Arturia Piano V 2.1.1.1786 - ÎïÀí½¨Ä£¸ÖÇÙÒôÉ«
¸ÖÇÙVÏÖÔÚΪVϵÁдøÀ´ÁËËùÓÐÀÖÆ÷µÄÍõÕߣ¬°üÀ¨Ò»¸ö³äÂú¸÷ÖÖ¸ÖÇÙÖÒʵģÐ͵Ť×÷ÊÒ£¬ÒÔ¼°ËÜÔì¸ÖÇÙÒôÉ«ÒÔʵÏÖȫпØÖÆË®Æ½µÄÄÜÁ¦¡£
¸ÖÇÙVÌṩµÄ²»ÊÇÒ»ÖÖ£¬¶øÊÇÊ®¶þÖÖ²»Í¬µÄÊÀ½ç¼¶¸ÖÇÙ£¬ÎÒÃÇʹÓùãÊÜºÃÆÀµÄÔìÐͼ¼Êõ¾«ÐÄÖÆ×÷¡£ÒòΪËüÃÇÊÇÄ£ÐÍ£¬Äú²»½ö¿ÉÒÔ»ñµÃ¸÷ÖÖ¸÷ÑùµÄÕæÕý¸ÖÇÙ£¬ÎÒÃÇ»¹Äܹ»ÎªÄúÌṩÒÔǰ´Óδ·ÃÎʹýµÄ²»Í¬×é¼þºÍÌØÐԵĿØÖÆ¡£Äã¿ÉÒÔÑÝ×àÏÖʵÖ÷ÒåµÄáÛ·å¸ÖÇÙ£¬»òÕßÓ÷Ǵ«Í³µÄÉùÒô»ñµÃÄãÏëÒªµÄ¼¤½ø¡£¶à¹¦ÄܸÖÇÙVÊÇÈκμüÅÌÊÖ£¬×÷¼Ò»òÖÆ×÷ÈËÔÚÈκÎÒôÀÖ·ç¸ñÖв»¿É»òȱµÄ»ù´¡ÀÖÆ÷¡£
ËùÓмüÅÌÀÖÆ÷Ö®ÍõÏÖÔÚ¶¼ÔÚV CollectionÖÐ
ÏÖÔÚ£¬Äú¿ÉÒÔ»ñµÃÕæÊµ¸ÖÇٵij¬ÕæÊµÉùÒô£¬¸Ð¾õºÍÐÐΪ£¬ÓëVϵÁÐµÄÆäËû²¿·ÖÒ»Ñù·½±ã¡£
¸ÖÇÙÊǼüÅÌÀÖÆ÷ÎÞ¿ÉÕùÒéµÄÍõÕߣ¬¼¸¸öÊÀ¼ÍºóÈÔÈ»±£³Ö×Å×Ô¼ºµÄµØÎ»¡£ Piano VΪÄú´øÀ´ÁËÄúϲ°®µÄËùÓбíÏÖÁ¦£¬ÈÃÄúÔÚµÚһʱ¼äµ¯¸ÖÇÙ¡£ÎÒÃDz»ÊÇʹÓóɶѵÄÑùÆ·£¬¶øÊÇÔÚÎïÀíÖÊÁ¿µÄϸ΢ˮƽÉÏÄ£Äâ¾ÅÖÖ²»Í¬µÄÕæ°ô¸ÖÇÙ£¬ÒÔÌṩÄúËùÐèµÄÕæÊµ¸Ð - ÒÔ¼°ÊʺÏÈκθèÇú»ò»ìÒôµÄ¸÷ÖÖ¸ÖÇÙ¿Úζ¡£
ƾ½èÆäÉùÒô£¬¿ÉÑÝ×àÐÔºÍÁé»îÐÔ£¬Piano VÊÇÊʺϸ÷ÖÖ³¡ºÏµÄ±Ø±¸ÀÖÆ÷¡£
ÔÎÄ
The Piano V now brings to the V Collection the king of all instruments, including a studio full of faithful models of various pianos, plus the ability to shape your piano sounds for a whole new level of control.
