查看: 22488|回复: 3
[音源] Audio Imperia - Klavier - Red Planet Piano KONTAKT
1万
发表于 2009-3-12 16:23:04 | 显示全部楼层 |阅读模式
Audio Imperia - Klavier - Red Planet Piano KONTAKT | 9.59 Gb
AUDIO IMPERIA的“Klavier”是我们新的“私人股票工具”系列中的第一款乐器,原本是为一组拖车作曲家设计的私人样本库,这个系列的两款乐器结合了世界上最好的原始/有机录音和后期制作/声音设计,整个项目的目标是从用户体验和原始声音开始,并将我们的方式倒退到最终产品,这是多才多艺,立即鼓舞人心的。
“红色行星钢琴”受到安迪·威尔的“火星人”电影改编的启发。哈利·格雷格森·威廉姆斯的得分是绝对惊人的,并启发我们创造了一个“外太空”版本的Klavier。红色星球钢琴与Gravitas钢琴共享同样的有机样品池。但为了获得那种特殊的“外太空”电吉他音色,我们创造了许多复杂的吉他音色。它们的设计与您需要唤起深度感和空间感的郁郁葱葱的广泛的声音相匹配。这与有机钢琴结合,创造一个真正独特的声音。我们使用了非常有限的Ibanez JPM90HAM的颈部(humbucker)和分裂线圈(单线圈)位置的混合。单线圈和直接的完美融合,以及颈部绞盘的温暖和深度。最初的录音是直接完成的,然后我们通过各种放大器和fx信号链重新录制录音。
原文
AUDIO IMPERIA's “Klavier" is the first instrument in our new “Private Stock Instruments” series. Originally intended as a private sample library for a group of trailer composers, the two instruments in this series combine the very best of the worlds of raw/organic recordings and post-production/sound design. The goal throughout the whole project was to start with the user experience and the raw sound and to work our way backwards to a final product that is both versatile and instantly inspiring.
The “Red Planet Piano” was heavily inspired by the movie adaptation of Andy Weir’s “The Martian”. Harry Gregson-Williams' score is absolutely amazing and inspired us to create an “outer space” version of the Klavier. The Red Planet Piano shares the same organic sample pool used for the Gravitas Piano. But to get that particular “outer space” electric guitar sound, we created a number of complex guitar sounds. They are designed to match that lush and wide sound that you need to evoke that feeling of depth and space. This, combined with the organic piano, creates a truly unique sound. We used a blend of the neck (humbucker) and the split-coil (single coil) position of the very limited Ibanez JPM90HAM. A perfect blend of the single coil twang and directness and the warmth and depth of the neck humbucker. The initial recordings were done direct and we then reamped the recordings through various amp and fx signal chains.
下载地址:
游客,如果您要查看本帖隐藏内容请回复
1万
发表于 2009-3-12 16:39:35 | 显示全部楼层
:victory: :victory: :victory:
4321
发表于 2009-3-12 17:22:53 | 显示全部楼层
:victory: Audio Imperia - Klavier - Red Planet Piano KONTAKT
1万
 楼主| 发表于 2009-4-17 08:57:50 | 显示全部楼层
看一看。。。。。。。
GMT+8, 2025-6-6 03:08 , Processed in 0.031201 second(s), 8 queries , Redis On.
