Soundiron Microrgan KONTAKT
MicrorganÊÇÓÉÒâ´óÀûµç×Ó¹«Ë¾FarfisaÔÚ20ÊÀ¼Í50Äê´ú½¨ÔìµÄÒ»¿îÀÏʽ49¼üµç¶¯Â«Î·çÇÙ¡£Õâ¿î¾µäÀÖÆ÷µÄµ®ÉúÔ´ÓÚº±¼ûÇÒ±¸ÊÜ×·Åõ£¬ÕâЩÀÖÆ÷µÄÆðÔ´ÉñÃØÄª²â£¬ÎÒÃÇÌØÓеļüÅÌÔÚ¹ýÈ¥¼¸Äê¿´µ½µÄ²»½ö½öÊÇËüµÄÄ¥ËðºÍ˺ÁÑ£¬¾¡¹ÜËüÈÔÈ»ÌýÆðÀ´²»´í£¬ÒòΪËüµÄ¼á¹Ì»úеºÍ¼òµ¥Éè¼Æ¡£ÎÒÃÇץסÁËËüµÄÎÂů£¬Ç«Ñ·¶øÓÖ±¥ÂúµÄÒôµ÷£¬ÓµÓÐÎÞÏÞµÄÖ§³ÅºÍ½ôÃܵĶÏÐø¡£µ«ÊÇ£¬Òª½«ÕâÔ¶Ô¶³¬³öÒ»¸öÆÕͨµÄ«ηçÇÙÑùÆ·¿â£¬ÎÒÃÇ»¹´´ÔìÁË20Öַdz£°ôµÄÉùÒôÉè¼ÆµÄ¶¨ÖÆºÏ³ÉÆ÷ºÍÌØÊâЧ¹ûÔ¤ÉèÒÔ¼°40ÖÖ¶ÀÌØµÄÒôÉ«Éè¼Æ·ÕΧ£¬¿ÉÒÔÏñ´óÆøºÏ³ÉÆ÷£¬ÎËÃùºÍ³ÄµæÒ»ÑùʹÓÃÉ«²Ê½øÐв¥·Å»òʹÓÃÖ±½ÓÔÚÄãµÄDAWÖнøÐÐÇ¿µ÷ºÍÓÅ»¯ÖÊÁ¿¡£
ÎÒÃÇÔÚGUIÉϼ¯³ÉÁËÐí¶àÓÅÐãµÄÉùÒô¿ØÖƹ¦ÄÜ£¬ÈÃÄú¿ÉÒÔÁé»îµØÒÔ¶àÖÖ·½Ê½Å¤ÇúÐÎ×´¡£Äú¿ÉÒÔ¿ØÖÆÒôÁ¿£¬Æô×࣬ÊÍ·Å£¬Ë²Ì¬Æ«ÒÆ£¬²üÒôºÍ°Ë¶È·Ö²ã¡£ ¡°»¬Ï衱¿ØÖÆ»¬¿é¿ÉÈÃÄú²¥·ÅÁ¬ÒôºÍ»¬Òôµ¼³Ì¡£Äú»¹¿ÉÒÔÕÒµ½Ò»¸ö¿ÉÊÊÓ¦µÄLFOϵͳ£¬¾ßÓпÉÑ¡µÄLFOÐÎ×´£¬µ÷ÖÆÄ¿±ê²ÎÊý£¬ËÙ¶È£¬Ç¿¶È£¬½Ú×àͬ²½ºÍµÈëʱ¼ä¡£Äú»¹¿ÉÒÔʹÓÃ13¸öµÍͨ£¬¸ßͨºÍFXÂ˲¨Æ÷£¬ÒÔ¼°¿ÉÖ¸¶¨µÄµ÷ÖÆ¿ØÖÆÑ¡Ï°üÀ¨ËÙ¶È£¬Ä£Ì¬ÂÖ£¬±í´ïʽ£¬´¥Ãþºó£¬¼üλÖúͲ½ÐòÆ÷¿ØÖÆÌ¨¡£Äú»¹¿ÉÒÔʹÓÃÎÒÃǵĿɶ¨ÖÆÅÃÒôÆ÷£¬ÄÚÖÃËÙ¶ÈÒôÐòÆ÷±í£¬²¢¿ØÖÆarp·½Ïò£¬Òô·ûʱ¼ä£¬°Ú¶¯£¬Ëæ»ú»¯ºÍ³ÖÐøÊ±¼ä¡£
ÔÎÄ
Microrgan is a vintage 49-key electric reed organ built in the 1950s by the Italian electronics company Farfisa. Rare and highly sought-after, the origins of this classic instrument are shrouded in mystery and our particular keyboard has seen more than its fair share of wear and tear over the years, although it still sounds good as new thanks to its rugged mechanics and simple design. We¡¯ve captured it¡¯s warm, humble and yet full-bodied tone with infinite sustains and tight staccatos. But to take this far beyond an ordinary reed organ sample library, we¡¯ve also created 20 awesome sound-designed custom synth and special effect presets and 40 unique sound-designed ambiences that can be played chromatically as atmospheric synths, dronescapes and pads or used directly in your DAW for underscoring and texture.
We¡¯ve packed the GUI with lots of great sound-shaping controls that give you the flexibility to warp the shape in many ways. You have control over Volume, Attack, Release, Transient Offset, Vibrato and Octave layering. The "Glide" control slider allows you to play legato and portamento leads. You¡¯ll also find an adaptable LFO system, with selectable LFO shape, modulation target parameter, speed, intensity, tempo-syncing and fade-in time. You can also apply your choice of 13 lowpass, high-pass and FX filter, with assignable modulation control options, including velocity, modwheel, expression, after-touch, key position and step-sequencer table control. You can also use our customizable arpeggiator, with a built-in velocity sequencer table and control over arp direction, note timing, swing, randomization and duration.
Soundiron Microrgan KONTAKT | 436 Mb
ÏÂÔØµØÖ·£ºÓοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë »Ø¸´ |
