 显示全部楼层
聆听、欣赏、支持!:victory::victory::victory:
4万
音频应用中级会员
Rank: 5Rank: 5Rank: 5
发表于 2009-3-17 14:26:36 | 显示全部楼层
顶起来  Maselec MTC-1X
GMT+8, 2025-9-6 08:17 , Processed in 0.028868 second(s), 8 queries , Redis On.