The Piano V delivers, not one, but twelve different world-class pianos that we¡¯ve meticulously crafted using our critically acclaimed modeling technology. Because they¡¯re models, you not only get a wide range of true pianos, we¡¯ve been able to give you controls over different components and characteristics that have never been accessible before. You can play pianos that are the pinnacle of realism or get as radical as you want with unconventional sounds. The versatile Piano V is an indispensable foundational instrument for any keyboardist, writer or producer in any style of music.
The king of all keyboard instruments is now in V Collection
Now you can finally get the ultra-authentic sound, feel and behavior of a real piano with the same convenience as the rest of your V Collection.
Still holding its own after centuries, the piano is the undisputed king of keyboard instruments. Piano V brings you all the expressive qualities you love that got you into playing piano in the first place. Instead of using stacks of samples, we modeled nine different awesome pianos at the granular level of their physical qualities to deliver the realism you demand¡ªand across a wide choice of piano flavors to fit in any song or mix.
With its sound, playability and flexibility, the Piano V is an indispensable instrument for all occasions.
Choose from legendary pianos
If you could have the sound of any piano you wanted¡ oh, wait¡ now you do!
There are as many different sonic personalities as there are pianos. No two are alike, even the same model from the same manufacturer. Different songs and different tracks also demand specific qualities. That¡¯s why Piano V gives you a total of nine different instruments spanning both grands and uprights. Just pick the preset that best serves you in the moment and you¡¯re good to go. These models are totally malleable as well, letting go far beyond that to modify the different components that make up each instrument¡¯s signature sound¡ªeverything from slight tweaks to extreme treatments. The possibilities are endless.
The Piano V gives you complete control over the character of your pianos for the ultimate in creative options.
Change the environment too
The Piano V let¡¯s you shape more than just the instrument. You can also change the room and recording setup to dramatically refine both spatial and timbral qualities to your taste.
A given piano can sound very different depending on its environment, miking and processing. That¡¯s why we¡¯ve factored all those elements into the Piano V models as well. With the simple click of the mouse, you can move any piano into a different type of room, select various mic positions, and shape the tonality with built-in EQ.
Whether you stick with presets or explore deeper environmental options, Piano V lets you easily get just the spacious qualities you¡¯re looking for¡ªno engineering degree required.
Main Features:
Advanced Physical modeling engine (no static samples)
12 different piano models to choose from
Concert Grand
Intimate Grand
Pop Grand
Jazz Upright
Piano-bar Upright
Pop Upright
Classical Upright
Glass Grand
Metal Grand
Japanese Grand
Plucked Grand
Tack Upright
Customizable Action settings
Global string tension ( tuning)
Unison detuning
Stretch tuning
Dynamic range
Hammer hardness
Hammer position
Velocity Curve editor to match your keyboard action
Customizable Mechanical noises
Pedal Noise
Key noise
Hammer noise
Mechanics
Lid position
Soundboard resonance
Multiple microphone positions
Microphone Mixer
Convolution Room simulator with 14 room types
Output parametric EQ
88 factory presets
Easy to use MIDI mapping
Whats New:
New Features
KeyLab MK2 Integration
Clicking on the preset browser "Clear All" button now scrolls back the result list to its top
Improvements
Reworked preset leveling and consistency
Bugfixes
User MIDI configuration is now properly recalled when loaded from an external file
Fixed an issue where you had to click twice on the empty MIDI configuration to properly select it
Default MIDI configuration is now properly working
No more white flash when resizing our instruments inside macOS applications in AU
Various Komplete Kontrol / Maschine improvement
No more crash when a "Song Select" message is received
No more cracks and glitches appearing when modifying effects dry/wet parameters
User preset saving feature is now working properly
No more duplicated presets
Live 10 doesn't crash anymore when browsing preset from AU version
Resizing the plugin window don't open the export bank popup for some users anymore
No more crash when switching instruments on a track in FL Studio on macOS
Arturia Piano V 2.1.1.1786| 88.7 MB
ÏÂÔØµØÖ·£º
Arturia Piano V 2.1.1.1786 - ÎïÀí½¨Ä£¸ÖÇÙÒôÉ«.txt
(98 Bytes, ÏÂÔØ´ÎÊý: 0)
